Old 04-11-2009, 10:37 AM   #121
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
Mike in Louisiana writes about the 2008 KLR650 's :
"All is OK!" The 2008 and newer KLR's does have 8mm left handed threads on their mirror stems, this is threaded into a rubber bushed adapter that then threads into the control mounts with a 10mm right handed thread. I removed the rubber bushed adapter and was able to screw your KTM folding mirrors into the 10mm control mount with no problems.
If for some reason I decided that I still needed to use the rubber bushed adapter I would need to purchase still another addapter to go from a 8m male to an 10mm female that would allow me to screw your mirrors onto the KLR adapter. I don't think I will have to go that route... I like the current installation.
You might consider putting on your page, "for 2008 and newer KLR's," the rubber bushed adapter will have to be removed.
PS: I did take your suggestion and used blue locktite on the threads and did not over tighten. I also used it on the screw in the pivot joint and only tighenting it enough to make it steady but still allowing for vertical adjustment.
hb7 is offline   Reply With Quote
Old 04-11-2009, 10:40 AM   #122
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
Originally Posted by sama3033
Holy crap
I got an email response to my order literally in seconds. That's impressive.
Thank you....for the appreciation. I try to ship as fast as possible.
All the best,
Henri
http://moto-science.com/
323-933-1366 Skype shb777
Old 04-11-2009, 04:17 PM   #123
xymotic
xymotic's Avatar
Oddometer: 8,367
Hey Henri, I just got back from 10 days in Baja, and the mirrors were fantastic. Droped the bike like 6 times, broke a lever, but the mirrors were 0 problem at all. My riding buddy broke both of his Honda mirrors. He bought some emergency Emgo Mirrors in San Diego, so expect a call from him soon
xymotic is offline   Reply With Quote
Old 04-12-2009, 09:10 PM   #124
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
Right on Xymotic....sounds like you had a good time.
Dropped it six times....that's almost too much testing.
regards, henri
Old 04-13-2009, 05:18 PM   #125
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 904
super fast mirrors
They came over nite WOW. Very happy THANKS
dogsslober is offline   Reply With Quote
Old 04-22-2009, 11:40 PM   #126
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,113
Henri - I just broke my mirror on a ride thru the snow. The mirror and metal shaft are ok, its the plastic piece right above the "rotating circle" that broke. Can I buy just that part or do I need to get a whole mirror?
Rick
PS The mirrors have been awesome! The best view I've had of approaching traffic!
rickypanecatyl is offline   Reply With Quote
Old 04-23-2009, 12:12 AM   #127
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
I didn't know there was snow in Kuoala Lampur....in April.
Interesting....
You need a new mirror....
All the best,
Henri
Old 04-30-2009, 07:51 PM   #128
Bonebag
ADDvrider
Bonebag's Avatar
Location: Wisconsin..Hot,Cold and everything in Between
Oddometer: 5,380
I want em...pm'd you...
thanks
G
Bonebag is offline   Reply With Quote
Old 04-30-2009, 08:17 PM   #129
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
thanks
G
Thanks, got it....need your email for paypal.
Yes, it will fit KTM 10mm perch mount.
Old 04-30-2009, 10:16 PM   #130
rickypanecatyl
Oddometer: 1,113
Put them back together with some $5.00 epoxy! I took a bit of time to make sure there was no epoxy in the "teeth" on the wheel that would make it harder to fold out of the way. Works great now!
Rick
Old 04-30-2009, 11:23 PM   #131
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
Send me your address.....I'm going to get the piece you need from Italy
and I'll get in touch. hb7@ca.rr.com
Old 05-15-2009, 02:36 AM   #132
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,019
Sent you an e-mail to order a pair thanks.
Cruz is offline   Reply With Quote
Old 05-16-2009, 04:56 PM   #133
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
Thank you...Australia. I appreciate the support from down under.
Let me know when you get them...All the best,
Henri Baccouche
323-933-1366
Old 05-22-2009, 04:04 PM   #134
RoyB
Dartmouth, Massacusetts
Oddometer: 1,578
A few ??........
These Ducati morrors would fit my new BMW X Challenge......Yes?
Ducati Folding Mirrors 225-325mm Adj. Stems - Pair
$98.00
Also, a buddy of mine mounted bar end mirrors on his BMW F800ST and they vibrated like a bugger. We drilled a small hole in the housing and filled them with #7 lead bird shot.......So stable now you could shave in them!
I fill all my handle bars with #7 bird shot. Amazing difference with vibrations. Highly recommended!
Roy B
Dartmouth, MA www.rvbprecision.com
2007 BMW K1200R Sport abs,2007 DL650 V Strom abs
2004 Honda VFR abs,2001 Moto Guzzi Rosso Mandello
1971 Honda Trail CT90
RoyB is offline   Reply With Quote
Old 05-22-2009, 04:35 PM   #135
hb7 OP
moto-science
hb7's Avatar
Oddometer: 308
Yes, they Ultimate Folding mirrors fit the BMW G650 X challenge...
Also these solid Alloy mirrors for the BMW F650 X, F800 R, F650 GS, F800 GS and R1200 GS cost : 60 each
All the best, henri
323-933-1366
skype shb777
Times are GMT -7.   It's 10:26 PM.
