Old 05-28-2012, 04:02 PM   #13111
Jakob
Oddometer: 34
Send a message via Skype™ to Jakob
can anyone please put an instruction how to change fork oil.. and how much oil goes inside it, and how to do it without breaking those oil seals or whatever they are..
I'll just grab another beer and do what I know how to do until someone helps me out.
Never ride faster than your quardian angel can fly!
Jakob is offline   Reply With Quote
Old 05-29-2012, 12:14 AM   #13112
Resi
Resi's Avatar
Oddometer: 194
Send a message via Skype™ to Resi
Jakob,
I do this like in the service manual described.
http://www.timguy.net/sites/drbiginfo/DrBIGmanuals/
Additionaly I use petroleum to get the black stinky old oil out of the bottom valves.
I let them drip out bottom side up overnight (after petroleum flush).
Fresh oil depends on your and your bikes weight and preferences.
Refill: press the fork together, spring not yet inserted.
Fill oil up to 160mm (SR43, Wirth springs, rider app.100kgs).
As a rule of thumb: The smaller the air chamber the harder the fork
Cheers,
Lars
Resi is offline   Reply With Quote
Old 05-29-2012, 01:41 AM   #13113
d33t
Oddometer: 27
Trying to make template of front caliper bracket:
d33t is offline   Reply With Quote
Old 05-29-2012, 05:07 AM   #13114
spen
on my arse
spen's Avatar
Oddometer: 309
Hi guys i have some spares in my shed that i have decided to sell ,any questions PM me ,i will ebay them but would prefer you guys saw them first ,My bike is an SR42 the first 800 model so thats what the spares are for .
750/800 CDI £60
750/800 REG /REC £20
750/800 FUEL PUMP £30
BRAND NEW!!!! SUZUKI LEFT HAND SWITCH SET £50
SET OF CLOCKS £30
EXHAUST DOWN PIPE £15
STARTER SOLINOID £8
SET OF SIDE PANELS £30 (NEED PAINTED) 750/800 MODEL SOLD
BATTERY BOX IN GOOD CONDITION £20
JUST FOUND REAR GUARD AND BEAK AND TANK FILLER PLASTIC COVER SOLD
REAR PLASTIC COVER THAT STOPS THE DIRT FROM THE BACK WHEEL COMING UP INTO THE BATTERY BOX AREA SOLD
I HAVE A FEW OTHER BITS IF YOU NEED ANYTHING LET ME KNOW ALL PRICES ARE BEFORE POST AND NEGOTIABLE
ALL THE BITS WILL BE ON EBAY THIS WEEK !! ONCE LISTED THERE WILL BE NO ENDING THE AUCTIONS EARLY
IF YOU NEED PICS OF ANYTHING PM ME
ALSO FOUND A SET OF CARBS ,ONE OF THE PLASTICS TOPS IS DAMAGED THE PICTURE OF THE BATTERY BOX ALSO SHOWS A MOUNTING FOR A CENTER STAND
/albums/ac139/spenspics/DSCF0037-8.jpg[/IMG]
spen screwed with this post 05-29-2012 at 07:30 AM
spen is offline   Reply With Quote
Old 05-29-2012, 07:36 AM   #13115
djerf
Oddometer: 1
Question Clutch seal
Hi! Does anyone know if it is possible to change the clutch seal (red) by undoing the blue-circled bolt and pulling out the axle, or if you have to do it the hard way? Thanks!
djerf is offline   Reply With Quote
Old 05-29-2012, 08:23 AM   #13116
Resi
Resi's Avatar
Oddometer: 194
Yep, I'll do it this way, too.
Cheers,
Lars
Old 05-29-2012, 10:32 AM   #13117
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,270
Whatever oil or level you use....make certain to pump the forks up and down a few times to expel all air bubbles. You'll see the level get much lower after the air is gone....then refill to final measurement.
Ladder106 is offline   Reply With Quote
Old 05-29-2012, 12:48 PM   #13118
Resi
Resi's Avatar
Oddometer: 194
Right!
Old 05-30-2012, 03:34 AM   #13119
the_sad_punk
the_sad_punk's Avatar
Oddometer: 348
And.....with progressives springs tighter wound part rides up top.
the_sad_punk is offline   Reply With Quote
Old 05-30-2012, 04:55 AM   #13120
bluesman
Oddometer: 2,998
Interesting. Why tighter part up top?
I mean - it is how I usually install them too, but did you find any tips on why we do it so?
We recently had big discussion on this on our site, hence the question...I had theory on that but it's kinda...shabby...
bluesman is offline   Reply With Quote
Old 05-30-2012, 05:10 AM   #13121
robmoto
robmoto's Avatar
Oddometer: 3,267
Probably so the tight coils don,t take up to much oil space.
Blue have you got the Tiger XC pic,s required and a full report nothing less .
I ride alone and not a KTM in sight .
robmoto is offline   Reply With Quote
Old 05-30-2012, 07:07 AM   #13122
Resi
Resi's Avatar
Oddometer: 194
Maybe the unsprung masses are lower?
Cheers,
Lars
Old 05-30-2012, 08:25 AM   #13123
Ladder106
Ladder106's Avatar
Oddometer: 4,270
Boing...boing
Yep, those are the two reasons. For our riding #1 makes the most sense. If you're a racer (or a real techno-weenie) #2 has some validity.
I've also heard this: As the spring compresses, the more tightly woundd coils will coil-bind first.....this makes the coil-bound area go into a slight "S" shape and so the overall diameter of this area grows.....This growth is better handled by the fork if it happens in the top (tube area on "conventional" forks) than if it happens in the fork leg. If the spring contacts anything up top it will be only the steel tube rather than softer aluminium parts down below......Dunno if I believe this one or not.
In the end.......the spring doesn't care.
Old 05-30-2012, 09:27 AM   #13124
spen
on my arse
spen's Avatar
Oddometer: 309
All the bits are now on ebay
Old 05-30-2012, 02:28 PM   #13125
Bambi
Bambi's Avatar
Oddometer: 487
Hello guys,
a friend of mine, running a professional motorcycle-workshop, once told me, that the narrow part of the spring creates too much foam in the fork-oil if it's installed on the low-side. Sounds not too stupid to me ...
Kind regards, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Times are GMT -7.   It's 06:51 PM.
