Old 01-06-2010, 06:01 AM   #226
gvthnks
gvthnks's Avatar
Oddometer: 572
I plan on digging on their website too. Just figured you were familiar too so thought I'd ask.
I'm hoping to find some GPS files to some of the trails. we'll see. I'll keep you posted.
What's the weather like there in May?
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
wife calls it a sickness. I'm running a M/C rescue
gvthnks is online now   Reply With Quote
Old 01-06-2010, 11:08 AM   #227
tdrrally OP
tdrrally's Avatar
Oddometer: 3,452
may weather is hit and miss mid to late is best
i have been planning to check out the trail had around logan and mann
edward
1996 Dr350se 1997 DR350se
2002 Drz250k2 i miss that bike 2007 sv650 naked scrambler
tdrrally is offline   Reply With Quote
Old 01-06-2010, 02:04 PM   #228
GlennF33
Oddometer: 117
I have a dual sported 2006 DRZ250 and after re-jetting, un-corking, the only issue I have with this bike is the close ratio transmission with the low road speed. I feel the stock 13/49 gearing is perfect for our single track here in Ohio. I often wondered if other versions (i.e Djebel) have a different 6th gear.
GlennF33 is offline   Reply With Quote
Old 01-06-2010, 02:56 PM   #229
tdrrally OP
tdrrally's Avatar
Oddometer: 3,452
factory street drz250s/djebels from a 14/42 with 4.60 rear tyre
then you can try a 13t
it works well for me and my bike
also hear i a suzuki parts list for the drz250s on and off road
http://www.scoot.bg/arhiv_na_opisani...2001-2005).pdf
edward
Old 01-06-2010, 02:57 PM   #230
tdrrally OP
tdrrally's Avatar
Oddometer: 3,452
BTW
what part of oh are you in?
edward
Old 01-06-2010, 06:45 PM   #231
gvthnks
gvthnks's Avatar
Oddometer: 572
[quote=GlennF33]I have a dual sported 2006 DRZ250 and after re-jetting, un-corking, quote]
what did your final jetting turn out to be? What did you change in the airbox or exhaust?
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Old 01-07-2010, 07:27 AM   #232
GlennF33
Oddometer: 117
I am in Newbury (east of Cleveland). My final mods were: #137.5 main, #15 pilot, shim needle .070", fuel screw std. 2 3/4 turns out (I have the California CV 32mm carb). I removed the snorkel, drilled a 1" hole next to it, and (3) 1" holes in side of right side airbox cover. Put in UNI vents in 1" holes. I also installed a UNI filter. Exhaust is stock except for grinding out header welds.
Old 01-07-2010, 12:31 PM   #233
tdrrally OP
tdrrally's Avatar
Oddometer: 3,452
ok i am running a pumper on my 03 with uni and yoshi and the cv carb on my 07 stock
edward
Old 01-07-2010, 12:34 PM   #234
gvthnks
gvthnks's Avatar
Oddometer: 572
My 01 has the Yosh pipe and the stock MJ. I think it will be fine on top, but the low end is what I'm working on. Waiting on those jets to arrive.
I lose all patience for waiting once I order something......
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Old 01-08-2010, 11:10 AM   #235
gvthnks
gvthnks's Avatar
Oddometer: 572
Originally Posted by tdrrally
i am running #40 (n224.103 tmx)
edward
yeah.....NO. Wrong jets. Don't ask me how I know......
the n224.103 are: OVERALL LENGTH = 26mm
THREAD PITCH = 4.0 x 0.7
TIP DIAMETER = 2.5mm.
The one my carb uses is the VM28/486. OVERALL LENGTH = 27.0 mm
HEAD DIAMETER = 5.0 mm
TIP DIAMETER = 2.0 mm
oh well. too cold to ride much anyway.
New order placed and patiently I wait. (Not) Am I the only one who begins looking out the window for the delivery truck just a few minutes after I order something?
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Old 01-13-2010, 06:27 PM   #236
gvthnks
gvthnks's Avatar
Oddometer: 572
Almost complete. I rode it today around the neighborhood and in the back yard some. Still need to replace the rear tire, fix the tear in the seat and do a couple of other odds and ends. For the most part though, it's ready to go. I plan on riding it in a local riding area on Monday for a shake down.
Thanks again for the headlight Edward. To me it makes all the difference in how it looks.
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Old 01-14-2010, 07:11 AM   #237
tdrrally OP
tdrrally's Avatar
Oddometer: 3,452
Thumb
looks great man
edward
Old 01-16-2010, 03:36 PM   #238
gvthnks
gvthnks's Avatar
Oddometer: 572
What do you use on your street rigs for speedos?
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Old 01-16-2010, 05:53 PM   #239
tdrrally OP
tdrrally's Avatar
Oddometer: 3,452
i am running a trail tech vector on k2 and stock dr125 speedo on k7 for now
edward
tdrrally screwed with this post 06-22-2010 at 06:22 AM
Old 01-16-2010, 06:05 PM   #240
gvthnks
gvthnks's Avatar
Oddometer: 572
dr 125 speedo huh? is that a bolt on affair? I don't really need one for trail and off road riding, but I'd like to find something.
I wondered how hard it would be to make a DRZ 400 cluster work. Obviously it has more features than I need, but I see them for sale sometimes.
Thought about going with a Vapor but we'll see. I want to ride it some and see how badly I want it after that. Trying not to sink anymore into this bike.
Thanks for the info
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Times are GMT -7.   It's 09:40 PM.
