Old 03-13-2013, 10:20 PM   #14191
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,258
I'd open that garage door a bit more, mate
Ladder106 is offline   Reply With Quote
Old 03-14-2013, 12:18 AM   #14192
Resi
Resi's Avatar
Oddometer: 194
Send a message via Skype™ to Resi
Originally Posted by aapo View Post
HI,
Any suggestions for 2component glue etc. for covering stator coils? I'm about to rebuil stator.
Neeed to be resistant for DR's very hot oil...
I'd suggest an epoxi 2k resin like Araldit e.g.
Cheers,
Lars
Resi is offline   Reply With Quote
Old 03-15-2013, 02:21 PM   #14193
MrPopples
Oddometer: 24
Hey guys :)
still havn't found a good deal for a used fork to put on the DR Big ...
but I think I have something for the rear shock :)
I found a Buell XB12 Ulysse shock, brand as new, for 50 bucks ...
only problem, the Uly shock is 390mm long and the DR Big is 410mm long.
I'm wondering if that is a "big" problem, since the shock might be more progressive and might even make the DR keep the same balance ... as my shock is 80 000 kms old and never had any refurbishing.
it seems rather hard to find a used shock that is 410mm long?
MrPopples is offline   Reply With Quote
Old 03-15-2013, 02:52 PM   #14194
Simosez
Simosez's Avatar
Oddometer: 244
Originally Posted by MrPopples View Post
Hey guys :)
20mm is a long way to drop the arse. this will rake out the front end and make it handle like a wheelbarrow.
i used a shock from a 1992 husaberg. it needed some modifying though.
i cut off the reservoir and remote mounted it with a hose and used the heavy DR spring from hessler. cost me about $300 all up and a pretty good result.
your other option is the wilburs shock which from all reports is a very good bit of gear if you can afford it.
fear causes hesitation and hesitation will cause all your worst fears to come true.
DR750 BIG
KTM 450 EXC
Simosez is offline   Reply With Quote
Old 03-19-2013, 01:44 AM   #14195
aapo
aapo
aapo's Avatar
Oddometer: 123
HI,
Has anyone put wide band lambda to exhaust system in DR big? Any good locations or component suggestions. I'll just try to get rid of speculations with lean / rich issues. (when i will get the engine back together)
-aapo
-aapo
DR 750S 1989
http://picasaweb.google.com/aapo.saari
aapo is offline   Reply With Quote
Old 03-19-2013, 02:28 AM   #14196
Resi
Resi's Avatar
Oddometer: 194
HI,
-aapo
Hi,
I put these sensors in my headers as shown here:
Cheers,
Lars
Old 03-19-2013, 03:57 AM   #14197
ausibatla
ausibatla's Avatar
Oddometer: 415
DR800 for sale
If anybody is interested in my '91 DR800 then let me know by private message or email. I can send photo's or post them. Or you can check out the bike on Photobucket.
http://s571.photobucket.com/user/aus...80788297214483
The bike has only done 8748kms since new. I have registration papers to prove it. I have also found out that it is the only registered DR800 in Western Australia. I want $6000 for it so if you're in Perth or W.A. and you want to check it out let me know.
Cheers.
Youth's a mask but it don't last
Live it long and live it fast
DR 800 DR750
ausibatla screwed with this post 03-19-2013 at 04:23 AM
ausibatla is offline   Reply With Quote
Old 03-19-2013, 04:06 AM   #14198
aapo
aapo
aapo's Avatar
Oddometer: 123
Originally Posted by Resi View Post
Hi,
Cheers,
Lars
Thanks! this is very informative picture. Was it difficult to weld? What plug or adapter did you use?
-aapo
-aapo
DR 750S 1989
Old 03-19-2013, 06:45 AM   #14199
Resi
Resi's Avatar
Oddometer: 194
I built this adaptor on my own, made out of 1.4301 stainless steel.
No probs with welding :)
Cheers,
Lars
Old 03-19-2013, 10:59 AM   #14200
aapo
aapo
aapo's Avatar
Oddometer: 123
Cheers,
Lars
Ok ;)
-aapo
-aapo
DR 750S 1989
Old 03-20-2013, 02:46 AM   #14201
shanekfalcon
shanekfalcon's Avatar
Oddometer: 115
Hi everyone,
Its been months since I last posted as I've been away on a few trips and so on. Anyhow I thought that I would let you all know how the DR800 is going.
After a stay at Rob's place, the mechanicals are working very well; Rob did a great job fixing things due to age and also problems created by my own ignorance. I did have a small electrical problem develop but by following Rob's advice, I took the rhs tank off and found the short. Its now working well.
Went on a 250 km round trip up the highway and to a local biker cafe, The Bellbird Cafe in Kenilworth and the bike ran extremely well. Still some fine tuning to go such as some grip puppies to increase the diameter of the grips, perhaps some aftermarket levers; that sort of thing. I've lent the car to a friend for a month or so and will use this bike for a daily rider for two weeks and then swap with the V-Star for two weeks etc. Bottom line though, the 800 is great to ride and working well.
shanekfalcon is offline   Reply With Quote
Old 03-20-2013, 04:38 AM   #14202
robmoto
robmoto's Avatar
Oddometer: 3,244
I ride alone and not a KTM in sight .
robmoto is offline   Reply With Quote
Old 03-20-2013, 10:28 AM   #14203
Ladder106
Ladder106's Avatar
Oddometer: 4,258
Vibration Control
I've been working trying to get the vibration on my SR41 (with the SR43 engine) under control for the past few weeks.
I've finally got the jetting mostly sorted and the bike runs well in all gears.
I changed the final drive to a 15/49 since the SR43 engine has a higher primary drive ratio this give the same gearing as the SR41 with 15/47....or very close to it. This has made the bike much easier to ride and made the ratios much more useful.
Anyway.....Vibration.
I'm using Renthal Carmichael High bend 7/8 in bars on my bike.
The main factor I found in smoothing out the handlebar vibration on the SR41/42 is the state of torque on the nut attached to the handlebar clamp stud underneath the top triple clamp.
Tightening this nut down hard will transmit much more vibration into the bars.
The best solution I found was to loosen the nut down to the cotter pin (that's what the hole in the stud if for if your bike is pin-less).
Stradling the bike push the bars forward and backward. There should be very obvious PLAY in the system.
Then tighten the nut (use of nylok or self locking nuts is important here) to the point that this play in the bars just disappears...add about 1/2 turn more and leave the nut there.
Barkbusters:
Everytime I put the barkbuster/lever protectors back onto the bars the Vibration increased dramatically.
Combinations:
I played with different combinations of
(a) Barkbusters using both Cycra and Acerbis models
(b) DRZ400 bar end weights (generally free at most Suzuki shops if you know the guys....found in a oil stained box next to the recycling bin)
(c) Ricor Vibranators (vibration reducing harmonic system)
After trying all the above combination/permutations of the above, I found that my bike was smoothest with:
DRZ400 bar end weights and NO barkbuster/lever protection and NO Vibranators.....just the weights. In fact I'm putting the standard Suzuki handguards (plastic only mounts to the lever pivots) from my SR43 back on this bike and will try to find a pair of Suzuki SR41/42 handgurads in the future.
Of course, your experience may vary depending bar type used and your tolerance (or lack thereof) to vibration. I'm not saying that this makes the Big feel like a Goldwing but it lets me ride the bike without my hands going numb.
Hopefully this will help
Old 03-20-2013, 02:01 PM   #14204
the_sad_punk
the_sad_punk's Avatar
Oddometer: 348
....so no joy with vibranators then? Worked wonders with my dakar high bars.
the_sad_punk is offline   Reply With Quote
Old 03-20-2013, 05:50 PM   #14205
Ladder106
Ladder106's Avatar
Oddometer: 4,258
The vibranators worked best at low revs like 2500 - 3500 but not 4-5 thousand where I spend most of my road time.
They helped when I had the SR41 engine in the bike but I'm better with the DRZ400 weights with the SR43 engine.
The SR41 engine will be taken down and rebuilt soon so I should be back to normal (at least what I consider normal) fairly soon.
But for now, this is what I found. Experimentation does provide benefits as there are many variables involved. My solution is likely not for everyone but if you don't like the way your bike feels, play with some things. Make one change at a time and eventually you'll find a solution.
Times are GMT -7.   It's 03:36 PM.
