Old 02-23-2012, 01:58 PM   #12436
Resi
Resi's Avatar
Oddometer: 198
Send a message via Skype™ to Resi
ReaperX, dripping gas when the bike on the side stand: Malfunction on needle valve, blocked oder worn, or o-seal defect. Did you ultrasonic clean the carbs? Sounds that one of the tiny pilot holes or so is blocked.
I disassemble the carbs, clean them with degraser, lay 'em about one day or two in denaturaded alcohol.
After that I'll blow them dry with compressed air and check each hole gently with a broach.
I use new seals, and change the worn parts...
On some carbs I had the engine stalling when decelerationing, caused by heavy worn nozzle needle...
Bluesman, I do remember, for sure
I left the compression at stock (for the moment... hrrhrr), maybe the next pistons get slightly higher compression ratio.
I want to get the engine running... for the next step
Cheers,
Lars
Resi screwed with this post 02-23-2012 at 02:04 PM
Resi is offline   Reply With Quote
Old 02-23-2012, 02:06 PM   #12437
bluesman
Oddometer: 3,029
Thank you!
I am looking for raising compression because I had chance to run my DR on 92 (I found place, where owners of collectable old cars have special place to fill up) and I was amazed how better it ran.
What's worse...my VTR1000F runs on 92 better and use less petrol than 95.
Do not know why. I guessed it is low compression rate of both motors.
bluesman is offline   Reply With Quote
Old 02-23-2012, 02:29 PM   #12438
Resi
Resi's Avatar
Oddometer: 198
Mait, I didn't found them UK-guys..
I met some guys on the 2010 Intermot in Cologne,Germany.
We built a couple of pistons at my spec, I reamed one barrel last week (I mentioned allready, I think),
and get the whole bunch assembled...
Cheers,
Lars
Old 02-23-2012, 02:58 PM   #12439
ReaperX
Live life and ride free
ReaperX's Avatar
Oddometer: 79
Send a message via MSN to ReaperX
Cheers,
Lars
Thx Resi I will give that a go, do you buy the parts from wemoto oh from where?
Many Thx
DR800 BIG
TE610
ReaperX is offline   Reply With Quote
Old 02-23-2012, 10:54 PM   #12440
MCmad OP
Oddometer: 7,842
Hi Guys have begun to update owner registra on front page, any other takers ?
KTM has broken down but DR still going, just thought you guys might enjoy knowing that
MCmad is offline   Reply With Quote
Old 02-23-2012, 11:44 PM   #12441
bluesman
Oddometer: 3,029
I don't want to gloat because it is your KTM but....
What happened?
Old 02-24-2012, 12:15 AM   #12442
Resi
Resi's Avatar
Oddometer: 198
Many Thx
Mate, no, we've got in germany some suppliers, too.
But I think wemoto makes good prices for this stuff.
When you buy these tiny o-seals at Suzuki, you'll pay a lot of bucks...
If you find out that the needles and/or nozzles are worn, drop me a PN ;)
Cheers,
Lars
Old 02-24-2012, 02:14 AM   #12443
MCmad OP
Oddometer: 7,842
What happened?
Don't really think its a KTM issue as such, ran fuel low about 20Km into low fuel light (sometimes I go up to 60Km) bike started to miss as if running out of gas when heavy throttle was used so I presume it was low fuel, refuel expecting problem to go away but it only got worse, bike will run on light throttles but completely dies on heavier usage, which was fun on the way home as at about 105kph on the motorway it would die and slow to about 50kph before regaining fuel and taking off again (a bit dangerous in traffic)
I'm thinking its water in the Carb after running low fuel?
Haven't been bothered as after my shoulder injury, have found KTM hard on me were as DR gives me an easier time of things (especially off road)
So no biggy that KTM is down for now
and One up for the DR
MCmad screwed with this post 02-24-2012 at 02:33 AM
Old 02-24-2012, 02:31 AM   #12444
robmoto
robmoto's Avatar
Oddometer: 3,331
Mark maybe just a blocked filter .
I ride alone and not a KTM in sight .
robmoto is offline   Reply With Quote
Old 02-24-2012, 02:36 AM   #12445
MCmad OP
Oddometer: 7,842
Could be Rob
As I say I don't care at the mo, polished the girl up and left in garage as am happy to Ride DR for a while
PS, its a major job to get to all that stuff and since I'm one armed will leave for now, will probable send to shop before next big road ride
MCmad screwed with this post 02-24-2012 at 02:47 AM
Old 02-24-2012, 03:10 AM   #12446
bluesman
Oddometer: 3,029
800rider,
What you describes looks like problem one of 990 owners I know had.
It was something to do with filter and pressure regulator. Cleaning mainly.
He developed solution to make it easier by (if memory serves me right) moving pressure regulator to outside of tank or something like it.
Here is photos
disregarding Russian text
http://kickstarter.org/forum/index.p...7392#msg107392
http://kickstarter.org/forum/index.p...7393#msg107393
http://kickstarter.org/forum/index.p...7395#msg107395
http://kickstarter.org/forum/index.p...7396#msg107396
And filter from Chrysler Voyager 3 liter (mitsubishi motor)
http://kickstarter.org/forum/index.p...99681#msg99681
He says that if engine get's really hot and petrol is let say not perfect the flow rate of original filters combo kinda s...s and bike start to behave as you described. So he made this mod.
Old 02-24-2012, 03:49 AM   #12447
robmoto
robmoto's Avatar
Oddometer: 3,331
Running low on fuel allows a lot of fuel sloshing and moving arround and stirs up all the crud, and allso refueling with a low tank stirs it all up again, its amazing some times when you clean the tanks out and wonder where did all this crap come from .
I thought I bought clean fuel .
Old 02-24-2012, 06:55 AM   #12448
kuba_astr
kuba_astr's Avatar
Oddometer: 8
Hello!
I'm Kuba and I'm from Poland, I couldn't find any "Hello" thread on this forum. I was always a reader, now I wish to join this very interesting 'population'
I've got the biggest thumper in the world as I might say all in this thread :)
Here's my BIG, actually this forum was the reason to build my own DR BIG....
A lot of work but it runs great!!!!!!!!!
SuzukiDR 800 SE
kuba_astr screwed with this post 02-29-2012 at 04:02 AM
kuba_astr is offline   Reply With Quote
Old 02-24-2012, 07:18 AM   #12449
AJ..
AJ..'s Avatar
Oddometer: 1,321
Send a message via MSN to AJ..
here's ny bike at presant with the upper crashbar just installed
HONDA XRV750-02(woot-woot)BMW R1100GS-'98()
KTM LC400SM '97()XR650R-02(For Dirt)
(Hyundai Tucson-(For Family)
http://www.facebook.com/pages/AJs-fr...7491373?v=wall
AJ.. is offline   Reply With Quote
Old 02-24-2012, 08:47 AM   #12450
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,302
Nicely done
Kuba astr
Welcome...what a great first post and nicely done BIG. If there were more than a handful in the US, I'd want one just like that to compliment the one I have.
Please give us list of what you've done. The side panels/rear fender/silencer all fit together very well.
Ladder106 is offline   Reply With Quote
Times are GMT -7.   It's 07:47 PM.
