Old 05-01-2012, 07:03 PM   #1396
53trb
Oddometer: 4
OEM parts
Hello
I have been updating my DR-Z... anyone interested in the OEM rear sprocket, foot pegs, or air filter? I also the stock Mechanical Speed-o-meter drive gear, cable, and Odometer (Not a speedo, only Resetable Odometer).
If you are interested let me know and we can work out a price, and I will send pictures.
Thanks.
53trb is offline   Reply With Quote
Old 05-02-2012, 05:47 AM   #1397
ChrisRiedinger
Specialized
Oddometer: 596
Originally Posted by fizzerfz1 View Post
Try Shinko 700 or 244, not a knobby, but should serve as 50/50 and they are fairly cheap. Or the Kenda 270... You will see all opinions on these tires, do your research..., You should be able to get a set for less than $100
Originally Posted by tdrrally
A kenda k270 on the rear with a knobby up front works well
You guys obviously don't read (or maybe comprehend ) before you respond?
I pretty specifically said: I also need a suggestion for a good KNOBBY for the front, the trials tire is great for the rear, but I need something with a knobby shoulder to help cornering in the loose stuff
ChrisRiedinger is offline   Reply With Quote
Old 05-02-2012, 05:48 AM   #1398
ChrisRiedinger
Specialized
Oddometer: 596
Originally Posted by 53trb View Post
Hello
Thanks.
Im interested in the pegs, if they include the mounting brackets. Send me a PM?
Old 05-02-2012, 07:35 AM   #1399
tdrrally OP
tdrrally's Avatar
Oddometer: 3,337
I use a kenda millville or waushagol up front and rear for mud
then k270 for ds and dry.
you got to find what works for you
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 05-02-2012, 03:03 PM   #1400
DRool
Oddometer: 54
Here is a link of a how to on expanding your tank that Paul has just put together. Good job Paul
http://www.youtube.com/watch?v=8h7BOGlNO8E
DRool is offline   Reply With Quote
Old 05-04-2012, 04:04 AM   #1401
Stinky@240
( Chef)
Stinky@240's Avatar
Oddometer: 73
Expanding Tank
Glad you enjoyed it.....
Thanks for sharing Steve!
Stinky@240 is offline   Reply With Quote
Old 05-06-2012, 09:44 PM   #1402
cm75
Oddometer: 107
Does anyone know the diameter of the forks on the drz?
cm75 is offline   Reply With Quote
Old 05-07-2012, 04:55 AM   #1403
tdrrally OP
tdrrally's Avatar
Oddometer: 3,337
43mm same as a dr250/350/650
Old 05-07-2012, 06:17 PM   #1404
cm75
Oddometer: 107
Thanks man.
Old 05-10-2012, 02:54 PM   #1405
cm75
Oddometer: 107
Update on street tracker drz250
Well,after hours on the interwebs looking for cheap ways to lower my bike,I finally decided to jump in with both feet and try it. I made some lowering links for the rear shock,ended up pretty good. Lowered the rear about 3",then I needed to lower the front end,cheaply.I ended up taking the forks apart and cutting the springs 3" and put it all back together and honestly,I think it looks great! I plan on taking the square headlight and shroud off and replacing it with a round headlight. For the bodywork,plastic/fiberglass cafe racer tailsections and seat pans are crazy expensive,so it looks like I my try my hand on doing a custom fiberglass rear section. As far as the tank,I have an old fiberglass flat track tank hanging in my garage. Maybe I can line the inside with something that will hold up to the gas we have around here. What to do,what to do...Hopefully you guys don't mind me posting this stuff here,I'm just kinda excited to be customising another scooter after a long break.
Old 05-12-2012, 07:50 PM   #1406
zgfiredude
Oddometer: 837
Pics, or it didn't happen........
zgfiredude is offline   Reply With Quote
Old 05-13-2012, 06:24 AM   #1407
cm75
Oddometer: 107
If I can figure out how to post pics,I'd be more than happy to share with you my little project!
Old 05-13-2012, 11:23 AM   #1408
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
http://www.smugmug.com/ costs $ but supports adv
http://imageshack.us/ is free.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 05-13-2012, 12:35 PM   #1409
cm75
Oddometer: 107
Thanks bud,when I get home,I'll check it out and post some pics.
Old 05-15-2012, 05:03 AM   #1410
Turbohag
Turbohag's Avatar
Oddometer: 6
Hey guys,
Thinking about getting some of these http://www.carlscycle.com/eshopprod_...g_Link_Set.htm
... doe anyone else think $40 usd is rather the expensive to send to a relatively small and light weight item from the U.S to New zealand?
Cheers
Turbohag is offline   Reply With Quote
Times are GMT -7.   It's 09:02 AM.
