Old 03-27-2013, 07:34 PM   #14236
spen
on my arse
spen's Avatar
Oddometer: 346
Wicked
Only if you want a spark
spen is offline   Reply With Quote
Old 03-29-2013, 04:49 AM   #14237
Silent Hunter
Silent Hunter's Avatar
Oddometer: 101
Originally Posted by the_sad_punk View Post
Selling off a few bits
Shock with 24k kms on was working as fine. Powder coated spring. Painted body.
30 GBP
Brank new and unused EBC disc,
Used oem disc, plenty life left
Refurbed Header, perfect order
Refurbed fork brace for under the mud guard
Powder coated bars, very slight bend on left hand side
Two spots H4
65 GBP
Hi sad Punk,
I am interested in the header, but will it fit the older 41 DRs made in 1990?
Mine is a SL model that has the Big750 body but the 800cc engine.
What's your bike's make?
Now on to the lithium battery part.
I got a Shorai Lithium ion battery (the biggest model- LFX18A1-BS12) and it won't fit into the battery compartment if I were to put it in the right side up.
But there was plenty of room if I slot it in side ways, with the -ve end at the bottom of the battery compartment and the +ve end at the top.
Cranking power is significantly better when compared to the lead batteries. I got at least 12 good cranks out of it before I noticed a drop in power. But after that the battery got weaker fast. Got another 6 or 7 cranks before the battery was too weak to do a proper crank.
The standard lead battery can only give 6-7 good cranks before it runs out of juice.
Bad news when the bike won't start and I was troubleshooting the carb.
I ended up push starting for every turn of the screw.
Motorcyclists are the nicest people on the road, try not to kill us.
Silent Hunter screwed with this post 03-29-2013 at 04:57 AM
Silent Hunter is offline   Reply With Quote
Old 03-29-2013, 02:04 PM   #14238
the_sad_punk
the_sad_punk's Avatar
Oddometer: 353
PM sent Silent Hunter.
The shorai battery is something im considering buying for one of the bikes. Let us know how you get on with it. Did you buy thier charger for it too? I believe you cannot use a standard trickle charger on it?
the_sad_punk is offline   Reply With Quote
Old 03-30-2013, 02:04 AM   #14239
Silent Hunter
Oddometer: 101
I got mine from the local dealer.
I goggle the local dealer address and number from the Shorai main website.
The guy just started business in Singapore and I was his first customer!
The dealer Kelvin wasn't ready for business until April. But I ordered mine from him anyway, so he did an early bird order for me and a few other people who called in and gave us a 5% discount.
If you are getting a Shorai battery, it is best to find a local distributor. That way you get the 1 year warranty after the purchase.
As for the charger, I just bought a generic one from this guy from eBay.
http://www.ebay.com/itm/320715017864...84.m1438.l2649
Used it once to recharge the Battery after the battery went flat from my experiment on how many times the battery can crank.
And once again after I tuned the carb. Works ok so far. Charging time is a bit long. Roughly 5-6 hours for a flat battery. 3 hours for a partially discharged battery.
If you are getting a non-Shorai charger make sure the charger DOES NOT have the de- sulphurication mode.
That mode will charge the battery above the safety voltage.
Silent Hunter screwed with this post 03-30-2013 at 02:09 AM
Old 03-30-2013, 03:15 AM   #14240
robmoto
robmoto's Avatar
Oddometer: 3,878
Anti Gravity, is the lithium battery I use, its about at least 50 percent smaller than the stock one and about a third the weight, it has about 130 cranking amps from memory.
The instructions say that the battery operates best if the bike don,t start to leave it a few minutes before cranking again as the battery will heat itself and give out more charge the warmer it gets the better cranking .
Silent Hunter if your battery and the size of it rather large too, and starting to die after 7 cranks maybe you got some troubles with starter motor brushes in the very near future . some thing don,t sound good to me .
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 03-30-2013, 06:33 AM   #14241
Silent Hunter
Oddometer: 101
Not a chance Robmoto.
I replaced the entire starter motor in 2010.
The lead battery is the problem. From what my mechanic told me, the Yuasa batteries were no longer made in Japan. Thus, the low quality. Farther more, the batteries were old stock and probably had corroded lead plates when it left the warehouse.
By the way, the Shorai LFX18A1-BS12 is the biggest one they got. It has a whooping 270 CCA (Cold Cranking Amp)
Width is 2mm broader than the lead battery, but length and height are much much shorter, so it can still fit into the battery compartment by rotating it sideways.
Silent Hunter screwed with this post 03-30-2013 at 07:32 AM
Old 03-30-2013, 05:25 PM   #14242
robmoto
robmoto's Avatar
Oddometer: 3,878
The Antigravity lithium 8 cell 240 CCA is what I use in my 800 yellow bike and found it to be very good so far my mistake I did say 130 CCA my mistake.
I was using the Oydesy PC 310 which is 100 CCA a bit gutless really.
I bought a motobatt MBTX14AU and found these are good for cranking, bought one locally they wanted 150 bucks got it for 130 thought this was good it has now shit itself after 15 months maybe old stock or something .
I now have found a place called http://www.batteriesdirect.com.au/
and they sell them 70 bucks 12 postage so I thought I will try this brand again as it did crank the big over quite good , for any one else they sell or the different brands and the prices is right.
Old 03-30-2013, 11:08 PM   #14243
onyajonesy
onyajonesy's Avatar
Oddometer: 24
Japan trip
HI ALL, I AM OFF TO JAPAN NEXT WEEK ANY INFO ON THE DR-BIG CLUB.I DID TRY TO CONTACT THEM BUT NO RETURN MAIL... I WILL GO TO HAMAMATSU TO CHECK IT OUT... ANY LEADS WOULD BE GOOD.. CHEERS AND SAFE AND HAPPY EASTER....CHEERS
WHEN IN DOUBT...STYLE IT OUT. BE COOL
onyajonesy is offline   Reply With Quote
Old 03-31-2013, 01:14 AM   #14244
mait
mait's Avatar
Oddometer: 333
Antigravity
Rob, have you already had a chance to try out Antigravity 8-cell battery in cold weather morning conditions? I mean temperatures around 0 degrees Celsius or 32F and the bike been standing outside whole night.
mait is offline   Reply With Quote
Old 03-31-2013, 01:25 AM   #14245
Longdude
Tall Geezer !
Longdude's Avatar
Oddometer: 62
I've done this much...............
And yes, the Michelin fork decal is the wrong way round (sorting that out soon, lol )
http://motorcyclerestorationuk.activeboard.com/
Suzuki DR 800 BIG / Triumph Tiger 955i.
Longdude is offline   Reply With Quote
Old 03-31-2013, 01:25 AM   #14246
StefanS.J
Hellre än Bra!
Oddometer: 27
Pressies
Originally Posted by Ladder106 View Post
.........also..............
I found out today that my family has ordered a new Wilburs shock as my Christmas gift.
The factory called to get weight, riding style etc today and my wife couldn't answer all the questions so they had to give up on the surprise factor.
Don't mind at all
He He He
StefanS.J is offline   Reply With Quote
Old 03-31-2013, 01:32 AM   #14247
Longdude
Tall Geezer !
Longdude's Avatar
Oddometer: 62
You lucky man ! I, having 'no money', have settled for a Hessler rear spring, I went for a heavy industrial spring, to carry my huge body
Old 03-31-2013, 02:15 AM   #14248
robmoto
robmoto's Avatar
Oddometer: 3,878
Yep have tried it in cold weather -5 C mind you my 800 has pumper carbs, just full choke 2 hits on the throttle , it only turns over twice and bingo she,s a goer, I have been using this battery for at least a year now, seems just fine to me.
I have a delvic battery in the motard, It was in it when I bought it, I have had that bike for about 4.5 years so it could be maybe 6 years old and it cranks real good but it is a full size one and heavy, when it shits itself a Antigravity will take its place even though I have a spare PC 10 sitting on the shelf.
What ever you do DON,T by a roadstar normal old lead acid battery there CRAP.
Old 03-31-2013, 02:41 AM   #14249
robmoto
robmoto's Avatar
Oddometer: 3,878
Lucky you have a HUGE body . I bought one and put it on a standard shock and found that there was too much rebound for in the bush.
But I do run one on my orange 750 that I go away on riding on tar only with all the camping gear grog etc, and found it good.
trying to put a pic up for you don,t know if this will work
Old 03-31-2013, 05:20 AM   #14250
Longdude
Tall Geezer !
Longdude's Avatar
Oddometer: 62
Nice.....
Great looking bike you have Rob. I'm 6'6" tall so the bigger the BIG the better
My rebuild is on here :
http://www.drbig.info/forum/viewtopic.php?f=7&t=1239
It runs to seventeen pages so far, and that's just taking the rear wheel out
Times are GMT -7.   It's 08:28 PM.
