Old 04-25-2012, 02:20 AM   #1381
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,351
Originally Posted by astaa View Post
Im searching for a rear Brake Disc for my Suzuki Djebel 250 xc (1996) does anyone knows where can I find one?
Thank you.
Get a DRZ250 rear disc off Ebay if you can't buy locally.
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 04-25-2012, 05:31 AM   #1382
tdrrally OP
tdrrally's Avatar
Oddometer: 3,332
or a dr250/350
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 04-26-2012, 01:20 PM   #1383
Seavoyage
Seavoyage's Avatar
Oddometer: 133
Difference between 1990 DR250 (US model) and Djebel?
What is the difference (frame/engine) between the 1990's US DR250 and the Djebel sold in European/Asian markets? Other than electric start.
I am also interested in the headlight on the Djebel 250XC, if it would fit a US DR250.
According to this BikePoint (Australia) review, the DR-Z250 is a relabelled DR250: http://www.motorcyclespecs.co.za/mod...rz250%2002.htm Can this be confirmed? The photos look like the same frame/motor and bodywork, except for the swingarm.
Is the DR-Z250 swingarm a direct fit for a DR250?
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter. -Ernest Hemingway
Seavoyage screwed with this post 04-26-2012 at 02:04 PM
Seavoyage is offline   Reply With Quote
Old 04-26-2012, 01:43 PM   #1384
tdrrally OP
tdrrally's Avatar
Oddometer: 3,332
its a different bike
Old 04-26-2012, 05:26 PM   #1385
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,351
The DRZ250 closely related to the 1996~ DR250rs below but not the earlier DR250/350 shown at the bottom.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Old 04-29-2012, 12:31 PM   #1386
privateer2010
privateer2010's Avatar
Oddometer: 37
Running Way Hot
Anyone have a problem with the 250 overheating? I am out this weekend riding and unfortunately we are having to do more highway than I wanted. I have had it happen hree times now. I will admit it has been going up the mountain in 6th gear wound out pretty good. I have never had an overheating problem prior to this. Any thoughts other than dont do that....
An adventure is only as far away as the first step out the door.
privateer2010 is offline   Reply With Quote
Old 04-29-2012, 04:52 PM   #1387
tdrrally OP
tdrrally's Avatar
Oddometer: 3,332
my bike has gotten hot once in traffic on a hot summers drive home in traffic
now i have the oil temp gauge working i can track the temp
have you changed the jets? or any thing?
Old 04-29-2012, 05:10 PM   #1388
privateer2010
Oddometer: 37
No I have not changed anything yet. Someone mentioned that a larger jet would probably help. I wonder if a little thicker oil might help. I am assuming you installed an aftermarket oil temp gauge? Can you post specs and pics I like that idea.
Old 04-29-2012, 08:46 PM   #1389
zgfiredude
Oddometer: 835
JETTING is almost surely too lean! Fix that first, and then ride baby ride......
zgfiredude is offline   Reply With Quote
Old 05-01-2012, 08:16 AM   #1390
ChrisRiedinger
Specialized
Oddometer: 596
I love my DRZ, took it out on some local trails last night, broke off the plate I was riding it so hard
But in all seriousness, I was able to keep up with kids on their 300exc's
They don't wear gear (read: they consider riding apparel work boots and a helmet, while I ride with mx boots, knee/shin guards, kevlar lined pants, upperbody armor, helmet, gloves, etc) so I don't really consider it fair, I can just bomb through things and they have to worry about breaking their toes off
This thing just CHUGS though! I can put it in 1st gear and literally crawl up rock formations that I never would imagine trying on a 650!
ChrisRiedinger is offline   Reply With Quote
Old 05-01-2012, 09:06 AM   #1391
tntmo
Oddometer: 491
Airbox to carb boot
Is anyone here parting a DRZ250? I need the rubber boot between the carb and the airbox if anyone has it.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 05-01-2012, 10:07 AM   #1392
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
We need to see the pictures to believe you.
Hope the trails tires are working better off-road than on-road.
DR650 - FZ1 - 200 EXC (plated - Not inspected yet)
fizzerfz1 is online now   Reply With Quote
Old 05-01-2012, 10:16 AM   #1393
ChrisRiedinger
Specialized
Oddometer: 596
Ill take a picture of whatever fine they give me at the DMV for losing my plate
EDIT: I also need a suggestion for a good KNOBBY for the front, the trials tire is great for the rear, but I need something with a knobby shoulder to help cornering in the loose stuff, the trials tire seems like it looses grip about 5 off of straight up and down!
ChrisRiedinger screwed with this post 05-01-2012 at 10:22 AM
Old 05-01-2012, 11:33 AM   #1394
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
Try Shinko 700 or 244, not a knobby, but should serve as 50/50 and they are fairly cheap. Or the Kenda 270... You will see all opinions on these tires, do your research..., You should be able to get a set for less than $100
Old 05-01-2012, 04:54 PM   #1395
tdrrally OP
tdrrally's Avatar
Oddometer: 3,332
A kenda k270 on the rear with a knobby up front works well
Times are GMT -7.   It's 11:48 PM.
