Old 01-10-2011, 03:16 PM   #9001
spen
on my arse
spen's Avatar
Oddometer: 346
SR42 model
spen is offline   Reply With Quote
Old 01-11-2011, 12:36 AM   #9002
Big Fan
Oddometer: 20
Toowoomba FLoods
Haven't posted for a while but follow you dr legends everyday. I'm from toowoomba in Australia. For those overseas google toowoomba floods. The videos are of the cbd. 9 dead, 59 missing. Houses washed away! Say a prayer for us and the victims. Thanks guys.
Big Fan is offline   Reply With Quote
Old 01-11-2011, 01:25 AM   #9003
spen
on my arse
spen's Avatar
Oddometer: 346
Hope you all make it through this tough time .and of course we are all praying for you
Old 01-11-2011, 05:07 AM   #9004
spen
on my arse
spen's Avatar
Oddometer: 346
finally on its wheels
Old 01-11-2011, 06:47 AM   #9005
Chanterman
Oddometer: 299
Looking a real treat there Spen...........
I may have to go back in the shed with mine again
Chanterman is offline   Reply With Quote
Old 01-11-2011, 05:27 PM   #9006
jabroka
jabroka's Avatar
Oddometer: 338
quick question
Guys, I was wondering.. did anyone fitted a low oil pressure switch replacing the main oil gallery plug? if you did, do you have a brand/part number? I cant find a small 14x1.25 oil pressure switch that activates at about 11-12 psi..
TNX!
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka is offline   Reply With Quote
Old 01-11-2011, 11:25 PM   #9007
robmoto
robmoto's Avatar
Oddometer: 3,858
Now 10 deceased 52 missing I have been glued to the TV, very sad and tragic event indeed, not religous but praying anyway. .
My thoughts are with the families and freinds of loved ones.
robmoto is offline   Reply With Quote
Old 01-12-2011, 01:41 AM   #9008
MCmad OP
Oddometer: 7,842
Im hearing all this in the Local News here in NZ
and will print this out and take it on my morning prayer walk.
We have many family and friends over there to, thankfully they are all OK but tough going for some others over there at the moment
Thoughts and prayer to you all in Australia
Mark
MCmad screwed with this post 01-12-2011 at 01:47 AM
MCmad is offline   Reply With Quote
Old 01-12-2011, 03:15 AM   #9009
Chanterman
Oddometer: 299
TNX!
Go to page 370 or search
Old 01-12-2011, 04:09 AM   #9010
HLK
aka Hielke
Oddometer: 141
It's been all over the news here. My thoughts are with you guys, be strong.
1996 Suzuki DR650SE
HLK is offline   Reply With Quote
Old 01-12-2011, 06:58 AM   #9011
hellicks hellmet
Prunc blastamat
hellicks hellmet's Avatar
Oddometer: 101
Working on the filter...
Yesterday it was the turn of that cumbersome, restrictive airbox to get off my bike. I'm going for an "easy in / easy out" solution; that is, an unrestrictive airfilter and a totally open exhaust. That being said, I had to come up with an airfilter that would fit my needs. I used this type of thin foam as an airfilter on my other Supermoto KLR, so it should do just fine here, too. Had to come up with smth that would fit the air intake collector on the carbs, and it so happened that an old empty powder-milk can (of which I have about a zillion in my garage - I've got a 2 year old son) has EXACTLY the right diameter, when I turned it oval.
I've glued the foam into a cylinder so as to fit tightly around the can and I've cut some openings into the can, so that the engine can finally BREATHE!
But no more small talk, I'll let the pictures do the rest.
Oh, I'll be finishing it later on today, probably in the evening. I'll be back with pictures, wether you like it or not!
I still have to cut the foam to size and fit a foam "lid" on the foam "cyllinder", and then slide it onto the can and.... VOILA!
I'm so deep, I have an echo.
1989 Suzuki DR BIG 750S Motard
1994 Suzuki DR 650R
1998 Aprilia RSV1000
hellicks hellmet is offline   Reply With Quote
Old 01-12-2011, 08:10 AM   #9012
nejauks
nejauks's Avatar
Oddometer: 173
Tank need of perforation, or foam will suck the inside. We need more foam layers. No protection from water and rain.Better that mounted on top, as is done in DR800
nejauks screwed with this post 01-12-2011 at 09:38 AM
nejauks is offline   Reply With Quote
Old 01-12-2011, 12:00 PM   #9013
hellicks hellmet
Prunc blastamat
Oddometer: 101
Ahemm....
The can IS already perforated, + it has no lid, and the foam will sit on the outside of it, so it cannot be sucked in. Damp/rain/water protection will be a fine layer of sprayable ol' WD40 on the outside of the foam (been there, done that, works like a charm).
Next!
1994 Suzuki DR 650R
Old 01-12-2011, 12:01 PM   #9014
MCmad OP
Oddometer: 7,842
Air Filter
HH
O yer, now you just need some wire and it will truly be a bushman's conversion
Is it just me or is thread almost of cult status (in a positive way I mean)
PS, cant wait to try this on my 750 once its on the road (and it will be 25kg lighter and shod with knobbies)
MCmad screwed with this post 01-12-2011 at 12:08 PM
Old 01-12-2011, 12:07 PM   #9015
Dino3310
Oddometer: 673
Originally Posted by 800rider View Post
HH
well there are a few "Wild hearted sons" on here
Dino3310 is offline   Reply With Quote
Times are GMT -7.   It's 07:13 PM.
