Old 12-05-2009, 01:56 AM   #5161
BigBat
Dakar Wannabee
BigBat's Avatar
Oddometer: 12
Originally Posted by nave
welcome BigBat :)
your bike look astonishing and i bet it sounds amazing!
just one thing- when going off road the rear wheel will touch the exhaust...
sometime my rear wheel reachs the top off the mud guard!
great job!!!
Thank you all for your kind response to the LOOK of my bike! I just had to mount that can, part because it was dirt-cheap, part because its huge, part because it sounds formidable! I know, that rearwheel travel is a big issue. But since I mainly use bike for comute, half of that on good and flat dirtroads, its not a problem. However, I am changing that a bit. Right now the bike is getting stainless exhaust pipes all the way from the front by a skilled welder I know, and he is fiddling with the mount of the can under the seat, so that I should get an extra couple of cm there.
Another thing is the rear shock and spring. I have not been able to find anything usefull. The original is a bit too soft, and because of the exhaust, I need something that can be adjusted to get more wheeltravel. Any sugestions?
BigBat is offline   Reply With Quote
Old 12-05-2009, 02:10 AM   #5162
mousitsas
Oddometer: 2,147
I have put an EMC shock on my bike which performs well and is slighly longer than stock (about 5mm). I think also that wilbers can supply shocks with adjustable ride height. But the cheap soltion if you want to retain your standard shock would be to go for a stiffer spring and get new dogbones which will raise the bike height.
What is your connection tube from header pipe to exhaust made from? It looks like something flexible...
Old 12-05-2009, 02:13 AM   #5163
BigBat
Dakar Wannabee
BigBat's Avatar
Oddometer: 12
Thanks for the tips! That flexible middle part on the exhaust is standard flextube for car-exhaust. Not so sturdy, and thats why I am having both that and the header pipe custom made in stainless steel.
Old 12-05-2009, 02:28 AM   #5164
mousitsas
Oddometer: 2,147
In one of the very early posts in this theard (or in the 'suzuki dakar bikes' thread) someone said that a full exhaust system made from 2 inch tubing resulted in close to 60hp on the back wheel with standard carbs jetted properly. I'm going that route myself pretty soon.
Old 12-05-2009, 03:01 AM   #5165
Bambi
Bambi's Avatar
Oddometer: 487
Hi BigBat,
if you're able to read and write the German language, have a try at www.dr-big.de. This is our forum for the Big and it's also very much alive!
Cheers, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 12-05-2009, 06:48 AM   #5166
nave
Nave
nave's Avatar
Oddometer: 351
rear shock- WILBERS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
nave is offline   Reply With Quote
Old 12-05-2009, 11:01 AM   #5167
i8lusaka
Guest
Oddometer: n/a
Just back from the garage
The transformation has begun.
I am in the proces of striping my Dr 800 1997 from unnececery over waight and some more crach friendly plastic for next seasons trip and the Africa trip 2011.
some pics of how it will look like when it is finiched but I dont know what to do with the rear at the moment.
i8lusaka screwed with this post 12-05-2009 at 11:19 AM
Old 12-05-2009, 11:08 AM   #5168
i8lusaka
Guest
Oddometer: n/a
this is how it will look like plus some more ad ons like acerbis hand proteectors and a new digital clocks
Old 12-05-2009, 11:18 AM   #5169
i8lusaka
Guest
Oddometer: n/a
some left over to be sold doet any one have any clue what it is worth and where to advertise
I am in Sweden so not so many Dr 800 around
Old 12-05-2009, 11:18 AM   #5170
i8lusaka
Guest
Oddometer: n/a
and some more
Old 12-05-2009, 11:50 AM   #5171
BigBat
Dakar Wannabee
BigBat's Avatar
Oddometer: 12
Originally Posted by Bambi
Hi BigBat,
Cheers, Bambi
Yes, I found that earlier, but my German is hopeless... too bad.
Old 12-05-2009, 12:13 PM   #5172
mousitsas
Oddometer: 2,147
Have you got the acerbis tank part number handy?
Old 12-05-2009, 12:46 PM   #5173
i8lusaka
Guest
Oddometer: n/a
here you are http://www.acerbistore.it/product.aspx?ID=61&C=110&L=2
Old 12-05-2009, 12:50 PM   #5174
mousitsas
Oddometer: 2,147
Originally Posted by i8lusaka
many thanks!
Old 12-05-2009, 12:59 PM   #5175
i8lusaka
Guest
Oddometer: n/a
many thanks!
fitts like a gluv
Times are GMT -7.   It's 02:05 PM.
