Old 02-20-2013, 04:32 AM   #14101
robmoto
robmoto's Avatar
Oddometer: 3,858
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 02-20-2013, 04:33 AM   #14102
robmoto
robmoto's Avatar
Oddometer: 3,858
Old 02-20-2013, 04:34 AM   #14103
robmoto
robmoto's Avatar
Oddometer: 3,858
Old 02-20-2013, 06:58 AM   #14104
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,997
Lars,
You certainly have some sort of magic. You've gotten more photos out of Rob in one go than his entire total since he's been on the thread. Well done.
Rob, thanks for the photos.
Refresh my memory on one point. On your Green/Yellow bike you are using the CR carbs from Stefan, correct?
Did you ever try that airbox with the standard CV carbs?
The photos illustrate just how many items Suzuki managed to cram into a very small space.
Ladder106 is online now   Reply With Quote
Old 02-20-2013, 07:22 AM   #14105
Resi
Resi's Avatar
Oddometer: 211
Originally Posted by Ladder106 View Post
Lars,
Resi is offline   Reply With Quote
Old 02-20-2013, 04:38 PM   #14106
robmoto
robmoto's Avatar
Oddometer: 3,858
Ray the yellow bike I now am using tm 36 mikuni pumpers.
Before these I used the BST 33,s and no air box at all at that stage the bike was a 750 I lost a little bottom end but gained a bit on the top end as was running a open pro duo and large header pipe the bike went quite well and earnt the name the yella terra .
robmoto screwed with this post 02-20-2013 at 04:45 PM
Old 02-20-2013, 04:58 PM   #14107
robmoto
robmoto's Avatar
Oddometer: 3,858
My belief is to keep the volume between the carbs and the air cleaner the same as the volume and bigger than the bore and stroke ,I used a DR 650 foam filter but ended up taking off the filter skin.
This filter must be be similiar to the air intake of a standard paper job to keep the over all vacume the same, more air at the top end revs won,t bother the 33,s Early in the piece HRT ran a 650 filter in a air box with the whole side cut out so I thought I would try that as a starting point thingy.
Old 02-20-2013, 05:05 PM   #14108
robmoto
robmoto's Avatar
Oddometer: 3,858
Ray if you at at page 940 one of the pic,s I just posted of the blue bike you will see the air box and filter cage but no paper , I made a foam filter to fit inside works ok and not looking for massave amounts of performance I think it is as good as standard job but at least I don,t have to remove a tank to get it out and clean it very versatile .
Old 02-21-2013, 11:52 AM   #14109
aapo
aapo
aapo's Avatar
Oddometer: 159
I'll have new valves (all four) top end gasket set and new piston in few weeks. Piston is 2nd oversize (100) with rings from hessler (like other parts too).
Valves will be third set (when counting originals too) in this engine. Shlould i change valve guides (or how they are called) too? Is there a way to check it easily? i need to take it some shop anyway with cylinder, but it woul be good to have all parts ready.
I start to regret i sold the cylinder head from donor 800 engine
Rockers and cam have been changed some 40 - 50 000 kms ago, seemed not new but ok.
-aapo
-aapo
DR 750S 1989
http://picasaweb.google.com/aapo.saari
aapo screwed with this post 02-21-2013 at 11:53 AM Reason: typo
aapo is offline   Reply With Quote
Old 02-21-2013, 12:09 PM   #14110
jabroka
jabroka's Avatar
Oddometer: 338
great pics Rob!!
a few of mine with new additions.. quick throttle & aluminum skid plate
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka is offline   Reply With Quote
Old 02-21-2013, 12:35 PM   #14111
spen
on my arse
spen's Avatar
Oddometer: 346
Just putting up a quick wanted AD i need the two top 19mm nuts that are on the top of the forks (sr41 sr42 ) mine have been badly rounded ,So if you have a scrap set of forks I"ll buy the top nuts from you .Thanks If someone needs another part we could do a swap !! i have some spares
spen screwed with this post 02-21-2013 at 03:40 PM
spen is offline   Reply With Quote
Old 02-21-2013, 09:21 PM   #14112
robmoto
robmoto's Avatar
Oddometer: 3,858
-aapo
Just a little tip for you , only use suzuki valve stem seals, the after market ones go hard in no time.
3 sets of valves why , maybe tappet settings could be a little tight, and or runnung a little lean, have a look at the colour of the carbon on the valves may help you determin whats going on.
Old 02-21-2013, 09:26 PM   #14113
robmoto
robmoto's Avatar
Oddometer: 3,858
Jabroka , long time no here since the trip to suthh aaafrica, Its good to have a bit of use full bling , I still like that muffler with the colour co/ordination .
Old 02-22-2013, 12:31 AM   #14114
aapo
aapo
aapo's Avatar
Oddometer: 159
I've used only suzuki valve stem seals and orginal mikuni parts in carbs, learned that hard way...
original valves were replaced when there was some 60 000km in clock, also pistone was replaced by first versize 050 then. I rebuild engine bottom at 85 000 km (if rebember rigt) the top end was like new.
No I have damaged cylinder (heavy oil consumption) and damage in valves. And yes, there were some carburetor problems and some serious overheating while offroading... i was riding too lean.
So i think your dianosis is right.
I'm just wondering how long these valve stems last? Seals for those are easy to change but stem itself reguires some professional help.
-aapo
DR 750S 1989
Old 02-22-2013, 01:35 AM   #14115
robmoto
robmoto's Avatar
Oddometer: 3,858
Appo ,when I bought my orange bike it was in very poor condition but still was rideable the piston would knock something terrible untill it warmed up I am just giving you an Idea how things were when I got it.
Now it looked like to me the head had never been of it, I did replace the exaust valves only and new stem seals on all 4 valves.
My point is this bike is running with no problems because of other work I did to the motor the valve guides have never been replaced and it has done 142k
If you can feel play in the valve there probably stuffed.
Times are GMT -7.   It's 10:01 PM.
