Old 06-23-2010, 05:33 AM   #7501
robmoto
robmoto's Avatar
Oddometer: 3,857
big Ed, and Steve, I got the forks in orange on the lower legs but forgot to get the dam fork oil on the way home bugger bugger bugger.
robmoto is offline   Reply With Quote
Old 06-23-2010, 08:25 AM   #7502
jabroka
jabroka's Avatar
Oddometer: 338
short vid
short vid of my big with scorpion Ti flame exhaust.. the cam is not the best so the sound is a little deeper and not that loud in real life, but youŽll get the idea .. hope u like it!
http://www.youtube.com/watch?v=3OX5IJwqP2c
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka is offline   Reply With Quote
Old 06-23-2010, 10:51 AM   #7503
Rajni
Gabor
Oddometer: 11
HI Okta,
Nice to see you here, your bike is bit weird, but it is very unique so well done...:)))
I like Vesa front fender, but I am afraid to say that in the Hungarian forum, I think they would kill me for it:))
Go on Mate all the best!
I haven't write anything for a while, but I am still reading Guys!!!!!
Nice paintwork Robmoto, I wish I could do the same.....
Cheers
Gabor
Originally Posted by Okta
Hello advrider.com BIG forum, happy 7500!
I was inspired by this project:
http://www.advrider.com/forums/showthread.php?t=73630
So I did this:
http://www.endurocross.hu/motoros_kepek/enduro/?dr=34665
(Start with the first pic and then click on the arrow:
http://www.endurocross.hu/motoros_kepek/enduro/?dr=34665&cmd=pic&id=459154)
Differences: no mechanic knowledge, no correct tools and no money. So I call it "economy-style".
Don't you worry, I have all original plastics packed into boxes...
The thinggy on the front lamp? This a military stuff - you know in the past almost all socialist vehicle had the same diamater of the front lamp. This is an old MZ-lamp on the bike, so it fits on it.
Like this:
http://luaz.mindenkilapja.hu/?m=3617683#/html/18630753/render/alkatresz-loose-part
http://luaz.mindenkilapja.hu/?m=3617683#/html/18630282/render/luaz-967-type
Rajni is offline   Reply With Quote
Old 06-24-2010, 12:46 AM   #7504
HLK
aka Hielke
Oddometer: 141
Originally Posted by bluesman
And I used similar to RickyCross mount system - I cut of flat long pieces off upper bar, made simple mounts on them and made from scratch a cross-piece they bolt to, and that cross-piece mounts similarly to Ricky cross. It has piece of 5 mm steel plate welded to it, 2 holes drilled in it and large clamp (one they sell for satellite TV dishes mounts in Brico/Gamma) goes from inside bike, through those 2 holes in plate and just fixed with nut. I also slid piece of plastic tube onto clamp, so that it does not rub paint of frame off.
Ah, the secret unveiled: Bluesman uses trained sheep for quality control! Thanks for the tips.
Yesterday: left the *** parking light on for three hours - battery dead. Try bump starting an 800cc single All I did was create tire marks, even in fourth gear. Found a friendly cager with starter cables, blew one of the fuses (I think starter/ignition circuit), replaced it with headlight fuse, stalled the engine, again the cables, turned up the idle, took the long way home to get some charge in. This morning it started, but I'm replacing the battery anyway.
Also had to adjust the head stock bearings. According to the previous owner it's as good as new...but I guess he didn't re-adjust them properly after installing.
Did you guys ever manage to bump start the BIG? Maybe with the manual deco?
1996 Suzuki DR650SE
HLK is offline   Reply With Quote
Old 06-24-2010, 01:04 AM   #7505
ztaj
jatz
ztaj's Avatar
Oddometer: 970
Not tooo hard with the manual lever, doesn't work to well with big knobblies and wet seal though
Got one indicator (musta smashed the rest ) and a tail light Ausi, I'll stick em in the post this w/end
ztaj is offline   Reply With Quote
Old 06-24-2010, 01:07 AM   #7506
robmoto
robmoto's Avatar
Oddometer: 3,857
Jabroka, she has got a nice bark sounds good to me.
I really like the paint and colours of your bike and goes well with the stainless exaust a very nice bike indeed.
Old 06-24-2010, 03:50 AM   #7507
ausibatla
ausibatla's Avatar
Oddometer: 447
Got one indicator (musta smashed the rest ) and a tail light Ausi, I'll stick em in the post this w/end[/quote]
You're one of natures true gentleman, mate. Please let me know what I owe you.
Cheers.
Youth's a mask but it don't last
Live it long and live it fast
'88 Harley Davidson Springer '91 DR 800 '95 Yamaha XV1100
ausibatla is offline   Reply With Quote
Old 06-26-2010, 02:40 AM   #7508
Brendan J
ONE HACK AT A TIME
Brendan J's Avatar
Oddometer: 1,560
Bumpty bump its depressing having this thread on the 4th page ! Anyway its slow progress on my 800 trying to mount up a double headlamp setup at present and wire up a cigarette lighter socket and gps.
Brendan J is offline   Reply With Quote
Old 06-26-2010, 03:02 AM   #7509
chris3155
chris3155's Avatar
Oddometer: 249
Hi all,
Brendan I'm considering the same myself.what are ya thinking, doing?
I think I know what I want, I am thinking of 2 round ,one HID white and the other as a led replacement to shine yellow for daytime.With a long led light horizontal under both to look conspicuous to other road users.
Probably will look fuc&ed up but in me head it looks great. I just havent got the courage to start the stripping yet as time is precious and I know I would have no lights for ages until its done.
Chris
chris3155 is offline   Reply With Quote
Old 06-26-2010, 03:29 AM   #7510
Brendan J
ONE HACK AT A TIME
Brendan J's Avatar
Oddometer: 1,560
G'day Chris I'm using the same setup as Hessler uses. I finally worked out what lights he uses and what bike they are off. The only problem with the lights are they are designed for people who drive on the wrong side of the road but I think I may be able to over come that problem. I will have to admit they are a PITA to fit as I have had to make up brackets and bend & twist & grind things but I'm slowly getting there. I will post some photos up on here when I get some time.
Old 06-26-2010, 03:38 AM   #7511
chris3155
chris3155's Avatar
Oddometer: 249
My bike was imported from Germany to Ireland .I might put one of those deflectors on for now.
I want something that looks like it wasnt thromn together,especially with the bill gone.
keep us posted good luck with it.
Old 06-26-2010, 05:43 AM   #7512
Brendan J
ONE HACK AT A TIME
Brendan J's Avatar
Oddometer: 1,560
Aussie DR-BIG owners GET TOGETHER
Well I have had a bit more of a think about this and wanted to float the idea of a get together in March next year. Now this would give you guys sometime to get your bikes sorted as I know Berg2 has a bit of work to do on his and Rob's 750 is coming along nicely as well one of Ozzie's bikes is a work in progress to boot. So please tell me what you think and if you can think of a place to meet as well would be good. I am open to any suggestions of time and place so don't be scared to voice your thoughts as I won't be offended.
Now for anyone other Aussie's reading this and you have a DR750/800 and are not a member of this forum please join and make yourselves known your opinion is also appreciated.
Old 06-27-2010, 05:33 AM   #7513
robmoto
robmoto's Avatar
Oddometer: 3,857
Brendan, Swanhill is nice good caravan park on the Murry about 10 hours from me.
Old 06-28-2010, 02:56 AM   #7514
Simon M
Simon M's Avatar
Oddometer: 87
Aussie get together
Hi Brendan, Swan Hill sounds OK for a meet, but I'd have to go via Darwin to make a decent ride out of it as I'm in Perth. I guess we could call it a "BIG" event .
Hey Lloyd, what do you reckon? Are you up for it?
Simon M
82 Husky AE420 85 Suzuki Katana 1100 88 Suzuki DR750
07 Triumph Speed Triple 08 Yamaha WR250F
12 Moto Guzzi Stelvio NTX
Simon M is offline   Reply With Quote
Old 06-28-2010, 03:52 AM   #7515
ausibatla
ausibatla's Avatar
Oddometer: 447
Has anybody got any of the rubber mounted nuts that hold the fairing on to the beak? I really only need one but I reckon by the time I remove the fairing I'll probably need 4. I'm spittin' chips because Suzuki want $3.80 for each screw and $11.35 for each rubber nut. Also is there another type of nut and bolt that will do the same job?
Simon, I would love to take off and ride across Australia but I don't have the time, the money or the resources.
Cheers,
Times are GMT -7.   It's 04:19 PM.
