Old 08-31-2009, 06:28 AM   #181
Knobbiethrower
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,282
emailed request
Knobbiethrower is offline   Reply With Quote
Old 09-01-2009, 04:43 PM   #182
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
Got mine today. Thanks.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 09-01-2009, 04:53 PM   #183
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
I think that's the way to go...fold them in and they can't get broken.
I'm trying to get a 6mm thumbscrew milled for the elbow....so we can loosen and tighten on the fly.....regards, moto-science
hb7 is offline   Reply With Quote
Old 09-01-2009, 11:01 PM   #184
Jiro
Watch Out for Squirrel!
Jiro's Avatar
Oddometer: 639
GAH! I'm fed up with my side mirrors. time to order this! PM SENT!
2003 F650GS
Ride Safe and Fast!
Jiro is offline   Reply With Quote
Old 09-01-2009, 11:06 PM   #185
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
never mind. he has great return policy.
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 screwed with this post 09-06-2009 at 09:43 PM
666 is offline   Reply With Quote
Old 09-02-2009, 01:18 AM   #186
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
With a handle like "666 and Satan Rules" , I should take your remarks
seriously... but I can't. Nobody else reports this. Slide a little shim cut from a soda can to tighten the joint is my suggestion.
After ~30k miles on my single cyl mule and several get offs, no broken mirrors....nothing.
Old 09-02-2009, 10:55 AM   #187
Knobbiethrower
ADV in ADK
Oddometer: 1,282
Originally Posted by Knobbiethrower
emailed request
Followed up with a PM....
Old 09-02-2009, 11:11 AM   #188
Chadd
I live in the wrong place
Oddometer: 467
email sent
Sent an email for a set.
Chadd Thompson
94 Ducati Elefant
04 625 SXC
03 WR250F
95 GasGas JT25
Chadd is offline   Reply With Quote
Old 09-02-2009, 05:27 PM   #189
xymotic
xymotic's Avatar
Oddometer: 8,367
Originally Posted by 666
I have these mirrors on my 640 and they fold at speed above 70 mph. Retarded design. Everything else works good on my ktm.
Mine work pretty good @ 100.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 09-02-2009, 06:38 PM   #190
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,113
I'm afraid I have to agree with "666" there. Henry has the best/fastest customer service and I think the military mirrors are the best design out there - while they last. I have had 3 and after a few months the round mirror part just keeps getting looser on the stock and it doesn't appear to be any way to tighten them down? The metal in the round mirror part looks like it is "stretched out".
If I try another pair I will be very intentional on not adjusting the mirror on the stalk, "fine tuning it" etc. I'm wondering if there is just only so much adjusting/moving around they can take.
At one point I had a 280 mm military mirror on one side and the sean kenn mirror on the other. There was no comparison in that the sean kenn is extremely akward to adjust and the military mirror very straight forward. However after lots of adjustments you are able to tighten the sean kenn on the stalk when its time to throw the military mirror away.
I'm also curious if the 240 mm would hold up bettter? I've got one on now - I can't see as well around my shoulders but I imagine they don't take near the buffeting at high speeds that the longer 280 mm stalks do.
No offense Henri - like I said while they work they are my favorite, most usable dual sport mirror. And Henri's service ... I think UPS was knocking at my door with the mirrors before I hung up the phone with him . The only reason I mention it is I wonder if something could be done to fix that problem. There is only 1 thing I like better on my stock KTM 690 mirors and its that part I'm wondering if it would be possible to incorporate in the military mirror. On the stock KTM 690 mirror, the mirror connects to the stalk via a ball and socket type connection. Then in addition to that, there is like a washer around the stock with screws going into the mirror itself. When it gets loose (which it does as well), you can pull back the rubber boot that covers that area, tighten the screws which pulls the ball tighter into the socket and stiffens it up again. That's all I need for the perfect mirror! And Henri - if you can pull it off I will gladly give yo $39 a mirror!
rickypanecatyl is offline   Reply With Quote
Old 09-02-2009, 09:15 PM   #191
xymotic
xymotic's Avatar
Oddometer: 8,367
On the Dakar the mirrors would loosen a bit over time. Some owners had success putting a hose clamp on it, heating the thing up with a heat gun/hair dryer and tightening it while it cooled and then removing the clamp. I imagine it looks crappy but it might work for a bit. I guess you could leave the clamp on too.
Albert Einstein
6:10 to Yuma
Old 09-04-2009, 10:50 AM   #192
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
Well, they do fold. Every day they do it. Both: left and right. Makes them useless. It's less of a problem when it's cold. May be age issue? 10years almost now.
I am talking about stock KTM mirror. Not the mirrors from this guy. He seem to have better return policy than ktm(or bmw - has same issue on f650 and dealer suggested using superglue)
666 screwed with this post 09-06-2009 at 09:47 PM
Old 09-04-2009, 11:04 AM   #193
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
Ok, If you you have a loose ball socket in the mirror and you bought any KTM folding mirror from me in the last 12 months ....
Send me the Mirror stem only for an exchange.
Enclose $6 for shipping per stem.
If you are in Kuala Lampur...contact me via email : hb7@ca.rr.com
Address is in the contact tab on the web page.
All the best,
Henri Baccouche
moto-science : the ducati mirror specialist ™
http://moto-science.com/
323-933-1366
skype shb777
hb7 screwed with this post 09-04-2009 at 11:50 AM
Old 09-06-2009, 08:16 PM   #194
the come back kid
the come back kid's Avatar
Oddometer: 505
that seems like excellent customer service to me, but I got my $ worth already. Thanks anyway P.S. my mirrors work well (not like new), but I have planted them 4 inches under the mud/dirt twice and wacked them off tree branches pretty hard at least a dozen times (I like to know what's happening behind me in the woods too. I only fold them for severe bushwacking)
the come back kid is offline   Reply With Quote
Old 09-06-2009, 10:38 PM   #195
Chadd
Oddometer: 467
Got em,
Thanks for the quick shipping.
Chadd Thompson
94 Ducati Elefant
04 625 SXC
03 WR250F
95 GasGas JT25
Times are GMT -7.   It's 04:25 PM.
