05-17-2012, 05:06 AM
#13021 | |
Oddometer: 3,249
http://www.ebay.com.au/itm/215-06-Fl...item256cb25626
I ride alone and not a KTM in sight . |
05-17-2012, 05:35 AM
#13022 | |
Oddometer: 2,993
This is brilliant! Thank you - I am watching it! :) And related one too - where they wheelie sh....t out of XC! bluesman screwed with this post 05-17-2012 at 06:00 AM |
05-17-2012, 07:28 AM
#13023 |
It's a short cut, really
Oddometer: 4,260
Electrical throttles
There are two words that scare me about the XC (and I guess every other new bike out there )
STEPPER MOTOR I just can't seem to get my head around having some tiny electrical motor opening (and closing which may be even more important) the throttle for me. LUDDITE !!! ............yep..............sorry |
05-17-2012, 07:36 AM
#13024 |
Oddometer: 2,993
We are so alike Ladder!
![]() I decided to break myself and go for new bike and one of reasons was precisely that - my luddism! I am improving myself! |
05-17-2012, 07:40 AM
#13025 | |
Oddometer: 4,260
Well.......maybe...... The only real way to know is to remove the springs and measure the travel available in the fork leg. (Fork Travel) Then measure all the spaces between the coils of the spring and add them up to get (Spring Travel) If ST is greater than FT the difference will tell you how much you can preload the spring before it coil-binds before the forks reach full compression. In general you want the fork internals to stop the fork (hydraulically) before the spring coil binds. But like all rules this is done for competition tuned bikes when trying to consistently use all available travel on the worst part of the course. In reality our bikes only use full travel in a very short part of their lives so setting up something that coil-binds first is not really that bad. However, when the fork does coil-bind, it's a pretty harsh hit and will really sting your hands on the bars and sometimes even make you loose your grip at a time when you need it the most. |
05-17-2012, 07:44 AM
#13026 |
Oddometer: 2,993
true....if travel was shorter than let say 2/3 of spring lenght (kinda rough rule) then probably no coil bind expected...
Honestly speaking - recalling our Morocco offroad - even idea of coil bind on those potholes makes me scared...I'd have somersault together with bike. |
05-17-2012, 12:04 PM
#13027 | |
Oddometer: 17
Seperate topic,fuel use in city riding conditions is 5.12 l/100km,not too shabby? I'm going to search up all the things that have been done to free up airflow as I've got a minor off-idle flat spot with large throttle openings,and it looks like by the time I get that done,and source a gsxr oem muffler,it'll be tire time. Thanks so much you guys for the input on these issues. I'm starting to see how this bike fills a certain niche pretty well. I looked at the smiley selection.Pretty soon I may try one. |
05-17-2012, 11:51 PM
#13028 |
rooky
Oddometer: 62
From 27-28th to 30th of April.
Okta www.drbig.hu |
05-18-2012, 09:46 AM
#13029 |
Oddometer: 27
05-18-2012, 10:03 AM
#13030 |
Oddometer: 2
"Stefan Heßler -winner of the +180kg class of the rally dalmatia 2012"
GRATULATION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
05-18-2012, 10:25 AM
#13031 |
Oddometer: 51
Hi all, just testing the water really as I haven't made my mind up fully. But, it's come time to make some room in the shed & move on the DR Big. I've hardly ridden it in the last few years, so it's probably best to let it go to someone who'll get more use out of it. It's a 1991 in very good cond. with 26000 miles. it wears a Dep end can, has a Hagon rear shock, Hepco & Becker crash bars, other than that it's pretty standard. If anyone wants to make me an offer, work away, nothing silly mind!!! Regards, Robs.
05-18-2012, 04:00 PM
#13032 |
Oddometer: 486
Hello guys,
removing the springs to test maximum fork-travel: doesn't this lead to the measurement of too much travel? I think that the inserted spring, fully compressed, sets an earlier limit. Or am I wrong? Curious greetings, Bambi
'Find me kindness, find me beauty, find me truth ...' (Dreamtheater, Learning to live) |
05-18-2012, 07:37 PM
#13033 | |
Oddometer: 3,249
was wondering what other make of bikes are in this class and a over all placing just to compare how good the BIG,s are against the newer bikes. Well done HRT.
05-18-2012, 10:31 PM
#13034 |
Oddometer: 4,260
Well Done, Stefan
05-19-2012, 12:55 AM
#13035 |
Oddometer: 2,993
Limit normally set by hydro lock (contemporary forks) or hydro stop (earlier models) or sprung stop combo with hydro "slow down" process (usual piston forks - like on DR). E.g. it is not spring that stops forks. Normally stop should stop forks before spring reaching full compression.
