Old 05-04-2013, 07:26 PM   #14416
Jakob
Oddometer: 37
and i have another question, about an exhaust system, I want to get my bike a bit louder, but with my salary i cant afford those hessler fancy double exhaust system. So I would need a little cheaper way to do it. It has to have double mufflers as original, And it has to look good.
still haven't got a gas tank, so i'm thinking a bit tuning up my beauty.
Never ride faster than your quardian angel can fly!
Jakob is offline   Reply With Quote
Old 05-05-2013, 03:09 AM   #14417
shanekfalcon
shanekfalcon's Avatar
Oddometer: 275
Hi guys,
Now that my SR42/800S is running well, I'm slowing making it look better as well. The beak is OK, but a bit ratty. It obviously was in some form of accident and was repaired with a steel patch and nuts and bolts. I may have a line on a 1987 or 1988 DR750 that is being wrecked. DO you think the beak will fit? Colour/paint is not an issue, I can repaint no problem?
Thanks,
Shane
shanekfalcon is offline   Reply With Quote
Old 05-05-2013, 04:56 AM   #14418
Simosez
Simosez's Avatar
Oddometer: 432
yeah Shane, she'll fit. the only real difference between the 41 and 42 is the longer stroke and rear disc brake. the bike didn't lose it's rugged good looks until the SR43
"Safety Turd. Because the only skid marks should be on the dirt."
"If I could get back all the money I ever spent on dirt bikes, I'd spend it all on dirt bikes."
DR750 BIG
Husaberg 350
Simosez is offline   Reply With Quote
Old 05-05-2013, 08:14 PM   #14419
Puddle
Oddometer: 127
Rear Shock - What did you go with
Looks like my rear shock is done. Bike sags. Appears the preload has been tightened down with not much more room to stiffen it up. So if you changed your shock, what did you go with? Source? DR750 1988. Original shock is installed. Thanks everyone.
Puddle is offline   Reply With Quote
Old 05-05-2013, 10:09 PM   #14420
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,997
Sounds like your spring is done....not the shock
Although, if the spring is that bad there's likely not much damping going on in the shock proper.
For replacement, I like Wilburs. Standard shocks are usually rubbish.
They are all expensive buy once you've done it you'll find it's money very well spent
Ladder106 is offline   Reply With Quote
Old 05-06-2013, 04:57 AM   #14421
Vistar
Oddometer: 32
I saw a couple of Bigs with Ducati Monster exhausts.
Saw them in a parking lot, on a trip through Austria. Didn't see the owners, so could not ask them about it. Looks good though..
Vistar is offline   Reply With Quote
Old 05-06-2013, 06:07 AM   #14422
Puddle
Oddometer: 127
...and does anyone know the specifications of the standard shock so I can go ahead a look for a new one without having to take this bike apart? Its my daily rider. Thank you.
Old 05-06-2013, 11:42 AM   #14423
stefan rb
stefan rb's Avatar
Oddometer: 133
an other kind of DR BIG riding:
start on the GCC (German Cross Country Championship)
long time i want to do this...
have a look:
http://www.baboons.de/gallery/cross-...timer-32-59243
result: 8. place ;-)
www.hessler-motorsport.de
and the home of DR BIG:
www.dr-big-shop.de
stefan rb is offline   Reply With Quote
Old 05-07-2013, 09:08 AM   #14424
Ladder106
Ladder106's Avatar
Oddometer: 4,997
Well done !
(I thought you'd be taller )
Old 05-07-2013, 12:55 PM   #14425
mait
mait's Avatar
Oddometer: 331
It looks slimy... did you fall ?
If you didn't fall you were not riding fast enough (just kidding)
Well done, keep going
mait is offline   Reply With Quote
Old 05-07-2013, 07:46 PM   #14426
Simosez
Simosez's Avatar
Oddometer: 432
piston arrived today Mait. thanks for that. it looks fast.
DR750 BIG
Husaberg 350
Old 05-07-2013, 09:38 PM   #14427
mait
mait's Avatar
Oddometer: 331
Sorry it took so long Simon, they told me it would take 7-10 days...
Hope it will serve you good, my engine is running well so far.
Old 05-08-2013, 12:19 PM   #14428
Maxi
Oddometer: 9
Hello, I have recently a big dr 800 and have the following problem not start when turn on the button, just pulled start I understand that carburetors are vacuum may also be a factor ?? not draw fuel
Maxi is offline   Reply With Quote
Old 05-09-2013, 06:23 AM   #14429
robmoto
robmoto's Avatar
Oddometer: 3,857
Maxi on the first page you can down load a manual, go down the list and its there don,t know if it still works though, if not best to buy a paper one.
This will give you a insight for what you are in for .
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 05-09-2013, 10:30 AM   #14430
Ladder106
Ladder106's Avatar
Oddometer: 4,997
Maxi,
We may have to work through a bit of language translation here.
It would be helpful to know the year and model of your DR.
Can you describe the starting problem more exactly?
Times are GMT -7.   It's 04:54 PM.
