Old 12-23-2012, 12:02 AM   #1081
drewnabobber
Urban Adventurer
Oddometer: 30
You can't put the clipons above the triple without raising the forks and screwing up the handling. Best bet would be riser clipons from woodcraft or svracingparts. On the first gen the N and S top triples are interchangeable (they are not on the 2003 onwards model) so you could also look at getting the N triple and putting handlebars on the bike.
drewnabobber is offline   Reply With Quote
Old 12-23-2012, 04:10 AM   #1082
gentlemanjim
gentlemanjim's Avatar
Oddometer: 197
That would be OK for me because of my limitied vertical stature I need tolower the bike a bit and that would blance the bike with a lowering linkin the rear.
1. Does doing as I suggested raise the bar suffciently like going tubular?
2. What is the width of the clip-ons compared to a "N" tubular bar?
gentlemanjim is offline   Reply With Quote
Old 12-31-2012, 09:09 AM   #1083
blue72beetle
Look at my Wee
blue72beetle's Avatar
Oddometer: 183
Hi guys. I'm a regular over at SVRider, but I thought I'd sign up and spend some more time over here too.
I've got a 2002 SV650 that I'm probably going to sell or part out soon. And I also have a 2003 SV650S that I'm turning into a sport touring machine with hard luggage.
blue72beetle is offline   Reply With Quote
Old 01-01-2013, 12:01 AM   #1084
PeteN95
PeteN95's Avatar
Oddometer: 2,741
Or you can do it yourself cheap and easy. My friend Willie will show you how:
http://www.sv-portal.com/forums/showthread.php?t=18709
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 01-06-2013, 09:55 PM   #1085
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,386
has anyone tried one of the danmoto exhausts on their SV? i'm specifically interested in the jisu model which apparently is quieter but haven't found any youtube videos comparing it to the stock pipe.
i'm turning my SV650 into a thin-strom on a budget and like the price of the jisu ($145 delivered) to drop the weight a little and have a pipe that won't be so exposed. but i'm definitely not interested if it's anywhere near the 108 decibels of the smaller exhausts they do.
did a write up on the project to date here. the overall aim seems to be make it as ugly as possible, but a bit more dirt worthy in the process.
BEFORE....
AFTER....
B1 is offline   Reply With Quote
Old 01-06-2013, 11:18 PM   #1086
opmike
Choosing to be here.
opmike's Avatar
Oddometer: 335
Mission accomplished.
"you want to fix the Pledge of Allegiance, put a disclaimer at the end: with liberty and justice for all...must be 18, void where prohibited, some restrictions may apply, not available in all states."
opmike is online now   Reply With Quote
Old 01-07-2013, 02:31 AM   #1087
fragile_this_side_up
fragile_this_side_up's Avatar
Oddometer: 1,371
eh, i think it looks good. i have a delkevic stubby on my bike. it's not too bad with the silencer in..
fragile_this_side_up is offline   Reply With Quote
Old 01-07-2013, 11:09 AM   #1088
JGNC
JGNC's Avatar
Oddometer: 387
I have one too. Just a slip on but it sounds great and not loud at all.
Sent from my DROID X2 using Tapatalk 2
-Jesse
JGNC is offline   Reply With Quote
Old 01-07-2013, 12:53 PM   #1089
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,005
I think the ADV SV is super cool lookin'.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 01-07-2013, 06:36 PM   #1090
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,592
Ditto....
Murphy Slaw is offline   Reply With Quote
Old 01-07-2013, 07:14 PM   #1091
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,301
My work still in progress...
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 01-08-2013, 05:02 AM   #1092
kalonji
nihilism or nothing
kalonji's Avatar
Oddometer: 1,917
I too am a fan of the DSV. Looking forward to reading the build thread to see your suspension changes if any.
kalonji is offline   Reply With Quote
Old 01-09-2013, 10:18 AM   #1093
Henderson757
Adventure~Rugby
Henderson757's Avatar
Oddometer: 426
HELP,
I have just converted my SV1000s from Clip on to LSL Conversion. Everything was pretty easy but I am having a hard time getting the Throttle cables to snap back when the bars are turned all the way to the right, ( The Throttle is next to gas tank ) Any suggestions? I have rerouted the cables and they dont seem to be hung up, in a neutral position the throttle snaps back and when next to the windscreen it is good as well. I have about 5mm of play.
Thanks for the help
PS. . I used some graphite to lube cables which has helped alittle.
Henderson757 is offline   Reply With Quote
Old 01-09-2013, 02:57 PM   #1094
kalonji
nihilism or nothing
kalonji's Avatar
Oddometer: 1,917
Originally Posted by Henderson757 View Post
HELP,
Thanks for the help
When I went from clip on's to handle bars I had to adjust the throttle cable itself
Here's a YouTube link that may help
http://www.youtube.com/watch?v=Qxglq...e_gdata_player
Old 01-09-2013, 02:59 PM   #1095
goodcat8
goodcat8's Avatar
Oddometer: 3,005
Just to test tension, try sliding the throttle/grip in on the bars. If it snaps back you've got to much tension and a cable re-route is needed.
Didn't the LSL come with longer cables?
Good luck.
Times are GMT -7.   It's 09:30 AM.
