Old 07-13-2008, 06:18 AM   #1
Phred OP
Oddometer: 128
Too big for Ural
Well, I went and sat on one (gear up) yesterday...and I think I'm too big.
I'm 6'3, 250.
I also had trouble with fitting my right foot between the bottom of the carb and the peg. And this was in sneakers...I didn't even have my boots on.
The seat was low so my legs were quite folded to get the proper foot position on the pegs.
Is there anyone out there who is my size that can offer an solutions?
I've always wanted one...and now have the means to purchase...I was discouraged.
____________________________
2009 Metallic Silver Honda Goldwing
2008 Magnesium Metallic BMW R1200GSA
2007 Silver Flamed Yamaha Roadstar 1700
Phred is offline   Reply With Quote
Old 07-13-2008, 06:33 AM   #2
princess jamaica
OLD DOG-NEW TRICKS
princess jamaica's Avatar
Oddometer: 2,257
i'm sure the seat could be raised,or swap out the tractor seat for the bench seat.someone here will know!
24 hours,maybe 60 good years,it's really not that long a stay.........jimmy b.
princess jamaica is offline   Reply With Quote
Old 07-13-2008, 07:04 AM   #3
KrazyKonrad
Will BBQ for Gas Money
KrazyKonrad's Avatar
Oddometer: 134
I'm 6'4" and 270 and have no problem with the Tourist (same as Patrol) bench seat. Tourist Patrol seat is 32" and Gear Up Tractor seat is 30.9". You don't have the option of scooting back on a tractor seat which is no problem on the Tourist & Patrol bench seat. I took one look at the Gear Up Seat and decided it was not for me.
The web seat height specs are all wrong. The correct specs are here
http://www.imz-ural.com/downloads/br...08Brochure.pdf
Krazy Konrad
Ural'ing South African Pitmaster
1998 Tourist
KrazyKonrad is offline   Reply With Quote
Old 07-13-2008, 07:17 AM   #4
Phred OP
Oddometer: 128
So...can I swap out the Patrol seat onto the Gear up??
Any ideas about the foot position on the right side? The top of my foot hits the bottom the carb when I rest my foot on the peg. I also find I have to turn my foot out to hit the rear brake. I asked if they had it set up right and the sales dude said it was. Does this sound right?
Old 07-13-2008, 08:00 AM   #5
eastbloc
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,351
Yes you can swap out the seats, also you can get a Rich Maund 'road sofa' type saddle. He makes them for Urals specifically. They're huge, made for American-sized asses
eastbloc is offline   Reply With Quote
Old 07-13-2008, 08:47 AM   #6
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,264
You may be able to modify the foot peg position a little, but the right side gets a little complicated because moving the foot peg affects where the brake pedal ends up. I haven't messed with the foot pegs on a new Ural- it may require a torch and some ingenuity.
Foot room is a common problem on Urals(and older BMWs for that matter). Often it it more a matter of getting used to it than actually needing more room. I was reminded of this when Arno let me ride his GS rig yesterday. You might need a little more time than just a single test sit to get the feel of it. See if you can find someone near you with a Ural fitted with a bench seat and give it another try(or two)
On the subject of bench seats-Ural has made a number of versions. I like the older really firm upholstery. Some of the soft bench seats they've made are no better than the tractor seats in my opinion. You sink into them and are afforded little or no real increase of seat hieght and are not able to easily slide back on them once seated. You can easily have a bench seat upholstered to give you the height and feel that works best for you.
" I need to stop talking and start drinking" ...Mom
RedMenace screwed with this post 07-13-2008 at 09:07 AM
RedMenace is offline   Reply With Quote
Old 07-13-2008, 08:55 AM   #7
Phred OP
Oddometer: 128
Well...this gives me new hope...thank you all.
Old 07-13-2008, 09:32 AM   #8
Uncle Ernie
Uncle Ernie's Avatar
Oddometer: 3,978
Rich's solo seats are unbeliveably wondrous. Possibly the best I've seen.
However, he's so back-ordered, you may want to build something out of 2x4's and an old couch cushion in the interim. A little paint and it will look right at home.
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 07-14-2008, 08:49 AM   #9
Jonniedee
Jonniedee's Avatar
Oddometer: 513
Mike at Wagner's has a simple seat adjustment/modification that he does durning customer set up that will easily add the leg room your looking for:
http://www.wagnerscycle.com/
Jonniedee is offline   Reply With Quote
Old 07-14-2008, 02:01 PM   #10
kjolly
kjolly's Avatar
Oddometer: 74
I'm 6' and 275 - with big old size 13's - and there was an adjustment period to get used to where and how to wedge my right foot down between the cylinder, the carb , and the brake - but really - didn't take long to get used to it.
I've ridden the tractor seat since day 1 - really quite a bit you can futz with there to move the seat up and back. I'm using a German made solo saddle now - which is wider and longer than the stock Ural tractor seat. I find it perfectly comfortable.
http://www.kevin_jolly.com
"If a hammer doesn't fix it you have an electrical problem"
Kevin Jolly
2006 Ural Patrol
kjolly is offline   Reply With Quote
Old 07-14-2008, 03:25 PM   #11
Uncle Ernie
Oddometer: 3,978
Hey- come back here! What seat? Where're the pictures? Links / catalogue?
Old 07-14-2008, 07:44 PM   #12
bvardi
Probably not Deciduous
bvardi's Avatar
Oddometer: 298
I'm 6'3, 250.
I'm almost 6'2 - size 11 shoes. My dealer (OVC in hillsburgh, ON) setup the tractor seat to be higher than stock (he just used some steel stock to make a spacer plus some extra long bolts on the seat and then doubled up on the rubber mounts - works well)
He also setup a little luggage rack with a square buddy seat at the same height - more of a classic look, but it gives some of the advantages of a bench seat while keeping the tractor seat up front. (but you can still scootch back a few inches)
I'd probably be fine with a bench seat, or even the tractor seat at stock height - but the extra couple inches do help I think.
The spacing on the brakes and shifting took a bit of getting used to - but no problems after a bit of riding.
Member, Canadian Sidecar Owners Club (CSOC)
Member, CURD (Canadian Ural Dnepr Riders)
bvardi is offline   Reply With Quote
Old 07-16-2008, 02:47 PM   #13
YellowstoneBen
YellowstoneBen's Avatar
Oddometer: 57
Size
I am 6'6" and 265 dry. I wear size thirteens and I don't have any issues. You will find that your foot is usually back on the peg or on the sidecar rail and rarely under the carb so much that they contact. I have the bench seat which is nice but I converted to the solo tractor seat and added an extra rubber spring to it for strength. I have ridden my all over the western US. I wouldn't let an initial test fit get you down, I had the same issue one witha tourist at an IMS show in atlanta when I spoke with the IMWA guys there.
YellowstoneBen is offline   Reply With Quote
Times are GMT -7.   It's 08:43 AM.
