Old 08-21-2011, 06:39 PM   #526
Michelangelo
2 wheel rider...anytime..
Michelangelo's Avatar
Oddometer: 1,525
Ok so I'm not smoking crack. I thought I had read there is some way one can switch through various hidden FI maps by doing the ignition ON, twist the throttle....etc...etc.. And that sounds like what you have done.
Can you explain more about this procedure and what exactly it does and choices of these settings? Seems like you said you got it to go to Advanced setting? What exactly is that?
Originally Posted by Brown Dog View Post
Im still running Stock Mapping as it came from KTM.
I am running it on setting # 2 [Advanced].
I turned the switch on & let the gauges do the sweep : [2008 model]
Slowly opened throttle to wide Open then slowly back to idle :
Then turned the switch off [no 15min idle deal]
It goes dead every once in a while at real low rpm's, but Runs Great
6th Gen VFR800, '08 KTM 690E, '05 CRF450X
'96 XR600TT, '00 Bandit 1200, '01 TTR-150L
Michelangelo is offline   Reply With Quote
Old 10-12-2011, 02:26 AM   #527
milosbgd
X
Oddometer: 55
Send a message via Skype™ to milosbgd
Very nice , how many DB killers you receive in package?,,,how is the sound, loud, Deep loud
Please u have realy clean tail, could you share info how did you install the turn signals on back tail.
Originally Posted by trailtrick View Post
Did you have a part number for the euro taillight ,o were i can get 1 ,thanks javier
milosbgd is offline   Reply With Quote
Old 10-12-2011, 08:31 AM   #528
Michelangelo
Oddometer: 1,525
Originally Posted by Ryman View Post
Mike: I think he is just talking about running on map #2 (advanced). There are several maps which can be selected by turning the selector switch under the seat. I think #1 is for economy #0 is for poor fuel. I really don't think there is any secret maps accessed by a combination of throttle blips. I think the turn key on, open and close throttle resets the TPS.
Get off the crack pipe!
So then how do I determine which map I'm on now?
Old 10-12-2011, 08:44 AM   #529
Barman
Way Offline
Barman's Avatar
Oddometer: 1,162
Have you messed with the selector since you bought it? If not it should be on #3 from the factory.
Page 85 in the service manual covers the Map-Select switch.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 10-12-2011, 09:46 AM   #530
milosbgd
X
Oddometer: 55
Hi,
Could some body explai me why it says 3 modes or 3 maps when it comes with 10-12 clicks.
Old 10-13-2011, 06:27 PM   #531
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,695
#2 setting under the seat is advanced meaning better throttle response etc... (#3 is stock) 4 & above does nothing #1 may be for low grade fuel ... Forgive me as I'm going off my memory
My wide open throttle with switch on, back to idle then switch off =
ONLY syncs / calibrates the TPS if I remember correctly
Brown Dog is offline   Reply With Quote
Old 10-14-2011, 08:55 AM   #532
engineerjoe
Oddometer: 38
0 is bad fuel
1 is "soft" aka DRZ400 mode
2 is Advanced aka "jerk-o-rama"
3-9 is "standard"
I'm using a hybrid between maps 1 and 2 right now for smooth up to 1/2 throttle then whack hold on!
engineerjoe is offline   Reply With Quote
Old 10-14-2011, 01:20 PM   #533
snohobo
Supermoto hippy
snohobo's Avatar
Oddometer: 405
Send a message via AIM to snohobo
Wonder if #1 would increase my fuel mileage? On a six month trip and could probably use a hand
RR: Supermoto Around South America - currently in progress!
2008 KTM 690 for sale in Patagonia (Punta Arenas, Chile)
http://advrider.com/forums/showthread.php?p=18077994
snohobo is offline   Reply With Quote
Old 10-14-2011, 01:38 PM   #534
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 3,199
nope. Ran #1 by accident once because i forgot I had set it to 1 for some nasty rocky riding. Saw no improvement in mileage over the other settings.
Seth S
Husaberg tank for sale: HERE
Seth S is offline   Reply With Quote
Old 10-20-2011, 05:48 AM   #535
payser
payser's Avatar
Oddometer: 112
here it is..
crowbar...helps more than word
KTM 950 SE,690 Ex2,xt660z(09)
XT660Z 2013
payser is offline   Reply With Quote
Old 10-20-2011, 08:13 AM   #536
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 823
Send a message via MSN to Gros Buck
Between 1 and what ? Between 1 and 3, the difference is almost nothing. Between 2 and any other ones, its around 30%. With a full tank, and the switch at position 1, I do 240 km. "Easy-rider" driving style. I will do no more then 180 km with the switch at position 2.
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 10-20-2011, 12:11 PM   #537
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 1,406
Calling it a map select switch is a bit misleading, it only messes with the ignition timing, if you wish to change the fuel scheduling then that has to be done at the dealer or via an aftermarket device like tuneboy i.e. changing the fuel mapping because of an aftermarket exhaust or different airfilter set up.
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690R 2011
http://www.jet-metal.com
El Ponkin is online now   Reply With Quote
Old 10-21-2011, 01:26 AM   #538
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 892
Wrong wrong wrong.
It switches between fuel map, ignition map LO map AND EPT map.
however the EPT map is the only one that you really notice.
950 Rally custom - 690 Enduro Ride ON!
StevenD is offline   Reply With Quote
Old 10-21-2011, 08:55 PM   #539
snohobo
Supermoto hippy
snohobo's Avatar
Oddometer: 405
Originally Posted by Gros Buck View Post
Between 1 and what?
Paul Jr 8
I'm assuming most people ride with #2 which is what mine is set up for. Ill give 1 and 3 a try and see what happens to my mileage.
I assume throttle response will go down
Old 10-25-2011, 03:17 PM   #540
milosbgd
X
Oddometer: 55
Hi, could you tell me how did you fit rear turn signals? Did you drill a hole?
Times are GMT -7.   It's 02:10 AM.
