Old 02-19-2013, 11:16 AM   #14086
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,975
Thanks Lars,
Are the two pins that engage the sprocket different diameters? Or is this just a trick of the photo?
Also, in making this work, is it sized so that the plate contacts the crankshaft to prevent it from spinning or sized to contact the inner part of the engine case?
Any tricks to having it engage the upper/rear balancer shaft sprocket. With the cam drive sprocket also there, this one seems the most difficult.
Ladder106 is offline   Reply With Quote
Old 02-19-2013, 02:51 PM   #14087
Resi
Resi's Avatar
Oddometer: 211
Ray,
these two pins are at 6mm diameter.
The flat bar is just fitting into the case on both balancer chain wheels, the inner diameter is large enough to get an impact driver socket through.
Cheers,
Lars
Resi is offline   Reply With Quote
Old 02-20-2013, 05:07 AM   #14088
robmoto
robmoto's Avatar
Oddometer: 3,848
Sorry for the delay Lars, this is the airbox cover I made about 6 months ago works a treat I am still using the original battery box holder so there is no relocating the electricals.
The CDI unit is where it is because the bike had a drum brake and now a disc brake and I needed to move the CDI to mount the rear brake resivior.
I am using a small battery under the air filter ,
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 02-20-2013, 05:12 AM   #14089
robmoto
robmoto's Avatar
Oddometer: 3,848
whoops wrong picture Lars that was a pic of your mesh insert and new end I made for that muffler we got of ebay. .
Here are the right ones I am a bit rusty at doing photo,s sorry you blokes,
Old 02-20-2013, 05:13 AM   #14090
robmoto
robmoto's Avatar
Oddometer: 3,848
Old 02-20-2013, 05:14 AM   #14091
robmoto
robmoto's Avatar
Oddometer: 3,848
Old 02-20-2013, 05:16 AM   #14092
robmoto
robmoto's Avatar
Oddometer: 3,848
Old 02-20-2013, 05:17 AM   #14093
robmoto
robmoto's Avatar
Oddometer: 3,848
Old 02-20-2013, 05:19 AM   #14094
robmoto
robmoto's Avatar
Oddometer: 3,848
Old 02-20-2013, 05:22 AM   #14095
robmoto
robmoto's Avatar
Oddometer: 3,848
Here are a few pic,s of Old Blue getting the restore make over treatment, Robmoto style .
Old 02-20-2013, 05:24 AM   #14096
robmoto
robmoto's Avatar
Oddometer: 3,848
Old 02-20-2013, 05:25 AM   #14097
robmoto
robmoto's Avatar
Oddometer: 3,848
Old 02-20-2013, 05:27 AM   #14098
robmoto
robmoto's Avatar
Oddometer: 3,848
Old 02-20-2013, 05:28 AM   #14099
robmoto
robmoto's Avatar
Oddometer: 3,848
Old 02-20-2013, 05:30 AM   #14100
robmoto
robmoto's Avatar
Oddometer: 3,848
Times are GMT -7.   It's 08:28 AM.
