Old 09-19-2013, 10:58 AM   #2131
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,124
Originally Posted by cm75 View Post
Hey y'all,I've got a quick question. I've turned my Drz into a street tracker, I had to tear it all apart. I have it back together now and everything works, EXCEPT my clutch will not engage. Is there a way to adjust it so it will work? Thanks in advance!
Pictures please, or it didn't happen. Just because I like DR's and street trackers. Here's a link to a cbr/crf 250 based tracker that I seen at the motorcycle show. Very nice.
http://cbr250.com/forums/cbr250r-for...250r-mc41.html
fastdadio is offline   Reply With Quote
Old 09-19-2013, 11:44 AM   #2132
tdrrally OP
tdrrally's Avatar
Oddometer: 3,350
that would be a place to try
and yes some pictures are in order
1997 DR350se
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 09-19-2013, 04:50 PM   #2133
cm75
Oddometer: 107
I hope this helps with the pics. Never done this before!!! Lol
cm75 is offline   Reply With Quote
Old 09-19-2013, 04:52 PM   #2134
cm75
Oddometer: 107
I don't see any pics. Try Cm75.smugmug.com
Old 09-20-2013, 10:12 PM   #2135
cm75
Oddometer: 107
Ok,I got the clutch working again. Apparently when I was routing the clutch cable,I zip tied it too tight to the back bone of the bike. Undid it and everything is working good now. Even took it out for a little spin around the block,everything working good now.
Old 09-21-2013, 04:05 AM   #2136
tdrrally OP
tdrrally's Avatar
Oddometer: 3,350
1997 DR350se
Old 09-21-2013, 08:45 AM   #2137
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 584
try photobucket.com it has built in image links and is pretty user friendly.
2006 Suzuki DRZ 250
redleger is offline   Reply With Quote
Old 09-21-2013, 08:55 AM   #2138
tdrrally OP
tdrrally's Avatar
Oddometer: 3,350
free too
1997 DR350se
Old 09-21-2013, 04:43 PM   #2139
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 584
Originally Posted by tdrrally View Post
free too
Hey TD. Can you check my post in the 400 thread. You seem to be veey knowledgeable and have an E model also. This one is driving me crazy.
Sent from my SPH-L710 using Tapatalk 4
2006 Suzuki DRZ 250
Old 09-22-2013, 05:38 PM   #2140
ruffzguts
ruffzguts's Avatar
Oddometer: 52
Hey guys i saw a link on here ages ago but Cant seem to find it now. I'm looking for the user manual that tells you how to set & operate the digital dash.
Kind regards.
Cheers,
ruffzguts.
_____________________________________________
If your dad doesn't have a beard, You've got 2 mums.
ruffzguts is offline   Reply With Quote
Old 09-22-2013, 05:41 PM   #2141
tdrrally OP
tdrrally's Avatar
Oddometer: 3,350
its the same as the drz400e/s if i recall
1997 DR350se
Old 10-04-2013, 09:33 AM   #2142
tkent02
Oddometer: 2,464
WTB decent DRZ 250...
Somewhere around Colorado would be cool.
tkent02 is offline   Reply With Quote
Old 10-11-2013, 09:41 AM   #2143
tkent02
Oddometer: 2,464
Can't find one to test ride, what is the DRZ250 powerband like? High RPM only like a WR250R? Or is there lots of low end grunt like most old thumpers? Somewhere in between?
Old 10-11-2013, 09:47 AM   #2144
turnenem
TBD
turnenem's Avatar
Oddometer: 1,036
Mine is geared 53-13 so not stock and my top speed isn't much more than 50 mph, but super linear power delivery right from idle. Starts dropping off quickly at around 8000rpm.
Turnenem
turnenem is offline   Reply With Quote
Old 10-11-2013, 09:55 AM   #2145
tdrrally OP
tdrrally's Avatar
Oddometer: 3,350
its real flat from idle to redline like an electric motor
i found my drz250 more rideable then my buds wr250
1997 DR350se
Times are GMT -7.   It's 12:09 AM.
