Old 12-03-2012, 12:22 PM   #13846
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,268
107mm pistons now aviable in our big shop
Stephan,
Do you think this is a reasonable change for a road-oriented bike running standard carbs and air cleaner?
Are any changes to the cylinder head required?
Is the vibration significantly increased?
I'm beginning a SR41A rebuild and the large bore might be an interesting thing to do.
Ladder106 is offline   Reply With Quote
Old 12-04-2012, 02:08 AM   #13847
robmoto
robmoto's Avatar
Oddometer: 3,267
Originally Posted by madafakinges View Post
remember Total Recall with Schwarzcenegger there were a woman with three tits... my girl have four
She is a keeper then , now theres a deal Stefen could do buy 2 pistons and get 2 free .
I ride alone and not a KTM in sight .
robmoto is offline   Reply With Quote
Old 12-04-2012, 06:09 AM   #13848
Seppo
Oddometer: 348
Send a message via Skype™ to Seppo
okay, its me again from austria.
still, my blue dr 800 has no spark and since i have another sr42 now, i checked pretty much everything and compared it between the running and the non running Big´s.
one thing, that has slipt through my mind until now has been the ignition coil. or the ignition coils, because there are 2 of them and i had no spark on any spark plug. that made me believe that they can´t be the problem. until now. i worked through my workshop manual and when it came to test the ignition coils, i realized, that one of them is broken. but that is still wierd, cause i don´t get a spark on the other coil aswell. just a coincidence or is there a connection?
and on another topic, i hope i will leave the cold and snowy alps behind me this winter and ride south into tunisia. has anyone of you ever riden the dr on sand dunes?
cheers
josef
92' Suzuki DR 800, 00' Buell M2
07' Husky TE 450, 95´ Ducati 916
Seppo is offline   Reply With Quote
Old 12-04-2012, 06:24 AM   #13849
Ladder106
Ladder106's Avatar
Oddometer: 4,268
No African dunes but have ridden the sandy trails in the Nevada desert in the USA.
- Good knobbies are a must. Any street/road oriented tire will leave you frustrated and pushing the bike...the Bigs are heavy.
- Make certain she's full off high quality synthetic oil. Low speed, high rpm riding in warm temps will tax your engine cooling. Check oil level after EVERY ride cause the bike will use some.
- Have a way to adjust air pressure easily in the middle of the ride. Reduce for sand, increase for pavement and sand mixed with rocks.
Go for about 2mm of "Clean Rim" when messing with air pressures. But be careful of tire "creep" if you're not using rim-locks. Remove the nut from the valve stems so you can see the stem moving over at an angle first.....rather than tearing the stem off the tube.
- Make sure your bike is comfortable when standing up. Weight way to the rear - steer with your feet. Some guys find the rubber mounted pegs on the Bigs a problem here. You can temporarily defeat these with the creative use of a few washers and longer mounting bolts.
- Speed is your friend. Riding sand at 20kph will have you falling down alot.
- Cresting rises and dune tops at an angle is easier (at least at first) since it reduces the "Ohhhhhh Shit" factor when going down the other side
Expect to be a bit frustrated for the first 10 miles or so....then it's fun but don't get so carried away that you forget to watch cylinder head temp or any signs of overheating.
That's all I can think of
Old 12-04-2012, 07:28 AM   #13850
mait
mait's Avatar
Oddometer: 227
Tuareg Rally
That sand talk reminded me of this interesting story read here:
http://www.drbig.info/forum/viewtopi...t=887&start=10
I wonder if a better prepared Big with a better rider (no offense here) would have made it further? It kinda made me sad that he had to quit.
mait is offline   Reply With Quote
Old 12-04-2012, 02:08 PM   #13851
Seppo
Oddometer: 348
thats a great story. i guess in the end its just a question of power to weight ratio. the big is to heavy for 50hp. and after all its basically a road bike with limited off road capabilities. more power (and cooling) and a tuned suspension would help heaps here.
Old 12-05-2012, 01:57 AM   #13852
robmoto
robmoto's Avatar
Oddometer: 3,267
The weight is the problem, once you loose speed your had it, and where is all this road bike crap coming from are you that blind if you park it beside a road bike you carn,t see the difference fair dinkam .
Old 12-05-2012, 03:04 PM   #13853
catweasel67
BAN - Born Again Noob
catweasel67's Avatar
Oddometer: 5,529
heya,
Bikeless in Vienna here :(
I'm narrowing my next bike choice down and number one on the list is a DR Big. The price is right, they're available (although in fairly limited supply), they're funky enough etc etc. I'm up to page 50 in this thread and I've a lot of pages to go so if this is 205 my apologies :)
So, intro done, question time;
Right now I'm wondering what the differences, just the big ones, are between a SR42 and an SR43.
Is it worth hanging on for one model over the other?
Is there a buyer's guide buried in this thread that I've not found so far?
thanks in advance for your answers :)
Planning NA 2010 NA 2010
Adriatic Loop August 09 Mandello Guzzi Protest Sept 09
"I've got the key to the gates of paradise...but I've got too many legs!!" Jeff
"Civilized men are more discourteous than savages because they know they can be impolite without having their skulls split, as a general thing." -- Robert E. Howard
catweasel67 is offline   Reply With Quote
Old 12-06-2012, 12:39 AM   #13854
Seppo
Oddometer: 348
Originally Posted by catweasel67 View Post
heya,
hey catweasel,
there is an used buyers guide for the DR 800 at motorradonline http://www.motorradonline.de/gebrauc...r-800-s/107160
i have 2 sr42´s, and what i can tell you is, that they are very rare here in austria, so getting used parts is a PITA. i was looking for a second sr42 for a long time and found one this august in upper austria. i paid 1000euros for it, needed new battery and tyres.
i´m no expert on the sr43, but AFAIK the main difference is a smaller fuel tank, auto-decomp and the new styling.
for me, some must do´s are steel brake lines and tuned suspenison in the front with fork brace.
have you seen this one already? http://www.willhaben.at/iad/gebrauch...?adId=49546595
greetings from wieselburg
josef
Old 12-06-2012, 01:09 AM   #13855
Seppo
Oddometer: 348
well i guess we have a different take on offroad bikes. here where i live, its not allowed to ride off the paved road. there are a few exceptions, and working on a farm here helps too, but gravel roads are usually prohibited. that limits the big here in austria and europe in general to the tarmac. cause all the offroad parks are made for super light exc´s or wr´s and so on. and like i said, it has offroad capabilities, but they are limited. my bigs are parked next to a ducati and a buell. so i see your point, there is a difference. but its also parked next to my husky dirt bike...and there is a difference aswell.
Old 12-06-2012, 01:19 AM   #13856
bluesman
Oddometer: 2,993
Originally Posted by Seppo View Post
hey catweasel,
josef
Except weight and stock exhaust and tank size and styling everything else about SR42 not worth chosing over SR43.
SR43 have different 43 mm (instead of 41 on SR42) forks that actually work quite well for such old bike and much better than SR41 and 42 forks.
SR43 have 300 mm front brake disk
SR43 have 5 mm longer wheelbase and slightly beefier swingarm (early sr42 vs sr43)
SR43 have reinforced frame that quite a bit more rigid than SR42
SR43 have full-blown system (mechanical and electronics) to prevent back-turn of engine and damage to parasite starter gear.
SR43 have 4 more BHP but only in unrestricted version - for example Belgium, France, Italy I think and Spain. German model sports few degrees different ignition map resulting in 50 bhp. Same for torque.
SR42 have 29 liter tank, SR43 have all different bodywork and 24 liter tank.
Late SR43 model have TPS.
The main weight difference is down to 14.5 kg stock exhaust on SR43 and 5 kg of taillights hardware - both can be easily removed. Suspension is better thou despite stroke down to 220 mm - which is more than sufficient if sprung correctly. If.
Parts for SR43 still available at Suzuki, so it is much easier to do than SR42. If you really want SR42 styling - take SR43 and fit SR42 "clothes" on it. Been done, totally possible.
bluesman is offline   Reply With Quote
Old 12-06-2012, 07:40 AM   #13857
catweasel67
Oddometer: 5,529
Originally Posted by bluesman View Post
***SNIP***
hey catweasel,
josef
thanks to both of you :) really helpful information :) lots to comprehend.
I'd not seen that 800 link Seppo, thanks for the link. I was only aware of 1000ps.at so now I've two more :). Am hoping to in March/April - no real value in buying before then, as much as I'd like it. It'd sit, covered in snow, more than it got ridden.
Old 12-06-2012, 09:49 AM   #13858
Hyena986
Hyena986's Avatar
Oddometer: 5
Send a message via Yahoo to Hyena986
hey guys... I prepared my 750 for the winter... the snow kind of surprised me on the road yesterday
and today I got my new license plate
Hyena986 is offline   Reply With Quote
Old 12-06-2012, 10:41 AM   #13859
Geo-Nemesis
Oddometer: 20
LOVE THAT LICENSE PLATE!
Geo-Nemesis is offline   Reply With Quote
Old 12-06-2012, 10:54 AM   #13860
Hyena986
Hyena986's Avatar
Oddometer: 5
Cool2
Yeah! I'm proud of it and pretty happy that it was available it worth the extra 10 euro
Hyena986 screwed with this post 12-06-2012 at 11:39 AM
Times are GMT -7.   It's 06:23 PM.
