Old 07-23-2008, 03:33 PM   #1
CaspianTiger OP
CaspianTiger's Avatar
Oddometer: 37
Dnepr sidecar only price?
I'm thinking about bidding on a new Dnepr sidecar (no bike). The minimum bid is $1300. Appreciate comments on the cost. Too much? About right? Good deal if it's under $1500? Etc. Etc.
Thanks.
CaspianTiger is offline   Reply With Quote
Old 07-23-2008, 03:56 PM   #2
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 4,852
Send a message via Yahoo to RedMenace
Thanks.
Dnepr sidecars are fairly robust and Ural mounting hardware will fit. People often base the price on that of a new Ural sidecar which was approaching $3000 if available last I checked. I think about a third that or a little over is fair for one without rust or dents and with a straight axle, so, yeah, $1500 isn't bad. Really the price is what you can find and what you can stand to pay.
Dnepr wheels are weak and should be replaced if you are going to hook it to a heavy bike or ride it hard. Ural wheels are better and some BMW wheels will fit. Jay(Dauntless) or one of the other shops can probably do an axle upgrade for you if you need to go to a different wheel.
The most common way to fix a bent axle is to replace the swingarm. Ural swingarms won't fit and Dnepr parts can be hard to find at times
the Red Menace
"You are measured by how you ride by people who ride, and how you pose by people who pose." Alejo
"Riders who get pissed off are doing it wrong." DAKEZ
RedMenace is offline   Reply With Quote
Old 07-23-2008, 06:16 PM   #3
CaspianTiger OP
Oddometer: 37
dnepr sidecar
Thanks Red for the good reply. It would go on a 1985 BMW K100RT. It won't be ridden TOO hard, but a better wheel sounds like a good mod.
Old 07-23-2008, 09:26 PM   #4
eastbloc
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,228
I haven't had a whole lot of experience with actually riding Dnepr sidecars, but I've worked on a few Dneprs and the frames seem beefier and more industrial than their Ural counterparts. The deep Dnepr fenders are also more aesthetically pleasing to me. All the rolled steel bits are thicker as are the tubes that make up the sidecar frame.
My suspicion is that a lot of the negative perception of KMZ machines have to do with the slapped-together grey market exports of the last fifteen years, (a la Yuri of eBay fame) rather than anything inherent to the product. Quite simply, many of the specimens we get on this side of the Atlantic have not gone through any quality control, and have even been rumored to be from QC-rejected stock that was sitting in warehouses destined for scrap.
I don't know how much truth there is in that, but I have a Yuri kit-bike engine sitting in my garage with 40km on the ticker with a worn-out cam follower.
The KMZ factory was producing bikes for the Red Army, and like many Soviet enterprises the best examples rolling off the assembly line were dedicated to that purpose, while the parts with looser tolerances were destined for the domestic consumer market. Somewhere in the middle were the export pieces. In light of that industrial philosophy, I'm not surprised that the grey-market Dnepr bits that end up over here are less than great.
I still tend to think that even a grey-market Dnepr would make a fine starting point for an affordable and reliable outfit if one were to buy it with an eye on a BMW airhead motor conversion. An MT-16 with a meticulous setup and an R75 motor should give a Patrol a very reasonable 2WD challenge at half the price. But I've never done this myself, so it is pure fantasy :)
As Red pointed out, Dauntless Motors would likely be able to replace your Dnepr swingarm setup with one that would fit a BMW wheel for $500 or so, delivered to your door in bolt-on fashion. The option to put a Brembo disc on said wheel is well worth considering. Jay's work is impeccable, and his prices are more than fair considering the meticulous attention to detail and design alike afforded by his products.
My experience tells me that $1500 for a Dnepr sidecar in good condition that needs nothing (good paint, lights, tonneau cover) is a fair price. Less if it is damaged or neglected.
My experience also tells me that the fun you will have after hacking your ride is priceless
'86 V65 Magna
'01 R1150GS/Ural
'03 Ural Wolf
'05 Kawasaki ZZR 1200
'09 Kawasaki Versys
eastbloc screwed with this post 07-23-2008 at 09:32 PM
eastbloc is offline   Reply With Quote
Times are GMT -7.   It's 07:11 AM.
