Old 06-22-2008, 08:44 PM   #1
TexasMule OP
Float away ya fairy...
TexasMule's Avatar
Oddometer: 3,859
BMW Zumo "can't unlock maps" error
Mulewife has been having fits with her BMW Zumo that came with her K12GT.
She keeps getting an error message "can't unlock maps" on her Zumo.
We're getting ready to go to Canada, and she's trying to upload some routes and the GPS keeps coming back with the above error message.
All the maps are already downloaded, so it's frustrating when she gets this message.
Anybody got any ideas as to this error message?
I think I'll keep my 276C for a while longer.
TMule
You can buy everything, but more time...
______________________________________________
-to my mind alloy triumph tanks rank near titties in their inherent attractiveness -Mutt
TexasMule is offline   Reply With Quote
Old 06-22-2008, 08:53 PM   #2
JR356
JR356's Avatar
Oddometer: 3,746
Have heard from other posts here,that in this situation,you need to reload the maps.
JR356
JR356 is offline   Reply With Quote
Old 06-22-2008, 09:07 PM   #3
TexasMule OP
TexasMule's Avatar
Oddometer: 3,859
JR356
She just re-loaded the maps, got the same error message.
Will try re-loading again.
TMule
Old 06-23-2008, 12:38 AM   #4
pckopp
Aged Adventurer
pckopp's Avatar
Oddometer: 1,280
Do you have the same version of City Nav on your PC as your Zumo? Maybe you upgraded one and not the other? Just a quess.
That's an odd message since the pre-loaded maps in the Zumo are already unlocked.
Phil in Seattle, WA
Europe 2014
pckopp is offline   Reply With Quote
Old 06-23-2008, 03:36 AM   #5
OleGrumpy
TFM/ODS Proficient
OleGrumpy's Avatar
Oddometer: 11,850
Same Issue with Zumo 450
I just bought a new zumo 450 and right from the box I got "can't unlock maps." I found that I can upload routes but not maps.
I think I'll drop back to my old 2610!
Come Revolution, proletarians (how you say, "Joe Sixpack?") not having anything to worry.
Ah, but Ruling Elite, is being different question, altogether.
OleGrumpy is offline   Reply With Quote
Old 06-23-2008, 06:50 AM   #6
pckopp
Aged Adventurer
pckopp's Avatar
Oddometer: 1,280
What maps are you trying to upload? The Zumo models all come with City Nav pre-loaded. You don't need to upload maps.
Confused.
Phil in Seattle, WA
Europe 2014
Old 06-23-2008, 11:42 AM   #7
xlcr
Stop being a dick, dick.
xlcr's Avatar
Oddometer: 4,895
Is she saving the routes to an SD card and then inserting the card in the Zumo? If your PC writes map segments to an SD card and those segments are unlocked for only your 276, the Zumo will deny access to those segments when it reads the card. If you write directly to the Zumo, MS should warn you that the segments will be unuseable and ask for confirmation before it sends the maps.
You should be able to deselect maps when you "Send to GPS".
xlcr is offline   Reply With Quote
Old 06-23-2008, 12:50 PM   #8
TexasMule OP
TexasMule's Avatar
Oddometer: 3,859
I think she was saving the routes to the SD card. I removed the maps from the SD card, and she just sent the routes and waypoints, but she still gets the same message.
She's going to call Garmin and get to the bottom of this (he says hopefully).
TMule
Old 06-23-2008, 12:59 PM   #9
walrond
Earth Wanderer
walrond's Avatar
Oddometer: 1,066
Did your Zumo come with a City Select Nav DVD? If so did you install that DVD on your computer? I suspect that the maps on your PC are not associated with your Zumo and you will be unable to use information derived from the mapsets that are on your PC until you do.
Save $5 when you open a SmugMug account. Use the following coupon: 7ztkgApOHBurY
walrond is offline   Reply With Quote
Old 06-23-2008, 02:56 PM   #10
xlcr
xlcr's Avatar
Oddometer: 4,895
Does she get the message when there's no SD card in the Zumo? There may be a wayward map segment on the internal flash drive.
Old 06-24-2008, 03:33 AM   #11
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
Connect your zumo to your pc
Go to the garmin folder
Delete gmapsupp.img only!
Disconnect and let the zumo restart
BurnieM is offline   Reply With Quote
Old 06-24-2008, 08:04 AM   #12
TexasMule OP
TexasMule's Avatar
Oddometer: 3,859
I deleted that file off her SD card, but still didn't fix the "can't unlock maps" error message.
We'll try it with the Zumo connected to the PC.
TMule
Old 06-24-2008, 09:41 AM   #13
TexasMule OP
TexasMule's Avatar
Oddometer: 3,859
As MuleWife just e-mailed me...
THAT IS A WINNER!
Fixed the problem.
Thanks.
TMule
Old 06-25-2008, 12:57 AM   #14
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
Problem was when you copied some waypoints or routes across to the zumo you inadvertantly had a map segment selected and the map box ticked and you copied over a map that was not unlocked for your zumo.
gmapsupp.img is the map file that MapSource on the PC creates when it copies maps.
The preloaded factory map file has a different name
Cheers,
Burnie M
Old 06-25-2008, 07:51 AM   #15
TexasMule OP
TexasMule's Avatar
Oddometer: 3,859
Cheers,
Burnie M
Excellent explanation mate.
Thanks again.
TMule
Times are GMT -7.   It's 09:53 PM.
