Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Old 07-27-2008, 04:17 AM   #16
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,241
Originally Posted by Noblehops
Forging ahead I wiggled an Xacto blade in there and gently freed the battery. But how to reinstall? I attempted to put a teeny dot of solder on the two contacts that sandwich the battery, but it would not stick to the battery, nor could I get it hot enough to stay molten and get the battery on it.
Look at post 10. The OP said "scratch" the battery. I bet he is saying rough it up so you can get the solder to adhere.
A little dot of an electronic safe flux would help as well.
Dave
dunno.....
Old 07-27-2008, 07:51 AM   #17
Noblehops
Misfit
Oddometer: 138
Dave
Yeah, I tried that, it still wouldn't stick and another problem is soldering the underside. You can heat up the solder till molten, remove the iron and attempt to place the battery on it, but the battery is so cold it sets up the solder instantly before it can adhere. Solder isn't going to be the answer, at least not for me.
The Google coughed up this with a little coaxing:
http://www.wireglue.us/
In addition, I found some recipies for homemade conductive glue using contact cement and graphite, but seeing as I have neither laying around, I ordered the wire glue, and fresh unmolested batteries.
I will photograph and document what happens next when I get it, but for the moment, I wouldn't advise folks blazing ahead with this project without a plan in place for how to reinstall this thing.
Nils
Nils Menten
'07 BMW R1200GS,DRZ400E, CBX, Z1, H2, CB400F
"In Penne We Trust"
Noblehops is offline   Reply With Quote
Old 07-27-2008, 04:30 PM   #18
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
You should be able to order the batteries with the weilded on tags .. than just solder the battery tags to the tags on the board... (not as cheap as teh plain jane battery .. and not avalible in teh drug store).
Conductive glue should ba avalible at radio shack, farnell, and other electronics suppliers .. it will not be cheap ..
Frank Warner is offline   Reply With Quote
Old 08-05-2008, 09:04 AM   #19
tsizmo OP
tsizmo's Avatar
Oddometer: 7
Nils
You are right this problem might happen, my only advice to this (don't laugh ) is to try several brands of batteries with the same characteristics.
some of them are real pain in the ass when it comes to solder (try Sanyo batteries)
tsizmo is offline   Reply With Quote
Old 08-09-2008, 11:59 AM   #20
Noblehops
Misfit
Oddometer: 138
Thumb
OK, it's done, and the glue worked perfectly. Success!
Here's a commented gallery on Smugmug detailing how I did it.
http://noblehops.smugmug.com/gallery...E9aP#348168332
Edit: The Wire Glue folks do not sell direct. After one aborted attempt to purchase from a mom and pop, I got it from Edmunds Scientific: http://scientificsonline.com/product...cd2=1218308292
They shipped it the next day for a pretty reasonable cost.
Nils Menten
"In Penne We Trust"
Old 11-09-2008, 12:17 PM   #21
ObiWanJak
ObiWanJak's Avatar
Oddometer: 234
I'm going to revive an older thread here. I tried to order the battery as suggested here, but I never was able to get it to take a charge. I suspect that due to the manufacturer discontinuing them, they may be reaching the end of their shelf life. I did find a Sanyo 3.0V rechargeable w/ similar specs (3.5 mah instead of 3.0, but same voltage) from Digi-key. This battery also already has tabs, so you can use straight solder and not worry about the wire glue. Just remember to select UPS ground as it's a lithium battery. I bent the tabs slightly on the one I received, soldered it on with no problems in less than 10 minutes w/ the above directions - works 4.0.
Loren
http://parts.digikey.com/1/parts/163...ml621-tz1.html
ObiWanJak is offline   Reply With Quote
Old 11-11-2008, 04:27 AM   #22
Twistn'roads
Twistn'roads's Avatar
Oddometer: 389
Loren,
Please forgive my ignorance in the ways of batteries but is the "charge" you refer to provided by the GPS receiver once the battery is mounted inside or did you charge the battery by some external means before you installed it? I have an older 276c requiring a battery change and I'm not all that savvy with electronic repair.
Regards,
Steve
Twistn'roads is offline   Reply With Quote
Old 11-11-2008, 11:25 AM   #23
ObiWanJak
ObiWanJak's Avatar
Oddometer: 234
When I received the battery, it had no voltage across the terminals - but the 276 will charge it when it's plugged in - the backup battery and main battery are charged at the same time (about 3.6V across the backup battery terminals when plugged in). Even after extended charge time in the GPS, the backup battery never put out any voltage. Hope that was clear. In short, I used the GPS to try to charge the backup battery, not an external charger.
Loren
Old 11-11-2008, 11:39 AM   #24
Twistn'roads
Oddometer: 389
OK, got it. Thanks Loren!
Now to figure out how to change the battery in my iPod....
~TR~
Old 03-09-2009, 07:19 AM   #25
Ooobah-Moto
Ooobah-Moto's Avatar
Oddometer: 3,809
...I just ordered the battery from DigiKey.
Thanks Loren
Ooobah-Moto is offline   Reply With Quote
Old 03-09-2009, 03:30 PM   #26
Countdown
Oddometer: 5,690
Tsizmo,
I would make a stand alone post
Titled "Slow Satilite Acquisition may be dead battery" and then explain sending to Garmin vs replacing battery.
Jerry Counts
Countdown is online now   Reply With Quote
Old 03-14-2009, 12:09 PM   #27
mudbreeder
mudbreeder's Avatar
Oddometer: 46
varta mc621 replacement
varta mc621 = 3V / 3mAH size: 6.8mm / 2.15mm
sanyo ml621 = 3V / 5.5mAH size: 6.8mm / 2.1mm
mudbreeder is offline   Reply With Quote
Old 03-16-2009, 12:41 PM   #28
tsizmo OP
tsizmo's Avatar
Oddometer: 7
Originally Posted by Countdown
Tsizmo,
Go ahead man, that sould be helpfull
Old 04-06-2009, 06:19 PM   #29
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,241
Thanks for that.
Just ordered one. Total cost - about $4.25
dunno.....
Old 04-07-2009, 02:45 PM   #30
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,081
I just replaced mine. It seems a little trickier than the set of photos indicate. I found it very difficult to separate the case after it had been stuck together for almost 5 years. He does not seem to show the flex circuit connector that mates to the white connector that is shown best in the 4th picture toward the right of the circuit board. I had to slide open the "keeper" portion of the connector to get the flex circuit that comes from the external power connector to mate back into the connector, then slide the keeper piece back in. There is also another connector on the backside that gets mated as you reinstall the circuit card. The last trick is to solder the two battery contacts without the iron or solder bridging the gap and shorting out the battery. (For sharp eyed whippersnappers that are used to surface mount soldering and have a small enough iron, I am sure it is a piece of cake).
Anyway, I hope this fixes the problem I had, which was for the GPS to forget what day or time it was.
My old battery showed only 0.7 V, the new one 2.68 V (before installation).
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Times are GMT -7.   It's 02:04 PM.
