Old 06-22-2010, 07:18 AM   #7486
robmoto
robmoto's Avatar
Oddometer: 3,835
Originally Posted by bluesman
oops - forgot photo
Yes much stronger really at the back behind the seat area which I like for ADV riding and could really load her up.
robmoto is offline   Reply With Quote
Old 06-22-2010, 07:23 AM   #7487
robmoto
robmoto's Avatar
Oddometer: 3,835
DR 750 rebuild
Old 06-22-2010, 07:27 AM   #7488
robmoto
robmoto's Avatar
Oddometer: 3,835
DR 750 rebuild
Old 06-22-2010, 07:36 AM   #7489
robmoto
robmoto's Avatar
Oddometer: 3,835
Hey Bluesman, I wound the preload adjuster to halfway with the special spanner thingy and it felt like heaps when you have the time no rush now but just by site roughly where is yours set, thanks.
The original spring was compressed to the max no more thread left at all
Old 06-22-2010, 09:13 AM   #7490
bluesman
Oddometer: 3,303
Mine is appr. 12-15 mm from the top of thread, but that's different shock absorber.
Let me better give you overall spring lenght in current state, all preloaded to perfect sag. Spring rated for 95 kg of load (I specially asked for a bit stiffer spring to accomodate me, gear and luggage and occasionaly wife as passenger): 240 mm
Wire diameter also 12 mm.
Stock DR spring I have (one that did not sag but lost some of stiffness) is 255 mm and 10 mm wire.
That's for SR43 of course.
bluesman is offline   Reply With Quote
Old 06-22-2010, 09:17 AM   #7491
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,957
ORANGE
Wow. The old Texaco/Marlboro colors look great.
Rob, you're a painting genius
But as for photography, I wish you'd focus a bit since I could not finish the football article on the newspaper. Try to do better, OK ?
Ausibatla,
Orange and blue is a good combo. Mine's the other-way-round......and dirtier (for counter-point)
Ladder106 screwed with this post 06-23-2010 at 12:06 AM
Ladder106 is offline   Reply With Quote
Old 06-22-2010, 10:51 AM   #7492
DrBigEd
DrBigEd's Avatar
Oddometer: 695
Rob, like always, stunning work. I wish you lived around the corner - I'd be there every other night watching and learning...
Keep up the good work.
"For long you live and high you fly
And smiles you'll give and tears you'll cry
And all you touch and all you see
Is all your life will ever be"
BREATHE
Dark side of the moon
Pink Floyd 1973
DrBigEd is offline   Reply With Quote
Old 06-22-2010, 11:37 PM   #7493
Simon M
Simon M's Avatar
Oddometer: 87
Frame strength
Hi guys,
I'm building an off road tourer out of my 1988 750 (SR41?). This will include Gobi panniers, upgraded suspension etc. Has anyone beefed up their SR41 frame to later specs? If so I'd love a list of where to brace and some templates for the braces if available. To all the "keep it standard" crowd, I'm keeping all the stock bits and will restore my BIG when I'm finished.
Robmoto: Love the orange paint. Mine will get a coat of that for sure.
Bluesman, Hmmmm, a frame up rebuild! Lots of work, but I'm sure the end result will be awesome.
Cheers,
Simon M.
Simon M
82 Husky AE420 85 Suzuki Katana 1100 88 Suzuki DR750
07 Triumph Speed Triple 08 Yamaha WR250F
12 Moto Guzzi Stelvio NTX
Simon M is offline   Reply With Quote
Old 06-23-2010, 12:20 AM   #7494
bluesman
Oddometer: 3,303
Originally Posted by Simon M
Hi guys,
Cheers,
Simon M.
It was done 2 years ago... since that time I finished modifying my DR twice
I have different approach to rebuild - my DR kept in old tatty and scratched plastics, no shiny parts - all is painted or brushed or...not washed
The principle was to build a "sleeper" and not to be worried about scratching plastics when offroading as I am beginner offroad and want to be not afraid to drop it. You probably noticed well worn crash bars. So basically I got now DR with fully tuned WP Extreme 50mm front forks, Beringer 4 piston brake, full adjustable twin-circuit Wilbers shock, titanium ex-Benelli Arrow exhaust with self-made link pipe,self-made minimialistic dashboard with Trailtech panel, modifyed crashbars, GPR handlebar with aluminium handguards, self-made MX type chain guide, custom pannier frames, upjetted carbs and improved air flow, 2 sets of interchangeable wheels (supermotard and offroad sizes), self made upper chain deflector,customized inertia valve chain oiler and some small bits and pieces.
But it still looks similar to it was when I bought it. 15000 km since finished last stage of modifying. No single hiccup and brilliant handling.
Here is more details:
http://s490.photobucket.com/albums/r.../MyDR800Feb10/
About bracing - give me your email address (via PM) and I will send you all photos of stripped and painted frame of my SR43A. SR43 frame is heavily braced comparing to SR41 in headstock, upper duplex joint, rear part of frame, triangle, across etc. All you will have to do is to do similar things to 750 frame. Why not to use Suzuki engineers brain when we can ?
Old 06-23-2010, 01:28 AM   #7495
robmoto
robmoto's Avatar
Oddometer: 3,835
Thanks bluesman for the info, I will leave the setting at the middle of the theaded section for now and wait till bike is all together then check the static preload which I believe should be should be 20/25 percent sag.
Ray if the glear is to much just move back 2 foot from the computor and it looks better .
Big Ed, forks going in tonight.
Old 06-23-2010, 03:06 AM   #7496
Okta
rooky
Okta's Avatar
Oddometer: 62
Hello advrider.com BIG forum, happy 7500!
I was inspired by this project:
http://www.advrider.com/forums/showthread.php?t=73630
So I did this:
http://www.endurocross.hu/motoros_kepek/enduro/?dr=34665
(Start with the first pic and then click on the arrow:
http://www.endurocross.hu/motoros_kepek/enduro/?dr=34665&cmd=pic&id=459154)
Differences: no mechanic knowledge, no correct tools and no money. So I call it "economy-style".
Don't you worry, I have all original plastics packed into boxes...
The thinggy on the front lamp? This a military stuff - you know in the past almost all socialist vehicle had the same diamater of the front lamp. This is an old MZ-lamp on the bike, so it fits on it.
Like this:
http://luaz.mindenkilapja.hu/?m=3617683#/html/18630753/render/alkatresz-loose-part
http://luaz.mindenkilapja.hu/?m=3617683#/html/18630282/render/luaz-967-type
Okta
www.drbig.hu
Okta is offline   Reply With Quote
Old 06-23-2010, 03:24 AM   #7497
bluesman
Oddometer: 3,303
Could not resist :) Okta, thanks for heads up!
Happy 7500 everyone!
Okta, I know it's wrong...but I like it! Specially all setup over headlight and on top of it.
Old 06-23-2010, 04:05 AM   #7498
DrBigEd
DrBigEd's Avatar
Oddometer: 695
No probs. Always keep looking to see if I can see your work.
Keep up the good fight
BREATHE
Pink Floyd 1973
Old 06-23-2010, 04:20 AM   #7499
Chanterman
Oddometer: 299
DR 750 rebuild
I reckon another stunner from you Rob , looking well
Chanterman is offline   Reply With Quote
Old 06-23-2010, 05:52 AM   #7500
robmoto
robmoto's Avatar
Oddometer: 3,835
Originally Posted by ausibatla
Just a couple of shots of the new project. Couldn't resist painting the rocker inspecrion covers orange other wise it will be as original as I can make it. Will post more pics as parts arrive (or get painted) and added.
Cheers.
Sorry Lioyd, I missed your pics its looking great we both are doing resto,s to the same model teriffic job old son.
Times are GMT -7.   It's 10:04 AM.
