Old 05-19-2013, 08:09 PM   #14491
ausibatla
ausibatla's Avatar
Oddometer: 447
Originally Posted by wundis View Post
i'm confused now :/
it starts fine, works fine for 20 seconds, then starts to work like a hit n miss engine + black smoke out of the exhaust.
i've measured the float level with calipers - the lines are perfectly paralel, the level is at 14,7 mm. float level setup was made by following this link
i thought the k&n filter might be the faulty bit, but no - the stock filter does absolutely the same thing.
now when i measured the float level with the transparent hose the first time (carbs off, fuel in, tidy measurement taken) the results were +-0mm.
Now I checked the fuel level after I shut down the engine - i got surprising results, both floats were way up, like +7 mm up. how is that possible? if I bend the adjustment tab on the carbs to compensate for the +7mm , the lines won't be anywhere near parallel.
i somehow get a feeling that the new replacement needle floats (oem) have weak springs and are not able to hold up the floats in the middle point, vibration does its job and the small springs get pushed in, thus raising the floats and flooding the carbs = ergo the black smoke and shitty run.
guys, i'm stuck and i need advice. buying another set of needle valves is a true robbery. bringing back these - dont think it will work like that.
If you set the float height with the carbies level on the bench then they will be out a bit because they sit on the bike at a slight angle but 7mm is far too much because of that. Before you start pulling things apart again try adjusting the mixture screw. You might get lucky.
Cheers.
Youth's a mask but it don't last
Live it long and live it fast
'88 Harley Davidson Springer '91 DR 800 '95 Yamaha XV1100
ausibatla is offline   Reply With Quote
Old 05-20-2013, 01:05 AM   #14492
wundis
Oddometer: 78
i'm a bit sceptic about trying to solve this issue with the mixture screw... afaik the mixture screw controls the mixture whilst iddling, and its influence on higher revs is rather small.
high float level on the other hand will influence the mixture on all ranges. gonna double-post to the bst bible page.
wundis is offline   Reply With Quote
Old 05-20-2013, 02:37 AM   #14493
robmoto
robmoto's Avatar
Oddometer: 3,848
Wundis , If your floats are worn at the pivot points and the cage when the bike isn,t horizontal there would be a difference after setting float height.
Did you put new seels around the sometimes brass sometimes stainless seats, these O rings didn,t get sprayed with carb cleaner buy any chance.
How many klm,s on the bike because I have replaced floats and cages on bikes with 70k on them and these parts needed replaceing because I could not achive a correct height with the old ones .
Allso have you double checked to make sure you have the fuel lines on the correct location and not on the breather or ass up.
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto screwed with this post 05-20-2013 at 02:44 AM
robmoto is offline   Reply With Quote
Old 05-20-2013, 02:44 AM   #14494
wundis
Oddometer: 78
now that was a chaotic reply :) thanks anyway :)
i've used carb cleaner when i dissasembled everything. not after :) all o-rings are new, float cage looks straight and proper.
ill have a look at the orings again today (hopefully).
PS the bike has ~50kkm on the clock
Old 05-20-2013, 02:55 AM   #14495
wundis
Oddometer: 78
once again, the tricky bit is that when i measure the float height by pouring in fuel on carbs sitting on a bench - the level is ok. when mounted on the bike after all those vibrations - its way +. to me it looks like that small annoying spring in the float valves is too weak. the floats keep rising causing all of my problems.
i need to check if my theory is correct, must do the bench test again and tap them slightly to see if the level changes.
PS robmoto, did you compare the old floats and the new floats? could you tell what was worn visually? ive got my brothers big next to mine, i can check how his floats are... in secret of course.
Old 05-20-2013, 03:26 AM   #14496
robmoto
robmoto's Avatar
Oddometer: 3,848
All I remember is at the pivot point I could wobble it from all directions and easily see that it was a sloppy fit .
One would assume that both parts would be worn,
Have you got a inline filter as some rubbish my be stuck to the seat, yours being a SR/43 should have over flow pipes, leave the fuel on and see if it is leaking out the tubes .
Allso drain the bowls just to see if any crap has come through.
Try gentle taps with a screwdriver handle around the bowl area as one of the floats could be stuck.
Old 05-20-2013, 03:41 AM   #14497
robmoto
robmoto's Avatar
Oddometer: 3,848
SR/43 I don,t have one, but don,t they have a shaft that is connected to both enrichnes and a pull cable, if so, check that it is returning to full off when pushed to off.
Its all a process of illumination .
Old 05-20-2013, 04:50 AM   #14498
p3dro
Oddometer: 30
I'm slowly losing the will to live...
My DR800 has been at the Garage for 2 and a half weeks now.
They're still not able to get it to spark.
The generator was re-wound but no change. Next they suggested we change the cdi, I found one in Germany which is now fitted but still no joy.
I'm too scared to ask how many hours they're going to charge me for this. When I popped in on Saturday there were 5 of them crowded around the bike with electrical gizmo's trying to work it out.
I don't know if I can take any more of this.
p3dro is offline   Reply With Quote
Old 05-20-2013, 05:16 AM   #14499
Simosez
Simosez's Avatar
Oddometer: 429
do you have the manual for the bike? it goes through how to test each component quite thoroughly. test each component individually as per the book then start looking at how the system works as a whole. there are a few tricks with the big that several things need to be correct before it will start.
or you could skip town and never return
"Safety Turd. Because the only skid marks should be on the dirt."
"If I could get back all the money I ever spent on dirt bikes, I'd spend it all on dirt bikes."
DR750 BIG
Husaberg 350
Simosez is offline   Reply With Quote
Old 05-20-2013, 05:45 AM   #14500
wundis
Oddometer: 78
As Simosez suggests, go step by step - the schemes are in the manual, check the fuses thoroughly, check the cabling and contacts (especially ground) thoroughly, check the sparks, coils, high voltage cables, ignition key, ignition shut down button, clutch indicator (must be shortened), side stand indicator (must be shortened).
There have been a number of people with similar problems lately, remind me - it turns but theres no spark?
Old 05-20-2013, 05:55 AM   #14501
Silent Hunter
Silent Hunter's Avatar
Oddometer: 101
Hang in there buddy, my DR800 had the same problem a couple of years back too. No spark, no matter what.
Ended up changing the CDI, Stator coil, and starter engine and for good measure, I change the wire harness as well.
After that the bike was ok for several months until the fuel pump busted.
The bike was in the shop for nearly 1/2 a year....
Motorcyclists are the nicest people on the road, try not to kill us.
Silent Hunter is offline   Reply With Quote
Old 05-20-2013, 06:41 AM   #14502
wundis
Oddometer: 78
Ill play with the carbs tonight. In the meanwhile, I had a light bulb moment.
Does anyone have a spare (an old one would do the trick, too) float valve sitting somewhere? The thing i'd like to see is how much pressure in grams it needs to have for the small spring inside to compress fully. In exchange for the measurement ill buy you a beer next time you're in Lithuania!
I'm going to measure the values myself using my girlfriends kitchen scales (when she's asleep obvioulsy) on the float valves ive got (2 new oem, 1 old strong, 1 old weak).
Old 05-20-2013, 07:25 AM   #14503
spen
on my arse
spen's Avatar
Oddometer: 344
Is the bike turning over ??? or completely dead
spen is offline   Reply With Quote
Old 05-20-2013, 09:23 AM   #14504
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,975
Wundis,
Does it always run OK when you first start it?
If it runs well for those first few seconds and then starts to miss and run very rich (black smoke)as the engine warms, then, I'd check the enrichening (choke) circuit on the carbs. It may be that your choke plunger (valve) is sticking open or the cable (on later SR43s) is hanging up and even though the knob on the bars is all the way down, the plunger in the carbs is still open.
Ladder106 is offline   Reply With Quote
Old 05-20-2013, 09:24 AM   #14505
wundis
Oddometer: 78
OK, now here are the results of the 2 old float valves I have:
The weak one takes approx 20g to fully compress the small spring inside.
The stronger one takes an incredible 55g to fully compress. I'm pretty sure a difference like that would cause some serious inequalities between the carbs.
The new ones are going to be somewhere in between, probably around 30g judging by the fact that they were only a bit stronger than the old weak one.
Anyhow, does anyone know what role those springs play in the function of the carb?
Times are GMT -7.   It's 12:07 AM.
