Old 04-27-2013, 05:47 AM   #14386
Resi
Resi's Avatar
Oddometer: 211
@Spen: Did I mention that your DR's looking real good?!
Cheers,
Lars
Resi is offline   Reply With Quote
Old 04-27-2013, 09:44 AM   #14387
spen
on my arse
spen's Avatar
Oddometer: 345
See how your ss header pipe shines in the sun
spen is offline   Reply With Quote
Old 04-27-2013, 02:20 PM   #14388
Bambi
Bambi's Avatar
Oddometer: 689
Hello Resi, hello Spen,
because of that nice header and it's nice description!
And on me myself as Miss Marlboro is really back together and on the road again. Some misfiring when closing the throttle has been solved by adjusting the throttle stop on the carb (too much shut-off) and Resi's ingenious mixture screw! There's still some fine-tuning to do, but - hey - the bike is running and much quieter than before. This can be addressed to a copper-ring that I put between the connection of silencer and header under the clamp. It always looked like the clamp would close the slots of the connection comepletly and it sounded like it didn't do so. Now it does!
Kind regards, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 04-28-2013, 09:33 AM   #14389
Silent Hunter
Silent Hunter's Avatar
Oddometer: 101
Originally Posted by Silent Hunter View Post
Guys, I just changed the sprockets of my DR big to 16 front, 42 back.
The power is amazing. I was going 100km/hr at barely 3,500 RPMs.
Previously on 15 front, 45 back, the bike needs to go up to 4,000 RPMs to match that speed.
Originally Posted by Bob Herr View Post
Yeah. Check out my post 14326. I just made this mod recently and really like the result. I kept the 15 tooth front and motor is turning 3600 RPM at 100K/hr. Looks like the 16 tooth front gives you an additional 100 RPM drop.
Thanks for the feedback. I read a couple of posts saying that we should not have even numbered teeth on the gears otherwise the chain will get worn out unevenly. Does that really happen?
And does anyone have the stock exhaust end cam that they don't want? I am looking for a 2nd hand one.
Motorcyclists are the nicest people on the road, try not to kill us.
Silent Hunter is offline   Reply With Quote
Old 04-28-2013, 11:20 AM   #14390
DRhino
DRhino's Avatar
Oddometer: 13
Aprilia RSV Mille exhaust installation. The interior is rebuilt, only the mantle of the original.! Two pieces of perforated pipe 520 mm long and 48 mm diameter! The sound of hell!
DRhino is offline   Reply With Quote
Old 04-29-2013, 04:37 AM   #14391
aapo
aapo
aapo's Avatar
Oddometer: 157
Originally Posted by spen View Post
IT"S ALIVE
I stuck some petrol in a small bottle and threw some down the plug hole and after many turns it started :tup: the engine is very quiet alot more so than my 800 i was surprised as it has 77k km on it so just run in :tup: now i can get all the paint work done atleast knowing i have heard it running
Argh, should i now go and change my black painted frame back to white....
-aapo
-aapo
DR 750S 1989
http://picasaweb.google.com/aapo.saari
aapo is offline   Reply With Quote
Old 04-29-2013, 09:51 AM   #14392
p3dro
Oddometer: 30
starting problems!!
Hello all,
I am having starting problems on my DR800 (SR43)
It's been running fine until this morning - tried to start, turns over but won't fire!
The AA have just left and the man said it is probably the "ignition module" or the "crankcase sensor".
He checked the right hand spark plug and got no spark, so checked the coil and it was not getting any power so said those were the next 2 items to test but could not locate the ignition module to test and said the crankcase sensor would need to be checked by a garage as it was under the crankcase...
Does this sound correct in your experience?
The plugs are only a couple of months old. The battery is fine. He checked the fuses on the little box marked FUSE behind the battery and checked a few wire connections to see if it was a loose wire/bad connection...
I don't get any result when I search for either of these parts on a search engine and WEMOTO do not list them either...?
It seems very strange....is he making it up??
Any advice greatly appreciated!!
Thanks,
Pete
p3dro is offline   Reply With Quote
Old 04-29-2013, 10:31 AM   #14393
aapo
aapo
aapo's Avatar
Oddometer: 157
Originally Posted by p3dro View Post
Hello all,
Thanks,
Pete
Hi,
there are two sensors under magneto cover. Ignition power source coil and timimg "trigger" coil.
Both can be measured from the cables/connectors located under tank. On mobile now, so sorry, specs now...
BR:aapo
-aapo
DR 750S 1989
Old 04-30-2013, 02:15 AM   #14394
robmoto
robmoto's Avatar
Oddometer: 3,854
Have a look where the wires should be solderd on the bottom of the ignition switch.
robmoto is offline   Reply With Quote
Old 04-30-2013, 06:13 AM   #14395
spen
on my arse
spen's Avatar
Oddometer: 345
Not sure about the 43 but in the 41 /42 check the small earth wire at each of the coils ,
Old 04-30-2013, 06:36 AM   #14396
Megamoto
Yes, I do look like this.
Megamoto's Avatar
Oddometer: 2,974
Yesterday I draged Daisy out of the shed and put her through the MOT. She passed, good old girl.
Guerrilla Moto diplomacy.
Higher level simians as ambassadors of vroom to skewer ignorance and amalgamate ideas globally.
I'm so happy I could whistle through my willie. (Dan Walsh)
Unum bonum Centurio
Megamoto is offline   Reply With Quote
Old 05-01-2013, 05:14 AM   #14397
Simosez
Simosez's Avatar
Oddometer: 430
not too many of these around. shame not all the parts required to fit it are available.
http://www.ebay.com.au/itm/KICK-DE-D...item3a7b7a1e99
"Safety Turd. Because the only skid marks should be on the dirt."
"If I could get back all the money I ever spent on dirt bikes, I'd spend it all on dirt bikes."
DR750 BIG
Husaberg 350
Simosez screwed with this post 05-01-2013 at 05:31 AM
Simosez is offline   Reply With Quote
Old 05-01-2013, 08:15 AM   #14398
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,984
I would seem that more bits than the lever itself are required.
"Some assembly required" also
Ladder106 is offline   Reply With Quote
Old 05-02-2013, 01:02 AM   #14399
Simosez
Simosez's Avatar
Oddometer: 430
if only it was that easy.
DR750 BIG
Husaberg 350
Old 05-02-2013, 02:16 AM   #14400
robmoto
robmoto's Avatar
Oddometer: 3,854
Simon I spotted that a while back and thought probably the same as another model Suzuki, and also thought that the rubber looked well worn and a normal person would use the button., hence it could be a ring in .
just saying.
Times are GMT -7.   It's 08:55 AM.
