Old 08-08-2008, 11:15 AM   #1
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,861
I'm going to build a 2WD rig.
Let's brainstorm first...
This thread was very helpful: 2WD
Another thought that I've had is this Toyota transfer case that I have sitting here. It's totally bada$$ and would work perfect for a left side car, but I have a right side entry Ural tub and it would look retarded on the left side. Nice idea, it has a divorce front adapter with a double reduction box and an e-brake on the back, they make a flip kit for it, but it's $700 .
Scratch that idea.
I can easily duplicate the Mobec Duo-Drive box.
I'll do the suspension like they do for the Super-Drive.
I think a trip to Pick-N-Pull is in order next to look for donor vehicles for suspension and stuff.
I'm thinking double A arm hung off the sidecar frame for the bike drive wheel and the same for the sidecar driver...I may get trick and hang the front the same way, but without putting power to it. In all reality I'll probably stick with a leading link front for simplicity.
I'm thinking of building an all new frame for the sidecar rather than modifiying the existing. This will give me a good sidecar frame to sell that will fit a Ural tub since the mods I'm making will be forever...no turing back.
I need to come up with a jack shaft drive to get power from the bike over to the sidecar. Time to start stripping parts.
If anybody has ideas for me, throw them in. I'm all 's.
Old 08-08-2008, 11:47 AM   #2
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 4,852
Send a message via Yahoo to RedMenace
Scratch that idea.
If you are going to all that trouble make the new front end hub center and link it to the SC wheel and make that steer too.
With a driven and steering sidecar wheel you can move it way forward and have a super stable rig with easy steering and no drag or pull at any speed.
Me, I'd just slap some links on the thing and extend the sc swing arm to reduce the lead by about 5" and call it done-I never finish my complicated projects....
the Red Menace
"You are measured by how you ride by people who ride, and how you pose by people who pose." Alejo
"Riders who get pissed off are doing it wrong." DAKEZ
RedMenace is offline   Reply With Quote
Old 08-08-2008, 12:02 PM   #3
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,861
Yeah, K.I.S.S. or I'll never finish it.
Hmm, steer the hack too? That might be too much for my little brain to handle.
I'm going to build it "expandable". Simple to get back on the road, while leaving options for the future..such as reverse, steerable sidecar wheel, lowering/raising, etc.
Old 08-09-2008, 10:46 AM   #4
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,861
I'm never very good at these type of threads...I forget too much.
Anywhooo, the point of this project is that I have a crashed sidecar rig. I tried to go simple and fast...get some wheels built so I could throw a leading link on it and get back to riding. I can lead a horse to water, but can't make him drink..aka, wheel builders seem to have a hard time actually building wheels. After 2 months of waiting I have given up. If they want to charge me shipping to get my parts back they can keep them. Sooo, the project shifts gears into something more complicated.
Okay, typing out loud here..
Jackshaft. Easy enough to build. Say the bike has a 15t countershaft sprocket. I can go to another 15t to get over to the sidecar, another 15t will be on the jackshaft at the SC, from there I run a short stretch of chain to my final drive sprocket, 42t or whatever it is. I can then go back into my own fab'd box like the Duo-Drive using whatever size sprocket I want in the splitter box. Right? Once I'm geared down with the 42t it stays at that RPM, right? Or is my thinking flawed?
I'm going to throw this pic in here again to clarify for myself.
Yeah, once it hits the final drive ratio you keep that rpm going and split out to the wheels using smaller sprockets to keep the size of the box small.
Right?
They're using a viscous coupler at the SC drive axle. I'll probably use a collar type mechanical disconnect like the rock crawlers use for front wheel drive only on the Toyota's.
The end result I'm hoping for is somewhere between Hog Wildz rig and what I had originally...without spending a small fortune.
Old 08-10-2008, 10:05 AM   #5
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,861
Been looking around the 'net at hub center front ends..pretty cool, but would be far too complicated for me right now. Wilbers suspension has a really cool page of customer rigs with their shocks and stuff.
I'll stick with a leading link front since it's easy for me to build and I have a bunch of parts already that can be used without spending more $$.
What's the skinny for using a car wheel on the front with a hub that will mount a rotor?
Think I can go single disc on the front and put the second disc over on the hack wheel using the front brake lever to accuate both? I've got an adjustable proportioning valve that would let me adjust for straight braking.
Old 08-10-2008, 08:08 PM   #6
bk brkr baker
bk brkr baker's Avatar
Oddometer: 4,139
Hello Larry,
I did a 4600 mile cross country ride on a FJ 1100 Yamaha with a Sidebike chair package. This is a French made outfit with centerhub front end,13" side and front wheels, 14" rear wheel, car tires all around and sidecar steering too.
The front brake set up used both Yamaha calipers on a single disc in the front. The sidecar wheel had a brake and that was coupled with the rear on the bike. This was well set up and very stable under hard braking.
The sidecar wheel steered about half as far as the front. This set was also well thought out and worked great. After I made an adjustment to reduce the toe in I found that you could steer the rig with your foot on the linkage. With a throttle lock this made for a lazy ride ,arms crossed watching the world go by in Texas.
You may enjoy the site Some Fear .com.
Old 08-10-2008, 09:27 PM   #7
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,861
Thanks, baker!! Helpful info, I'll check out the site.
I'm going to be using front wheel drive car stuff so I'll lock out the steering function on the hack to get me on the road for now, with the option to make it functional later.
For home engineered I really think I should play it safe and go with a leading link. I can get a little more wheel travel and feel more confident building it.
Old 08-11-2008, 11:58 PM   #8
zenben
all roads are one
zenben's Avatar
Oddometer: 593
Unless you live somewhere where snowfall requires most people to own a snowmobile, I can't really see a point to 2WD.
If the design exercise is the whole point, then I can see appeal.
Proof of concept is rewarding, if not always rational.
As a senior ME project, this would undoubtedly get a high grade.
zenben is offline   Reply With Quote
Old 08-12-2008, 04:08 AM   #9
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,518
Dual-sporting is a great use of 2WD. Gravel and mud can benefit from some additional traction. Otherwise I agree. But then, if we all were purely logical, we would all ride the same bike, eh?
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift!
Member of the Maryland OHV Alliance
Kyler is offline   Reply With Quote
Old 08-12-2008, 05:58 AM   #10
bk brkr baker
Oddometer: 4,139
Endevour to persevere
Please, don't try to discourage Larryboy with logic, I want to see this built!
Old 08-12-2008, 06:57 AM   #11
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 4,852
Hi Ben!
I think you might be missing the point.
TWD is not just for off road and Ural's design approach is niether the only nor the best design possibility for TWD. One huge plus of a modern twd system with a differential is handling: no sidecar drag, straightline acceleration without yaw, reduced tire wear and reduced fatigue.
I suspect Larryboy is trying to correct some of Yellow Suzi's design flaws. It pulled hard the way I had it set up when we traded bikes. And I understand the front end needs some attention...
the Red Menace
RedMenace screwed with this post 08-12-2008 at 07:03 AM
Old 08-12-2008, 07:54 AM   #12
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,861
The whole thing is that it's a crashed rig at the moment..and like Vernon pointed out, I really don't want to end up where I started. Yes, I could handle it how it was. I love the appeal of the Ural 2wd and treat my machines in much the same way that Mr. Cob does...so I have a need. I've crashed sooo many times on 2 wheels when hitting ice or snow and would like to extend my high country riding season with a 2wd rig.
There is also the second attraction of possibly getting my wife or daughter to come to Death Valley with me if I took the sidecar and creature comforts that would make the trip more enjoyable for them. I don't trailer anything anywhere. It gets ridden or it stays home...I like the speed and power of the Bandit powerplant or I'd just scrap the whole thing and buy a Ural.
So that's where I'm coming from.
Now how about some of you web riders answer some of my questions?
Old 08-12-2008, 08:11 AM   #13
larryboy OP
Paint it black.
larryboy's Avatar
Oddometer: 12,861
I just took the time to look at the some fear dot com site. I now understand how to build a hub center front that is strong enough...makes perfect sense. I love the cantalevered shock mounting..way cool. Too much for me on this project.
Old 08-12-2008, 09:22 AM   #14
zenben
all roads are one
zenben's Avatar
Oddometer: 593
OK, The justification makes sense.
I have studied the concept before, and settled upon a Subaru diff as the logical choice.
A long chain driven transfer case is how the Mobec is set up, but it seems simpler to me that a shaft would cross the sidecar at the rear, and chain drive forward to the chair wheel, not unlike the original military R75:
The above hub center design looks like an RDS. One of the more elegant looking solutions. Also available with sidecar steering.
zenben screwed with this post 08-22-2008 at 11:01 PM
Old 08-12-2008, 03:36 PM   #15
ag_streak
Tiene Ruta Cuarenta?
ag_streak's Avatar
Oddometer: 2,989
THAT is about the most ambitious project I have ever seen! Bravo!
2013 Triumph Tiger 800 - 2007 Harley XL1200R Roadster - 2002 BMW R1100S
You can lead a politician to water, but you can't make him think. - Kinky Friedman
Improve your cosmic karma here!
ag_streak is offline   Reply With Quote
Times are GMT -7.   It's 02:53 AM.
