Old 03-29-2010, 06:26 PM   #6571
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,018
im almost sure that the bike shouldnt run on 0 turns out on the mix screws so im guessing some sort of issue with choke plungers?
It sounds like you were way too rich before.
If that's the case, your shaft seals should be OK since leakage here will give you a lean condition. With the better flow from filter and pipe, I'd expect you to have to turn idle mixture out past what is normal.........
.........so..............
..............somehow fuel is bypassing the idle circuit of the carb. The only way I know that this is possible is through the "choke" (really enrichening pathway) circuit.
Normally, there are small black seals on the ends of the choke plungers. If those are missing, or cracked, fuel may be bleeding by. If there is dirt between the plunger and the carb, the seal will be bad and the "choke" will be partially open.
I'd certainly look at "chokes" first.
Hope it works.
Ladder106 is online now   Reply With Quote
Old 03-29-2010, 06:30 PM   #6572
Simon M
Simon M's Avatar
Oddometer: 87
Hi Brendan, I have a better idea. I'll assemble my BIG and ride over for you to have a look at it in August. I'm preping the bike for a trip across Oz from Perth to Melbourne, or Sydney, covering as little bitumen as possible. We are going to follow the Trans Line to Glendambo, but not to sure where from there. Sound like fun? Simon.
Simon M is offline   Reply With Quote
Old 03-29-2010, 06:32 PM   #6573
Ladder106
Ladder106's Avatar
Oddometer: 5,018
Wait...........
Fuel in the bowl is ABOVE the gasket surface.
I don't think this is correct but I may be wrong. If you set the floats per the manual I THINK you'll get a fuel level well below the gasket surface. If the fuel level is too high, you'll just be pouring fuel into the intakes.
How did you measure the fuel height in the bowls.....dunno what +1 over gasket means.
Old 03-29-2010, 07:03 PM   #6574
Brendan J
ONE HACK AT A TIME
Brendan J's Avatar
Oddometer: 1,562
If the float heights are set too high this will lead to a rich running condition regardless of what pilot jet you are using. Too low will lead to a lean running issue. I always set float heights in respect to manufacturer specs and have never had a problem with doing it this way. I do use a special tool from Honda that measures float height.
Simon that sounds like a date to me but I will be hopefully at the Off Centre Rally in August keep me posted on some dates and I'll see if we can catch up. And some photos of your progress of the bike would be good !!!!!!!!!!!!!!
Brendan J is offline   Reply With Quote
Old 03-30-2010, 05:52 AM   #6575
jabroka
jabroka's Avatar
Oddometer: 338
Hope it works.
ill take a look..i think that might be the problem too. as you said, I think it already had a rich condition that was covered by the air leak through the shaft seals.. now that the seals are not leaking, its horribly rich .. also.. b4 changing the seals the plugs where brownish.. now theyre really black..
side note: i just drove the bike to work with 0 turns outs on the pilot screws.. it idled pretty good and no backfiring at first... came to a stop, downshift and began backfiring horribly and tried to stall.. next stop, no backfiring again.. idled perfectly.. should i call an exorcist?
jabroka screwed with this post 03-30-2010 at 06:06 AM
jabroka is offline   Reply With Quote
Old 03-30-2010, 05:58 AM   #6576
jabroka
jabroka's Avatar
Oddometer: 338
1mm avobe bowl gasket surface.. thats where thee fuel level is after i set the float height 14.9mm as the manual says.. also HERE says that 1mm over gasket surface is about the correct fuel level..
am i doing something wrong?
jabroka screwed with this post 03-30-2010 at 06:32 AM
Old 03-30-2010, 08:32 AM   #6577
Ladder106
Ladder106's Avatar
Oddometer: 5,018
Thanks....I remember seeing that now. I've just never done that measurement before. Good information.
OK, so if the floats are good, I'd go back and look at the chokes.
Also make sure the carbs and the rubber seals/boots between the head and carbs are assembled correctly and not cracked or leaking. The common tip is to spray WD40 around the sealing areas and watch for white smoke out the exhaust if any of it gets sucked into a crack. Also idle speed will change.
Are you sure the idle adjusting screw was assembled correctly. Firs the screw, then spring, tiny washer, O-ring last. Is the O-ring in good shape? Taper on the brass screw is a constant angle and not notched from being overtightened into the carb body?
Just trying to shoot questions as you as reminders for things to examine.
Old 03-30-2010, 09:07 AM   #6578
bluesman
Oddometer: 3,355
TBH all bases covered I think by Ladder106, but just to add more questions :)
You mentioned both idle screws if I am not wrong - does it means that you actually drilled out plug that covers screw on second carb and if so - did you attempted to synch carbs?
Also which method you used to adjust idle? The one when you look at right spot by turning mix screw in direction that causing rpms to go up at beginning and then finding points where rpms go up and then start to go down again?
bluesman is offline   Reply With Quote
Old 03-30-2010, 09:36 AM   #6579
jabroka
jabroka's Avatar
Oddometer: 338
i think all parts are in correct order and in place but ill recheck all that.. ill let you know as soon as i have time to work on the carbs.. TNX!
Old 03-30-2010, 09:57 AM   #6580
jabroka
jabroka's Avatar
Oddometer: 338
there were no plug/cap on the 2nd carb.. my bike is marked as an E6 (31D00 on carbs) .. maybe E6s dont come with capped mix screws? my friend who also has a dr800 (an E6 too) dont have plugged mix screws either..
i set the screws at 1 3/8 turns out (both as the manual says for other models) thinking i should go richer with my intake/exhaust setup and it idled but very rough.. plugs were very black.. fuel level steady at 1mm over gasket surface (with engine on or off, no difference) dark smoke if i blipped the throttle.. another 1/4 turn in, same tests, same results, and so on, till i ended at 0 turns out for both mix screws..
idle is way more steady than b4 but still not perfect.. to my understanding bike should backfire very bad at 0 turns out or even not idle at all.. well, thats not the case.. not always at least.. as i said b4, when riding the bike on the street, at some stops it backfires very bad (as its supposed to with that mix screws setup) and at some other it just idles fine, no backfires.. also.. mid range is just fine.. no problems.. I couldnt test WOT here we have 60km/h top speed limit on the streets..
jabroka screwed with this post 03-30-2010 at 10:06 AM
Old 03-30-2010, 10:03 AM   #6581
zappa71
60.000 km BIG fun
zappa71's Avatar
Oddometer: 101
Bit simple maybe but the gaskabel is not to tight ?
And the idle adjustment screw can go down as much as needed?
That one falls in a other bolt, when that one is set to high you can't lower the idle adjustment screw then the hight of that bolt..
Could also be air leaking, do check the edge of the air box and the intake rubbers, when to tight it cracks open, best to seal it there with silicone..
Also put some grease between air filter and air box.. it will leak fine dust there when you don't..
Don't cry, you can fix it.....
zappa71 is offline   Reply With Quote
Old 03-30-2010, 10:20 AM   #6582
jabroka
jabroka's Avatar
Oddometer: 338
nope, its ok with plenty of slack.. and its brand new too.
im gonna check that too.. maybe i made some mistake when assembling the mix screw+spring+washer+oring and thre not sitting propperly..
But if it was an air leak, shouldnt it have lean symptoms instead of rich?
already done that, thanks for the tip anyway ;)
Old 03-30-2010, 12:41 PM   #6583
zappa71
60.000 km BIG fun
zappa71's Avatar
Oddometer: 101
Yip, it shoud, it's a long shot.. but a engine running lean runs harder until...
But i,m puzzeled.. a choke problem shoud stall your engine when hot..
Try asking here..
http://www.drbig.info/forum/
Old 03-30-2010, 06:28 PM   #6584
ausibatla
ausibatla's Avatar
Oddometer: 448
Does anybody live near Cologne or around this area... Die Teile sind nur fr Selbstabholer. Kein Versand. Standort ist: 56593 Pleckhausen, etwa 70Km sdlich von Kln, etwa 130Km nrdlich von Frankfurt a.M. direkt an der A3 Abfahrt 36.
I want to bid on some stuff but the seller wont ship. It's pick up only.
Anyone able to help or offer advice. .......proper advice.......
Cheers.
Youth's a mask but it don't last
Live it long and live it fast
'88 Harley Davidson Springer '91 DR 800 '95 Yamaha XV1100
ausibatla is offline   Reply With Quote
Old 03-31-2010, 12:25 AM   #6585
aapo
aapo
aapo's Avatar
Oddometer: 164
How do you measure the fuel level. Old float assemblys could get stuck. I had this problem. Once you have cleaned carbs an put them back together, there is a change that those float assemblys arent working because worn parts are litle different places than before. And if you had the old float valve dissassembled it might cause rich mixture also by leaking. Float not working proper way or worn out float valve lets too much fuel in to fuel chamber and then this fuel leaks in to the carb through needle valve.
I measured the fuel level with trasparent tube attatched to the drain plug at the bottom on carburetor like here
http://home.arcor.de/avehrenb/DR800maintenance.html
and found this problem. One of my carbs was leaking.
-aapo
-aapo
DR 750S 1989
http://picasaweb.google.com/aapo.saari
aapo is offline   Reply With Quote
Times are GMT -7.   It's 06:15 PM.
