01-18-2013, 05:40 PM
#13981 |
Oddometer: 3,254
try ebay Pyramid spares, and Wemoto engand.
I ride alone and not a KTM in sight . |
01-18-2013, 10:59 PM
#13982 |
Puddle,
are you looking for the bottom seal? Cheers, Lars Gesendet mit Tapatalk über Erdfunkstelle Usingen/Taunus |
01-19-2013, 08:48 AM
#13983 |
Tall Geezer !
Oddometer: 62
Hi, I just sprayed my engine satin black. That's what I did this afternoon.
http://motorcyclerestorationuk.activeboard.com/ Suzuki DR 800 BIG / Triumph Tiger 955i. |
01-19-2013, 08:54 AM
#13984 |
Oddometer: 111
01-19-2013, 10:10 AM
#13985 |
Oddometer: 2,291
Hello Gents,about 18 months ago I was fortunate enough to buy this beauty.
![]() As you can see the tanks, and plastics are in very good condition. ![]() ![]() Since then I have given it a good clean and have painted a few parts in order to tidy them up and now it is going back together again. ![]() ![]() Which brings me to a problem that I have had with the bike. Ever since I got it it has always leaked fuel from the carbs. Soooo, I took the carbs off to have a look at them. Now, I'm sure that you will be able to spot that the carb that was giving me the trouble is missing something quite important - like the main jet WTF?![]() And, upon further investigation found that something else was missing. I don't know what it is called so I'll show you what it is. It's this little brass tube (jet?) that my screwdriver is pointing at. ![]() ![]() Now, I'm no factory trained mechanic but I'm guessing that these missing parts may be the reason why fuel is pissing out of my bike! So, my question is what is that missing part called and where can I get one from? Also, I guess that I should be able to order a main jet from a Suzuki dealer or from Stefan Hessler? Any help is much appreciated, thanks
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon. |
01-19-2013, 11:33 AM
#13986 |
It's a short cut, really
Oddometer: 4,265
Hiya Tim,
Very nice bike. So, to be terse, on to the questions. The main jet is, indeed missing. Are you certain it wasn't in the bottom of the float bowl when you took the bowl off? If you were not the one to replace the phillips screws with allens, then whoever was there before you seems to at least have some inkling of doing things correctly, so it's quite odd that the main would be AWOL. Of course, the main should be replaced. If the UK is anything like the USA, the jets should be available at almost any dealer. Make certain to get the correct size. It should match the other main in number. On the tiny brass tube, the SR41s (750s) only had a "choke" (enrichener circuit) in the left carb. Unless I'm mistaken this tube provides the fuel pickup for that circuit. The same spot in the right carb should be blanked out and not drilled for anything, correct? Now, for the fuel leak. Unfortunately, the answer to your leakage question is "None of the above" Fuel is leaking because one or more of the small O-rings that these carbs use is dried out/cracked/torn/square in cross section/or otherwise damaged. You'll find these O-rings (a) under the brass tube that holds the float valve (b) on the plastic "tree" that supports the floats themselves (c) on the bottom of the grey plastic throttle slide guides where the guides go into the carb body. And the other place may be the float valves themselves. If the small black taper is dented or damaged, fuel will overflow since the floats will not stop it. From here it usually fills the crankcase...which it much worse than leaking out of the carbs. There are also O-rings on the tiny idle mixture screws down at the bottom...they are very very small but should be replaced. Replacing all these bits is not expensive but is a bit tedious. The bits for the grey plastic slide guides I was able to find from BMW or KTM since a few of their bikes use the same parts. The Suzuki parts diagram does not even list the slides or the O-rings as a seperate part. Setting the float level correctly and replacing all the O-ring should solve your fuel leakage problems. BUT...you may also want to check the fuel "T" that lives between the float bowls. There is a seal on each side of this "T". If the "T" spins around in the space between the bowls with little to no effort, these seals should be replaced. The "T" should be able to rotate but should have significant "drag" when moving it. If it seems loose, fuel will leak from that part also. Once all these problems are solved (a bit of what's required in owning a 20 year old machine) the carbs work quite well. Lots of information and photos if you do a search for "carbs" on this thread. Remember to use the fuel valve on the tank and turn the fuel OFF after you put the bike away for the day. Leaving this valve on is asking for problems. Enjoy Ladder106 screwed with this post 01-19-2013 at 11:40 AM |
01-19-2013, 12:29 PM
#13987 | |
GSX750 (1999) Suzuki part number 51644-12C00 should do the job. The only difference is that this seal will sit below the lower ring, you have to mount the seal before (!) the lower ring comes onto the stem. Cheers, Lars |
01-19-2013, 12:47 PM
#13988 |
Oddometer: 224
About pistons
I did some more research on pistons.
OEM pistons with valve cutouts are not sold any more. They are superceded by simple flat top pistons without any recess or cutout. I dug out the box of the 0.5mm oversize piston set I ordered 2 or 3 years ago for my SR42. The part number is 12100-31D00-050. And the same piston set is sold now by CMSNL for SR41, SR42 and SR43. Conclusion - flat top piston without valve cutouts will work on all DR Bigs be it SR41, SR42 or SR43. Thanks to BigBob on drbig.info who led to the right tracks.
mait screwed with this post 01-19-2013 at 01:03 PM |
01-20-2013, 05:12 AM
#13989 | |
Oddometer: 2,291
Thank you very much for your reply.
01-20-2013, 07:34 AM
#13990 | |
Oddometer: 94
Got proper cert for the exhausts to clear inspection in Singapore? If have I buy.
Motorcyclists are the nicest people on the road, try not to kill us. Silent Hunter screwed with this post 01-20-2013 at 07:41 AM |
01-20-2013, 07:55 AM
#13991 |
Oddometer: 4,265
Tim,
Sounds like you have all the usual suspects already corrected. The O-rings on the bottom of the slide guides will not normally be responsible for a lot of fuel leakage. But they do affect the carbs performance a bit. The guides were designed as the "soft-part" in the carb that takes all the wear from the slides vibrating in and out on intake cycles from the big cylinder. They can have significant wear and cause problems with the fueling if badly worn. ![]() To remove the slide, the needle jet (long brass tube) must be removed first. They can be a bit stubborn so what I do it this: Unscrew the main jet about 1 1/2 to 2 turns. Tap the main jet toward the top of the carb with a small soft hammer or even the plastic end of a screwdriver. This should start the guide moving upward toward the diaphragm area. If more "persuasion" is necessary you can GENTLY thread in a 4mm screw (I think this is the correct size) that has longer threads and give it a few more taps. Careful here because I don't believe the M4 screw has exactly the same threads as the main jet and you do not want to "rethread" the brass needle jet. If your slides require replacement, I was able to get mine from a BMW dealer. They are the same ones used on the early model BMW Funduro 650. BMW has these listed as a part number (slide and O-ring" while Suzuki makes no mention of this. The last thing I'd recommend is to find the carb vent tube that exits the between the two carbs and is usually routed back under the seat somewhere near the airbox. If you ride off-road or dusty conditions, a small air filter (K&N has them) clamped onto this line will prevent dirt from entering the area under the diaphragms of the carbs. Maybe you found dirt there while cleaning? Also, On reassembly, particularly in cold weather, I'd recommend removing the bolts holding the airbox/rear fender to the frame. This will allow you to move these bits upward and back a few cm. This will give you more space to refit the carbs and make CERTAIN the boot between the carbs and the airbox is sealed correctly on the carb mouths. Doing this seems like it takes longer but, in fact, will save time and bad language while wrestling the carbs back into place, pinching and tearing the airbox boot etc. Lastly, make sure the carb vent tube and vacuum line (the one driving the fuel pump) are connected to the carbs BEFORE you install the carbs on the bike. There is very little space available for installing these lines after the carbs are in place. Ladder106 screwed with this post 01-20-2013 at 08:00 AM |
01-20-2013, 01:58 PM
#13992 |
Oddometer: 111
Thank you Lars. Really appreciate this. Rob
01-21-2013, 08:01 AM
#13993 |
on my arse
Oddometer: 309
Stuck my center stand on ebay and sold it but the winner decided not to pay so i have had to relist it .It"s quite heavy to post so would prefer UK or Europe . You can make me an offer on it if interested.
NOW SOLD THANKS spen screwed with this post 01-22-2013 at 12:12 AM |
01-21-2013, 02:33 PM
#13994 | |
adventure flyfisher
Oddometer: 328
Centerstand
96 DR 650 77 Montesa Cota 247 Restored 87 XL600V Transalp Project 77 Yamaha TY 250 Restored 75 Honda CT 90 Trail Project |
01-21-2013, 02:59 PM
#13995 |
on my arse
Oddometer: 309
Shipping is coming back £60 /£70 .far to expensive although my sister is visiting from Toronto in July , if i still have it i will send it back on the plane with her
