Old 08-20-2008, 06:13 AM   #106
aceluck
aceluck's Avatar
Oddometer: 232
Motophoria, that is truly an awesome setup! Thanks for the detail pics.
I adventure-tour on my GSXR. 160 mph is adventurous, no?
aceluck is online now   Reply With Quote
Old 08-20-2008, 06:36 AM   #107
Rider_WV
Rider_WV's Avatar
Oddometer: 2,325
OK guys I need some tire advice. What are you guys running on the rear and what mileage are you seeing? I am currently running Pirelli DIablo strada's and cant get more than 5k out of a rear. Technically my current tire is at 4800 and at the wear bars. At this rate I am changing the rear every two months. I will be on my third tire since april when I order one.
The pirelli's warm quickly, balance easily and handle great. I was just hoping for more like 7-8k out of the rear. I guess thats unrealistic. I am getting the most wear on the left of the tire, exactly like my last one. Right side is great, center is decent, left of center is bald. I check my tire pressure at least 3 times a week. Running 37psi rear, very little 2-up.
Anyone getting decent mileage from anything else? Conti, Michellin, Metz?
Rider_WV is offline   Reply With Quote
Old 08-20-2008, 06:51 AM   #108
disconnected OP
anti click
disconnected's Avatar
Oddometer: 7,246
Im on my third tire too since April, I run the Stradas also... the left side is wearing from the crown in the road.. I thought 5k was pretty good since the Diablos I used to run on the CBR only gave me 2k...
I buy from Dennis kirk they seem to have good pricing.. I have convinced my self if I get anything else higher milege the tire would not be as safe in the twisties since the compound would need to be harder..
Im up for suggestions too gang..
IBA # 47004
disconnected is offline   Reply With Quote
Old 08-20-2008, 07:03 AM   #109
Rider_WV
Rider_WV's Avatar
Oddometer: 2,325
well at least we are consistant, maybe its just the combo of our roads and our throttle application. 5k isnt terrible but changing tires this much will get old. I usually order from Ironpony since its free shipping and I am in their 1 day delivery range.
Old 08-20-2008, 07:15 AM   #110
ChopSuey
ChopSuey's Avatar
Oddometer: 410
06 SV650S with handlebar conversion, heated grips, and Givi hardbags.
ChopSuey is offline   Reply With Quote
Old 08-22-2008, 06:58 AM   #111
disconnected OP
anti click
Oddometer: 7,246
Has anybody lowered there pegs alittle.. I have heard you can use Buell Pegs..
Any input would be appreciated..
greg
IBA # 47004
Old 08-22-2008, 08:32 AM   #112
Rider_WV
Rider_WV's Avatar
Oddometer: 2,325
I have the buell pegs, got them off ebay for about $25. Made a huge difference in riding position. I am 6' with a 33" inseam and I felt a little cramped on the stockers. They are by far the best mod I have done to the bike.
I can get some pics in a few minutes if you want some.
Old 08-22-2008, 08:49 AM   #113
disconnected OP
anti click
Oddometer: 7,246
do any Buell Pegs fit, or do you need somthing specific??? Pictures would be great!
thanks,
greg
IBA # 47004
Old 08-22-2008, 09:02 AM   #114
Snaildrake
prowling the SW since '64
Snaildrake's Avatar
Oddometer: 163
Can you handle five inches of naked alloy?
Originally Posted by disconnected
Has anybody lowered there pegs a little.. I have heard you can use Buell Pegs..
greg
Sure, I just did the Buell peg modification last week to my naked SV for $26 and can tell you how it works for me. My quick take is that the switch works if you're looking to lower the pegs inexpensively to accommodate longer legs for commuting or touring comfort. It's possible you won't like your feet being pushed 1+" outboard - some SVriders tried it and went back to stock pegs.
The change brings the peg down 1" and a fraction back. I am 5' 11' with a 31" inseam and the mod drops my knees so they fit in the tank recesses, gives my legs room so they don't cramp, and makes it easier to find the pegs moving away from stoplights. The basic SV seat-peg position still tilts you forward some, and this doesn't change that.
The Buell pegs need adapting: a couple millimeters shaved off to fit in the SV peg mount, the pin hole bored out, a flat reduced and the lean indicators removed (they're lower, remember?). The modification is easy and could be done with a flat and round file on the sidewalk - I used a drill press and bit, bench disc sander and a few strokes with a flat file. I am slow and meticulous and it took me under an hour.
I can think of three reasons you might not want to do this:
1. The dropped peg pushes your feet out an inch or more from the stock position, so you have to toe in more to reach the brake and shifter
2. The Buell pegs are metal with no rubber pad
3. Your pegs will ground earlier - not clear how much earlier though
The whole switch is well documented in several svrider.com threads, like this one:
Buell footpeg mod pictures
The Buell/HD part no. is N0006.1AD for the pair of pegs. I ordered it from my local HD dealer, took 10 days to come in.
There are also rearset plates that will move the pegs up or down and back, which sportbike riders might want but not me - check svrider if you're curious.
Of course there's the free entertainment bonus: the HD parts counter guy, covered with tattoos and piercings, who I'm sure rides protected only by manly chest hair, looked incredulously at my full ATGATT rig on a 90+ degree day and asked, "Aren't you hot, dude?"
Snaildrake is offline   Reply With Quote
Old 08-22-2008, 09:21 AM   #115
disconnected OP
anti click
Oddometer: 7,246
wow snaildrake, thanks for the info. ..
greg
IBA # 47004
Old 08-22-2008, 09:22 AM   #116
disconnected OP
anti click
Oddometer: 7,246
I just ordered the SW Motech quick release bags too, ill take some pictures when I receive them.
greg
IBA # 47004
Old 08-22-2008, 10:05 AM   #117
Rider_WV
Rider_WV's Avatar
Oddometer: 2,325
couple of pics on my gen1, yep the bike is very dirty I have a gravel road to ride to get to work and a gravel driveway at home.
Old 08-22-2008, 10:06 AM   #118
Rider_WV
Rider_WV's Avatar
Oddometer: 2,325
another, i didnt get the stops ground down enough so the pegs angle back a little.
Old 08-22-2008, 10:07 AM   #119
Rider_WV
Rider_WV's Avatar
Oddometer: 2,325
pic with my cortech saddle bags, mainly cause I am a pic whore
Old 08-23-2008, 11:15 PM   #120
damasovi
damasovi's Avatar
Oddometer: 2,637
some questions about the sv and SVS
Hi I hope you don't see my questions as super dumb and can help me.
I am looking into buying a bike maybe the last one in some time, so I have questions about the difference between the 2 sv, SV vs SVS, how different are they? Fist let me tell you I see the obvious, the setting position, clip ons, and lighting, but other than that, what else is it that I should consider?
I tend to like more the SVS, but if I don’t like the clip ons, can I change them and have something more “standard”?
One last question, how are the lights on this bikes? Are they like the ones on a DL or like the stock KLR? (I love the DL lights, hate the KLR one)
Thanks for your comments
Damasovi
damasovi is offline   Reply With Quote
Times are GMT -7.   It's 07:36 AM.
