02-22-2013, 12:31 AM
#14116 | |
aapo
Oddometer: 123
original valves were replaced when there was some 60 000km in clock, also pistone was replaced by first versize 050 then. I rebuild engine bottom at 85 000 km (if rebember rigt) the top end was like new. No I have damaged cylinder (heavy oil consumption) and damage in valves. And yes, there were some carburetor problems and some serious overheating while offroading... i was riding too lean. So i think your dianosis is right. I'm just wondering how long these valve stems last? Seals for those are easy to change but stem itself reguires some professional help. |
02-22-2013, 01:35 AM
#14117 |
Oddometer: 3,267
Appo ,when I bought my orange bike it was in very poor condition but still was rideable the piston would knock something terrible untill it warmed up I am just giving you an Idea how things were when I got it.
Now it looked like to me the head had never been of it, I did replace the exaust valves only and new stem seals on all 4 valves. My point is this bike is running with no problems because of other work I did to the motor the valve guides have never been replaced and it has done 142k If you can feel play in the valve there probably stuffed.
I ride alone and not a KTM in sight . |
02-24-2013, 09:28 AM
#14118 |
Oddometer: 11
Front wheel bearings
Hello people
Can anybody remember the odd front wheel bearing size? Some bikes use an identical pair and some (mine included) run a smaller diameter but wider bearing in one side. Last time I made it up from two thin ones. I can't get in the garage to measure it at the moment. Thanks guys |
02-24-2013, 05:25 PM
#14119 |
Oddometer: 255
well i finally got around to cutting the side out of a spare filter and seeing if it makes a difference.
after i cut out the triangle, i ran a bead of silastic around the cut edge to make a rounded profile to reduce turbulence. this mod is worth doing along with 125 mains and richening up the needle. with the jetting mods and stock filter there was a slight increase in performance but was still flat up top. after the filter mod, this thing pulls hard all the way to 148k/ph and was still pulling hard but i was running out of road this is a definite improvement. i thought the old girl might be getting a bit tired but after today i think she still goes allright![]() Rob, that yellow bike of yours must be impressive
fear causes hesitation and hesitation will cause all your worst fears to come true. DR750 BIG KTM 450 EXC |
02-25-2013, 02:38 AM
#14120 |
Oddometer: 3,267
Gidday Simon, she,s a goer mate, hey there are about 10 or so blokes staying here friday night the 15th to Sun sun the 17th with a ride on the sat 16th remember last year we called it the Turon River Classic .
Are you comin over give us a ring and I will give you the details.
02-25-2013, 11:05 AM
#14121 |
Oddometer: 227
Camshaft question
Any of you guys knows if SR43 camshaft will fit into SR42 head and do its job there?
I know the timing and lift is a bit different but other than that? |
02-25-2013, 11:12 AM
#14122 |
It's a short cut, really
Oddometer: 4,268
As far as I know they are identical for fit and use.
The exception is the "A" style cam from the UK that has a bit earlier intake timing than the "B" style from Germany. I think you get a few more HP with the "A" style. it should be stamped on the cam end where the cam timing marks (that line up with the head casting) are located. |
02-26-2013, 01:22 AM
#14123 | |
Oddometer: 255
how is the river? have you had the sort of rain we have had east of the range? the rivers ar raging over this way.
02-26-2013, 03:13 AM
#14124 |
Oddometer: 3,267
Simon not much rain over here really we are missing out, although not bone dry.
02-26-2013, 03:18 AM
#14125 |
Oddometer: 227
Camshaft
Thanks Ray. This is what I thought myself, too. Why did I ask it was because SR43A camshaft is still available as Suzuki original part. While SR42A camshaft is superceded and replaced by SR43B type camshaft AFAIK.
I have DR800 SR42B and the idea was to release some more potential from the engine with less restrictive "A"-model camshaft. If you know of any reason why these two (SR42B engine and SR43A camshaft) should NOT be joined together in holy DR Big, speak now, or... I may be screwed I think I've read in German Big forum (with the help of google translator) someone had SR43 camshaft in SR41 for a year without problems, so it should be working fine in SR42, too. BTW the 106mm pistons are not ready yet. I have no idea why it is taking so long. Or maybe its just me being impatient. |
02-26-2013, 04:42 AM
#14126 |
Oddometer: 37
Perhaps it's a good time to discuss this publicly rather than ask mait in private
![]() To add up to his question: Since my camshaft is worn beyond recognition (ok, i may be exaggerating a bit here) and I am still considering multiple options on what to do with it. Does anyone of you know if one can use a brand new SR43A camshaft (12711-31D00 ) on a SR43B (in a perfect world the camshaft should be 12711-31D10) bike with SR43B CDI (32900-31D10) (again, in a perfect world A camshaft should go with A cdi (32900-31D00))? That is taking in mind the differences between the camshafts and cdi (different timing). PS as an alternative, I am considering using local camshaft restoration services from a reliable shop, they do that for 72 eur (that includes restoration of camshaft and 2 rocker arms). On the downside - I don't think i would be sleeping as calmly with this restoration as with HRT services, but the difference in price (and transport) is playing a big role here. |
02-26-2013, 04:43 AM
#14127 | ||
Cheers, Lars |
02-26-2013, 11:10 AM
#14128 |
Oddometer: 227
Lars, 5 weeks to make the pistons was what I was told, too. I think we are in the middle of week 5 now. I'll shoot them an e-mail tomorrow.
About camshaft - I think I'll give it a try to put SR43A camshaft in SR42B. I am quite sure there will be no mechanical conflict. Like Wundis already pointed - I am curious too how the camshaft will act with different CDI (read: ignition timing) it was not designed to work with. I suppose it shouldn't be a problem, since many aftermarket cams are produced for BIGs and they don't care if it goes into SR41 or SR43, A or B model AFAIK. And then there is another possible mod called tunable CD Ignition which allows you to design your own ignition curve in your computer I hope these guys are still in business: http://www.ignitech.cz/english/aindex.htm Look for section "SPARKER DC-CDI - capacitive ignition for 1 cyl. motorbikes" on their site. I am not too serious about this mod right now but the idea has haunted me since I read SR43 had different ignition curve. OK, over and out now. I think I am just overthinking and should get working on the bike finally. Snow is already melting here... |
02-27-2013, 12:08 AM
#14129 |
02-27-2013, 05:16 AM
#14130 | |
aapo
Oddometer: 123
This is interesting choice for SR41 owners, since SR41 stator is avilable only from suzuki, €€€€ . or then just re coil old one....-aapo |
