Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 05-19-2008, 08:00 AM   #1
tsizmo OP
tsizmo's Avatar
Oddometer: 7
Same here..
I found this: http://gpsinformation.biz/phpBB2/viewtopic.php?t=4701
..i think I'm getting ready for the... operation..
tsizmo screwed with this post 05-19-2008 at 11:00 AM
tsizmo is offline   Reply With Quote
Old 05-19-2008, 11:54 AM   #2
tsizmo OP
tsizmo's Avatar
Oddometer: 7
Replacing 276C Internal Battery
Ok first remove the screws from the box shell
and the ring of the antenna base connector
carefully lift the aluminium paper behind the LCD screen (dont worry it has only soft glue)
remove PCB screws
at the back of the PCB you can see the battery
It's a VARTA MC621
Replace and voyla... no more acquiring satellites delay
Old 05-19-2008, 05:46 PM   #3
intr1gue
intr1gue's Avatar
Oddometer: 211
Thnk You!!!
...and that's how it's done. people ask a question, and the Internet serves up a couple casual responses and one ridiculously well documented response.
Thanks much. I'll do this and get back pronto.
--Ranjan
Ranjan
One little Indian
Seattle, WA
intr1gue is offline   Reply With Quote
Old 05-20-2008, 07:57 AM   #4
ebbo
ebbo's Avatar
Oddometer: 149
That’s what probably happened to mine, same symptoms, cost me just over £100 when I sent in to Garmin for service
It probably means they’re all destined to fail some time after 3 years, as mine did
According to the Varta life expectancy of Varta MC621
10%DOD - 1000 cycles
100%DOD - >200 cycles
Deep Discharge - >100 cycles
DOD = Depth of Discharge
Martin Ebdon, England,
R1200RT replaced by MX5
ebbo is offline   Reply With Quote
Old 05-20-2008, 02:08 PM   #5
tsizmo OP
tsizmo's Avatar
Oddometer: 7
Originally Posted by ebbo
...cost me just over £100 when I sent in to Garmin for service
totaly agree..!! For something so simple, Garmin keeps us in the dark...
...wondering why... $$$
Old 05-20-2008, 07:23 PM   #6
jktpa
X-Troller
jktpa's Avatar
Oddometer: 783
one of the ways to get by the phone wait is to use the marine service this works with 276's and 176's since they are really marine chart plotters.
Knick
Low Tech-Hi Fun
F800GS
WR250R
ET4
jktpa is offline   Reply With Quote
Old 07-17-2008, 09:29 AM   #7
Noblehops
Misfit
Oddometer: 138
WOW! Thanks
You sir, are a prince. The hardest part of this endeavor will now be finding that battery online.
THANK YOU, very much.
Nils
Nils Menten
'07 BMW R1200GS, '05 Suzuki DL1K,'02 Suzuki DRZ400E, '80 Honda CBX
"In Penne We Trust"
Noblehops is offline   Reply With Quote
Old 07-17-2008, 10:02 AM   #8
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Thumb
You are the man. My 276c is way too new to do this, but I'm stashing this information away for the inevitable.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 07-17-2008, 10:23 AM   #9
Noblehops
Misfit
Oddometer: 138
Nils
OK, this battery is actually discontinued by the manufacturer, although I was finally able to track it down online. So it's written down somewhere, this is what I learned:
It's a Lithium Ion rechargeable battery
it's 3.0 volts
it's 3.0 mAH (milliamps)
It measures 6.8 mm in diameter
It measures 2.15 mm in height.
This online battery retailer (Apex Batteries) had it, but it was obfuscated with a really long part number including some superfluous information.
http://www.apexbattery.com/mc6216062...batteries.html
They have it listed as
MC62160621-101-511 - Rechargable Lithium Battery
I bought 2 :-)
Nils
Nils Menten
"In Penne We Trust"
Old 07-17-2008, 03:42 PM   #10
tsizmo OP
tsizmo's Avatar
Oddometer: 7
it's 3.0 volts
Nils
..no worries man, just put ANY 3.0 volt battery that fits (a little larger will also do the job) thus more milliamps more battery life..
A friend of mine already put a larger sanyo battery and his GPS is working fine..
also remember to "scratch" both the battery poles before using the soldering gun..
cheers..
Jim
tsizmo screwed with this post 07-17-2008 at 03:49 PM
Old 07-17-2008, 03:49 PM   #11
intr1gue
intr1gue's Avatar
Oddometer: 211
Question related q about water-resistance...
Of course, one additional question: is there an o-ring or something that needs to be replaced when you replace this battery? I know when you unseal watches sometimes the ring needs to be replaced, or else the thing's no longer watertight...is this a problem or will it stay watertight even after it's been opened and put back together again with the original ring?
--Ranjan
Ranjan
One little Indian
Seattle, WA
Old 07-19-2008, 05:41 AM   #12
tsizmo OP
tsizmo's Avatar
Oddometer: 7
--Ranjan
no problem for me..
the "o-ring" is a heavy duty rubber seal
Just remember to carefully wipe it before closing the unit
with a soft slightly wet cloth..
i've wash the GPS a couple of times at home
and also did a big trip last September with
lots of km under heavy rain ...no problem at all
Old 07-19-2008, 06:11 AM   #13
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 12,936
This is so good, it deserves its own thread.
Dave
dunno.....
Old 07-26-2008, 08:15 PM   #14
Noblehops
Misfit
Oddometer: 138
OK, How to install the new battery?
Same here..
OK, I tore into it, as my GPS is about 4 years old, and although a reset did speed it up, it seemed like a matter of time before the battery croaked, and it didn't seem too fiddly.
Disassembly went fine, but when I got to the battery itself, it looked like it had been spot welded with the world's smallest spot welder. If you look closely at the close up photo you will see a pair of teeny dots. That's what I found.
Forging ahead I wiggled an Xacto blade in there and gently freed the battery. But how to reinstall? I attempted to put a teeny dot of solder on the two contacts that sandwich the battery, but it would not stick to the battery, nor could I get it hot enough to stay molten and get the battery on it.
Along the way I fear I shorted the new battery with solder, and I don't want to chance putting that one in. I'm going to order another.
I took some crazy glue to one of the now un-trusted batteries and tried sticking it to some pot metal. Presto! it's stuck hard. But is that kosher? Is ther some magic PC glue that is conductive?
I can't imagine how the heck I'm going to fix this any other way than gluing it on. Suggestions, pointing and laughing, etc are welcome.
Nils
Nils Menten
"In Penne We Trust"
Old 07-27-2008, 04:27 AM   #15
JDLuke
JDLuke's Avatar
Oddometer: 8,644
Perhaps a bit of emery cloth to roughen the surface of the battery would allow the solder to take hold?
Oh, almost forgot:
Times are GMT -7.   It's 01:02 AM.
