Old 06-29-2008, 04:20 PM   #1
Spicy McHaggis OP
Darth Peach's cracker...
Spicy McHaggis's Avatar
Oddometer: 3,789
Pissed Ural paint...2 steps below Testors model paint...
Good lord, you LEAN on the paint on one of these motos and it comes off onto your arm.
I just spent a good hour washing the Arctic, after the run up the Dempster to the Arctic Circle. They spread pure calcium cloride onto the road, then go over it with a water truck, THEN they mix it in with a grader...all to keep the dust down.
Problem is - it gets literally EVERYWHERE. I'm quite sure my Ural will rust to pieces before I get it paid off in 2 years.
The springs on the shocks are missing paint - and there was nothing rubbing on them.
So far, that's the only big drawback I've seen with this thing - it's eagerness to rust (who posted the thread with the totally rusted out Ural???) and the shitty paint.
Spicy McHaggis is offline   Reply With Quote
Old 06-29-2008, 05:50 PM   #2
drrider1
just running amuck
drrider1's Avatar
Oddometer: 414
they are what they are............now break oy that flat black rattle can and get busy
Every life needs 9 cats.
11R1200rt 96 Ural Tourist (red peril)
07 Ural Touist brides new ride
drrider1 is offline   Reply With Quote
Old 06-29-2008, 07:49 PM   #3
eastbloc
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,352
My whole damn Ural owes its handsomeness to a rattle can.
You should have seen what that thing looked like after eight years of being driven daily and not washed in the salty mid-Atlantic states!
eastbloc is offline   Reply With Quote
Old 06-29-2008, 09:09 PM   #4
uraldog
vagabond
uraldog's Avatar
Oddometer: 405
hey Spicey , get youself a can of spray oil [not WD 40 ] and spray all the welds and any where two or more pieces of metal come together [ you really should have done that before riding in the calcium ] this will help delay the rust and corrosion factor till you can strip and repaint --the paint on the Retros aint to good either, that was one bitch I've had from day one too
uraldog is offline   Reply With Quote
Old 06-29-2008, 11:12 PM   #5
P B G
Oddometer: 10,001
POR 15, the stuff works great.
I use it alot on car frames, where anytime i'm under and I see a spot of rust I wire brush till nothing is loose, por 15 primer, followed by rubberized frame paint for aesthetics.
On a bike, i'd wire wheel rust, por 15, then paint of choice. As mentioned if you really want long term paint you'll need to redo it. Powdercoat is more durable for offroad environment.
Old 06-30-2008, 05:08 AM   #6
redflasher
Baltika Lover
Oddometer: 150
Anything that isn't painted will rapidly corrode also. I don't know if it is zinc plated or what but everything on my GearUp that isn't chrome-carb tops, caliper mounting, 2wd rod, etc have been etched by a few exposures to Minnesota winter salt.
And the chrome ain't that great either.
Bob in Minnesota
2006 GearUP
redflasher is offline   Reply With Quote
Old 07-01-2008, 10:30 AM   #7
SandHog
SandHog's Avatar
Oddometer: 97
Here in Florida the salt air seems to attack any surface not thick with piant. I have been slowly picking at the Patrol with OD Rustoleum every time I work on something. I found the front fender starting to rust through. Green is good...At least you don't have to sand down the Rooskie Chrome before painting.
'07 Ypan патруль/Gear-up
'88 BMW R100 GS Bumble Bee
SandHog is offline   Reply With Quote
Old 07-01-2008, 02:17 PM   #8
MooseKiller
Tripod
MooseKiller's Avatar
Oddometer: 4,604
Anyone use RhinoLiner (or similar such bed liner type thing) to "repaint" their Ural? I'd figure that would be the best upgrade...
I used to be an adventurer like you, until I took a Hyundai to the knee...
MooseKiller is offline   Reply With Quote
Old 07-01-2008, 05:35 PM   #9
Spicy McHaggis OP
Oddometer: 3,789
I'm going to do the Herculiner bed liner stuff on the inside of the car...might do it on the bottom of it as well...
Old 07-01-2008, 08:34 PM   #10
LadyDraco
KillerSmileIHazIt !!
LadyDraco's Avatar
Oddometer: 29,988
I'm get ready to put that stuff on my Trikes Fenders...
My fenders chip big time ....
TISE
Life is what you make of it~If it don't fit make alterations
Check it from time to time as I'm always adding to it..
My Rides and life on the Farm
Just because the road is rocky doesn't mean your spirits should get rocky, too.{Crazy Cora}
LadyDraco is offline   Reply With Quote
Old 07-01-2008, 09:18 PM   #11
frederickflintsone
Flaming Misanthrope
frederickflintsone's Avatar
Oddometer: 36
insulting testors
you are realy insulting testors model paint by associating it with ural paint.
testors works quite well on plastic.
the company I work for is building a plant in russia, and the horror stories I am hearing from my co workers going there, you just wouldnt believe. the quality that they get in everyday goods is far less than the quality of the cheap chinese goods we get at walmart. having worked in the auto engineering field, I have a grasp of production costs, and I just cant justify any reason for the list price of a 2008 gear up to be as high as it is.
they are charging a super premium price for a sub-standard product.
back from the dead
2002 MZ 660 streetmoto,
2000 KTM exc520,
yamaha 660 raptor atvr
frederickflintsone is offline   Reply With Quote
Old 07-01-2008, 09:36 PM   #12
Spicy McHaggis OP
Oddometer: 3,789
While I agree with you in principle, I will defend the Urals and their newer, higher costs.
Other than a few "minor" issues, it is not a sub-standard product. German made gears. Nippon-Denso alternator (770 watts, baby!!!). Keihin carbs. Brembo disc brake up front. Ducati ignition system.
And the #1 reason they can justify the higher price - they are the ONLY gig in town that makes motorcycles as sidecars from design to finish. With 2-wheel drive. And reverse.
The supply has always been lesser than the demand. To my knowledge, they haven't had problems selling every moto they've brought into the US of A.
Would I pay the additional price? Damn right I would.
Now...if they would just find some better paint...!
Old 07-02-2008, 12:53 AM   #13
Ivan Rider
Ivan Rider's Avatar
Oddometer: 605
Yep. I've had Rino Liner and LineX along with the paint your own type from Pep Boys. LineX has a ruffer finish, only comes in Black but is not bothered by Gas spills. Rino comes in any color you want and has a smoother duller finish but is affected by Gas spills. The paint your own is much cheaper but didn't look near as good. I prefer LineX.
I've 6 rigs done on the inside and one done inside and outside. It works great and makes them indistructable inside.
Ivan Rider screwed with this post 12-11-2010 at 10:01 AM
Ivan Rider is offline   Reply With Quote
Old 07-02-2008, 06:21 AM   #14
frederickflintsone
Flaming Misanthrope
Oddometer: 36
supply and demand
this is the only reason they are still selling now.
with the caveate that I dont own one, I still say they are an inferior product and not up to world standards, part of there apeal is the nostagia. they make a modern 1950's bike.
HD makes a wonderful 1940's bike and they also sell everyone they make.
compare a $14,000 (msrp) ural to a $17,000 (msrp) BMW GS and there is realy no comparision (sidecar asside). the BMW GS has taken 1930 engine design to well beyound modern world standards.
when your pike is paid for, strip it down, have all the metal sandblasted then spray it with an epoxy primer. (uesualy a gray-green) to start and then get out the flat camo paint and go to town
back from the dead
2000 KTM exc520,
Old 07-02-2008, 09:50 AM   #15
chappy
Porkchop Sandwiches
chappy's Avatar
Oddometer: 1,910
While I was more interested just a few years ago when a Patrol was more like $10k instead of $14k I would still get one if I had the extra cash now. I think the fun I would have would far out weigh what I was paying.
HD's bike are not faithful reacreations of the bikes they mimic the way the Ural and Royal Enfields are but then the HD probably is way more reliable. If you are buying a Ural expecting it to be a HD type experience you would be heading in the wrong direction I would think.
I agree it would be nice if someone would make a modern bike designed as a hack rig but it probably will never happen.
P.S. Do the Ural's have the $17k dollar BMW's final drive issues
chappy is offline   Reply With Quote
Times are GMT -7.   It's 04:51 PM.
