Old 01-29-2013, 09:14 PM   #14026
KilgoreTrout
adventure flyfisher
Oddometer: 328
1989Dr 750SK vs 1990Dr 800s
Another day another test ride Ray... it must be nice! When I went to work this morning it was -38C with wind chill However they are forecasting +7C by Saturday....heres hoping The question I am posing is whether the side panels from the 89 750s and 90 800s are interchangeable and are the colors the same ( Marble Dynamic Blue ) Figured if any knows the answer it would be here. Thanks in advance for any help with the puzzle. Cheers BA
96 DR 650
77 Montesa Cota 247 Restored
87 XL600V Transalp Project
77 Yamaha TY 250 Restored
75 Honda CT 90 Trail Project
KilgoreTrout is offline   Reply With Quote
Old 01-30-2013, 12:29 AM   #14027
robmoto
robmoto's Avatar
Oddometer: 3,260
Pigs ass they need a big silencer, they just need a big hole at the end ..
I ride alone and not a KTM in sight .
robmoto is offline   Reply With Quote
Old 01-30-2013, 12:34 AM   #14028
robmoto
robmoto's Avatar
Oddometer: 3,260
The shape is the same . but as for the colour I have only seen red 89 ones down under from memory.
Old 01-30-2013, 01:42 AM   #14029
mait
mait's Avatar
Oddometer: 227
Now that was funny, made me spill my coffee
I have the same silencer from GSXR1000 as Ray and I am pleased with the sound, too. No idea how it performs, due to snow I did not do any field testing before I tore the engine apart. The gas flow is definately easier compared to stock muffler. If the hole is big enough will be seen in the spring.
Ray, I am watching your jetting progress with interest because I will have the same way to go when the pistons arrive.
mait is online now   Reply With Quote
Old 01-30-2013, 08:11 AM   #14030
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,268
Rob,
Hole at the end of the can is 37mm (with spark arrestor installed)
It's 45 mm with spark arrestor removed.
I took the spark arrestor out and did one test ride with essentially no change in performance other than just a bit more noise.
Ladder106 is offline   Reply With Quote
Old 01-30-2013, 08:27 AM   #14031
Ladder106
Ladder106's Avatar
Oddometer: 4,268
KT,
I posted a reply in drbig.info.
Bob answered your question there. The short answer is the 800 came in blue but a different shade and color name.
eBay perhaps??
Old 01-30-2013, 06:27 PM   #14032
KilgoreTrout
adventure flyfisher
Oddometer: 328
Thumb Ladder
Originally Posted by Ladder106 View Post
KT,
eBay perhaps??
Thanks Ray, I saw it and figured as much I will go with white and keep an eye out for a spare
96 DR 650
Old 01-30-2013, 09:09 PM   #14033
robmoto
robmoto's Avatar
Oddometer: 3,260
Ray 37mm is good size should be fine, I was thinking it may have been smaller like the GPR ones 25mm
Old 01-31-2013, 05:37 AM   #14034
Rik Le Ray
VAT FREE FISHING
Oddometer: 32
Marlboro decals
ok guys i have a set of Marboro decals for sale 1 only the same as the pic please email me sales@tackledirect2u.co.uk if your interested £125.00
[IMG] photo P1000191.jpg[/IMG]
Rik Le Ray is offline   Reply With Quote
Old 01-31-2013, 08:38 AM   #14035
Ladder106
Ladder106's Avatar
Oddometer: 4,268
And to further confuse things....RATIOS
When I first started riding my "transplant" bike (1993 SR43 engine in the 1989 SR41 frame) I noticed that it felt like the gearing was different.
Noticably taller.
Since I also changed the rear tire for a brand new knobbie I put this off at being the result of the tire change.
Yesterday I was able to put in a much longer 80 mile ride and spent some time on the motorway for the first time. Here I really noticed that the gearing had changed. I was at 4550 rpm and 70 mph. Before the transplant 70 mph had been just under 5000 rpm.
Why the difference?? And also (and more importantly) maybe this was the real reason the bike would not pull to redline in top gear.
So I took a careful look at the service manual.
Final Drive ratios:
The manual lists 15/48 as the final ratios for the SR41 and also for the SR42.
The SR43 gets a 15/47 final. So when the 800cc engine gets the larger air boxin the SR43, it gets more effecient. The main jet size goes from 117.5 to 130 and the final gearing gets a bit taller.
When I first got my bike it had a 47 on the rear. I've kept that and didn't think that much about it.
The final drive ratio I am using is: 15/47. (3.3333) and this is about a 4 % increase in ratio (which is just about equal to 1 tooth at the rear sprocket...smart men those Suzuki guys) from the 15/48 that I SHOULD be using per the service manual....so I'm already a 4% overgeared.
Took a look at all the internal transmission ratios......no change across the board for any model DR750 or 800.
Why the big change in the way the bike felt?
I kept looking through the manual and found......AHA !
When the bike got built into the SR43 (with the larger airbox) the PRIMARY DRIVE also changed.
The primary went from a 62/32 (1.937:1) on the SR41 and SR42
To a 61/33 (1.848:1) on the SR43
This is about a 4.5% increase
This gives me a total increase of about 10% in final drive rations.
You are all saying .....
"THAT'S WHY THE BIKE WON'T PULL TOP REVS IN 5TH GEAR...DUMMY !"
Yes, I've been quite insensitive and while I'd like to think that I'm a rider much more attuned to his bike, I have to use the excuse that the bike was out of service for the better part of 6 weeks during which time I've spent a lot of time getting retired from my job, wading through retirement system paperwork and getting muddy on my DRZ400 to relax. The transition back to the "big bikes" is always a bit of a change to my riding.
And I mistakenly wrote the difference off to the engine transplant (for some magical reason) and the new tire (except that the tire would have to be GIANT to account for this much gearing change)
At least THAT mystery is cleared up.
Now for the latest jetting (cause I know Mait at least is watching this)
First thing yesterday I installed a Laser Pro-Duro silencer (that I got when I bought the SR43) It's the one that states : "Not for road use". A test ride with that silencer made no difference (other than more noise) than the performance with the GSXR silencer. This data using only top speed figures and my butt-dyno.
So at least I know that the GSXR silence was not being overly restrictive (or maybe that the Laser is just equally as restrictive).
Then.....reasoning that Suzuki used 117.5 mains in the standard SR42 AND that my internet searching showed the GSXR silencer actually needing smaller mains when used on the DR650 bikes.....
..... I went back to the standard recommended jetting for the SR42 (800cc engine in the 750 frame with smaller airbox) which is:
Using 117.5 mains. and the rest of the standard jetting listed in the manual for the SR42.
There was actually improvement with this:
The bike will now pull quickly to just above 6200 rpm in top which is the best I've done so far. (The richer mains kept the revs at about 5500 and would slowly climb to about 5800 from there.) There is no lean surging and no detonation (atleast none that I can hear at that speed or when running through the lower gears at large throttle openings)
My goal is not to have the bike go as fast as it can, rather I was using top speed as an indication of correct jetting with the engine transplant and the addition of the GSXR silencer.
What have I learned.......
(a) If I want the bike to have a bit more power (like the standard SR43) I have to improve flow into and through the SR41 airbox.
(b) When adding the GSXR silencer you PROBABLY do not have to change jetting. I'm adding the word PROBABLY here because I do not have any scientific evidence that the bike is running as well as it can right now.
Essentially, it's taken me a week to discover everything the Suzuki engineers found in about an hour while updating this machine.
I plan to still do a bit better. I've been talking with "Motolab" here. He has a dyno and all the super scientific gadgets necessary to evaluate fueling and is about 80 miles away from me.
So the next step is a trip to him for the final assessment.
For now......I'm going to leave the bike alone (to the relief of my wife) and just ride it.
I rather like the tall gearing. 1st is still low enough for most off-road stuff that I get this big bike into. The bike runs easily with the taller gears at road and motorway speeds (4000-5000 rpm which it where it seems like it likes to run anyway). I do not need a bike that will go over 100mph for any reason.
It remains to be seen if mileage will improve over the 42-45 (mpg) I was getting with the 750 engine. I've rather burned though a half tank of fuel doing testing so I'll assess mileage figures later.
Apologies for this being so long but there is some information in it that was a revelation at least to me and I hope others find this helpful.
Thanks to Rob and everyone who has offered suggestions and advice. Now it's time to start work on stripping the SR41 engine....lots to do
Ladder106 screwed with this post 02-08-2013 at 07:43 AM
Old 01-31-2013, 12:51 PM   #14036
Bambi
Bambi's Avatar
Oddometer: 487
Hello guys,
may I ask you to step a bit closer and would you please line up? Cause I'm going to tell you a little secret: It's Lars' (evildent resi) birthday! Ok, in Germany the day's nearly over now. So would you please join the international chorus of Big-riders around the world:
For he's a jolly good fellow, for he's a jolly good fellow, for he's a jolly good fellooooooow - which nobody can deny!
Which nobody can deny, which nobody ...
Thanks, guys, and a big applause for your (nearly ) nice singing ! And I can surely tell you, that he is a jolly good fellow, trust me.
So kind regards and congratulations to him and Mela, his beautiful lady, hopefully from all around the world, lead by Iris (my beautiful lady) and me, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 01-31-2013, 02:33 PM   #14037
mark618
Oddometer: 4
Wicked DR Virgin
Hello to all interesting forum. I have recently become the proud owner of a 1988 DR 750. Bit of a project so I don't have to endure appaling TV. The bike has a tank form a 450 I think anyway it is split and looks far too small. Need to replace it but not easy to find in the UK. Is there an aftermarket tank that will fit, such as the acerbis on NAVE's lovely looking bike. Any help gratefully received.
mark618 is offline   Reply With Quote
Old 01-31-2013, 03:29 PM   #14038
Ladder106
Ladder106's Avatar
Oddometer: 4,268
HAPPY BIRTHDAY LARS !!!
Old 01-31-2013, 08:23 PM   #14039
Puddle
Oddometer: 112
Happy Birthday Lars...and if we missed it, celebrate it again!
Puddle is offline   Reply With Quote
Old 01-31-2013, 10:44 PM   #14040
Resi
Resi's Avatar
Oddometer: 194
Send a message via Skype™ to Resi
*blush*
Many thanks guys!
Cheers,
Lars
Resi is offline   Reply With Quote
Times are GMT -7.   It's 04:19 AM.
