Go Back   ADVrider > Riding > Face plant
Old 05-10-2009, 12:46 PM   #226
Mika S
JC & MC: Double Freedom
Oddometer: 155
Baroness, sorry to hear about your incident. I wish you a full recovery and God bless!
Benesesso, what did u find out by SEM?
Mika S is offline   Reply With Quote
Old 05-12-2009, 07:40 PM   #227
Benesesso
Benesesso's Avatar
Oddometer: 8,506
I have been asked not to make any public statements specifically on her forks.
With that said, I can reveal that I have seen reports/photos of other fractured forks of the same type, and based on those reports/photos at least some of them had clear evidence of outside-initiated fatigue fractures that grew, probably over a relatively long time, until the "critical crack length" was reached which resulted in sudden fracture.
What this means for a rider who still has the "old" design forks is that a good dye-penetrant exam, preferably fluorescent, should reveal any cracks before they grow to the point of failure. Any such test must be performed after steps have been taken to assure that no oil or water is within the cracks, and this is not so easily done. The cost of such tests, properly done, could be a fairly large % of new, later-designed forks.
This is not to say that inside-initiated cracks/defects do not occur during riding or are present as new. Such defects would be much harder to be detected.
The bottom line is that if *I* rode one of these bikes, I would replace the forks with the newer design.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 05-12-2009, 08:08 PM   #228
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 2,757
good info! Hmmmm I may just haul my forks into work and do some conductivity testing on them to see if I can find localized hardness. What do you think?
I will add that as an instructor in LPI (dye penetrant) certified by the Canadian government with years in aviation inspection that most people do LPI incorrectly.
If Benesesso's data proves out I would be inclined to advise against using LPI, first because of the sensitivity required to detect fatigue cracking. They are very fine cracks requiring more sensitive penetrants (hence his well founded advise to use a Flour. Pen. with extremely good precleaning). Secondly because not many do LPI correctly, while it is a very simple process there are steps that often get shortcutted or missed entirely.
I would have complete confidence in Eddy Current inspection (a reasonably common aviation inspection method) to find ANY cracking open or close to the inspection surface. But finding good experienced Eddy Current inspectors is harder than finding good Dye inspectors. I know because I am also certified the same in Eddy Current inspection.
Non Destructive Testing is expensive, also as noted, you are better off spending the money on a new fork leg. I believe the new ones are direct replacements with no modifications needed. Here's a hint. I can do my own testing with Eddy Current, LPI, Radiography or Ultrasonics. I have the equipment and the expertise to accurately test them. I replaced my fork legs with others (WP 50mm Extreme conventional style).
Why? Because the stock forks suck, and because we don't know how quickly the fatigue cracking will cause catastrophic failure. Even if it is a slower failure, I don't want to be testing my forks every 1000 miles or whatever. It would be no good have to test them on a trip, of shock load them incorrectly once an speed the cracking process. Even more thought provoking is just because we (inspectors) accurately declare a part defect free doesn't mean the cracking won't start on the next ride.
One other note. The number of known failures is quite low compared to the number of forks that are out there. What we don't know is how many unreported failures there are, and if there are service considerations that play into failure. I ride my Dakar pretty hard, DS races and lots of dualsporting so I chose to replace and upgrade. Knowing what we know that may not be the right choice for everyone.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 05-13-2009, 03:24 AM   #229
Meltdown
Abort, Retry, Fail?
Meltdown's Avatar
Oddometer: 1,738
It was good of you to do the testing for her.
I suspect that your statement above means that BMW either settled the incident and told Baroness to keep quiet about it OR that litigation is pending. Of the 2, sadly I find the second option more likely.
In any case, after following this for some time (but never posting about it) I'm glad to hear that that she was not injured any worse that she was and that the ADV community came through for her.
Everything. Everyone. Everywhere. Ends.
Join us! The Central Florida Tag-o-Rama
Meltdown is offline   Reply With Quote
Old 05-13-2009, 06:03 AM   #230
Benesesso
Benesesso's Avatar
Oddometer: 8,506
Thanks. Maybe one day we'll all meet somewhere. As luck would have it, I finally retired shortly after I received the broken fork pieces, and lost my free access to the SEM. I did manage to get a fairly quick look at some of the pieces in the SEM, but was unable to perform a really detailed study.
With concurrence, I contacted a very highly regarded engineering forum, and found a metallurgical engineer who specialized in aluminum casting failure analyses (I am much more experienced with steel failures). We got lucky as he was aware of the incident--don't know if he's a member here or not. Fortunately he also agreed to examine the broken parts w/o charge, so off went the pieces again.
He found some things that I had missed, but our conclusions were basically in agreement. We certainly owe him a lot of thanks.
It appears that these forks can possibly fracture from different causes, but our broken fork database is tiny. The causes of many other failures I have been involved with were far easier to determine, as most of them had clear evidence of exactly what the causal factor was.
I have no knowledge of what may be happening on the broken fork legal front, if anything.
Benesesso screwed with this post 07-24-2009 at 02:03 PM
Old 07-13-2009, 07:01 AM   #231
WayneC1
Oddometer: 783
UK Safety Investigation
As of 15/6/09 UK VOSA safety Authority has announced an investigation into the fork issues on the early F650GS
They have promised a full investigation
Will post further information as it becomes available
WayneC1 is offline   Reply With Quote
Old 07-13-2009, 10:08 AM   #232
mitch
mitch's Avatar
Oddometer: 1,298
Thumb
We await with intrest for the result.
mitch
02 GSA written off by a DRUNK in pickup.
04 GSA Written off by a pickup.
06 GSA . SE. will try to stay away from pickups.
Well it was a car this time #L/tib & fib in the same place as the previous F wit crushed it
Ducati making mechanics out of riders for 50 years
mitch is offline   Reply With Quote
Old 07-16-2009, 10:25 PM   #233
RidingAgin
RidingAgin's Avatar
Oddometer: 340
Good information here, but would like more details on part number of alternate forks that would work, i,e WP 50mm Extreme conventional style, I agree, that eddy current would be the best bet, but it would require going back and rechecking... at an undetermined interval.. not good.
I had [dumped it a couple of months ago 170K 12 yrs old] a auto, mercury mountaineer that had a slight coolant leak, I pulled off the thermostat housing, ie an aluminum one, that "became" cracked. It was very small leak, but when I had the part in my hands, I gave it a twist and it broke in half. The replacement was a new design...
Well, I just had the F650GS on the highway at 75 today, the bike is parked till new forks are installed or I am convinced the ones I have are the new design. This really sucks..as riding season is in full gear now.
08 R1200GS
RidingAgin is offline   Reply With Quote
Old 07-17-2009, 01:47 AM   #234
sgk3
sgk3's Avatar
Oddometer: 16
[QUOTE=
Well, I just had the F650GS on the highway at 75 today, the bike is parked till new forks are installed or I am convinced the ones I have are the new design. This really sucks..as riding season is in full gear now.[/QUOTE]
Hey RidingAgin. Its pretty easy to tell the difference once you've seen both. The new design has signifigantly more metal around the axle. Just take a look at the bottom half the axle mount. The old style is narrow, like a half inch. The newer ones are quite a bit wider. There's a photo back in this thread somewhere that shows both new and old forks side by side. That should help you out. If you're still unsure just post a picture. One of us could tell you.
Riff Raff 2013 ???
sgk3 is offline   Reply With Quote
Old 07-17-2009, 07:01 AM   #235
RidingAgin
RidingAgin's Avatar
Oddometer: 340
Thanks sgk3, the photo at #92 has the photo of the two and #126 has another break. My F650GS is the beefed up design.
08 R1200GS
Old 07-17-2009, 08:46 AM   #236
sgk3
sgk3's Avatar
Oddometer: 16
That's good news! Now you can start RidingAgin
Riff Raff 2013 ???
Old 07-24-2009, 08:49 AM   #237
vdv2020
Luxembiker
vdv2020's Avatar
Oddometer: 161
Question Investigation
Image Source: http://www.therevcounter.com/staying...-owners-7.html
It's still open:
http://www-odi.nhtsa.dot.gov/defects/results.cfm
search on PE09026
Best regards,
VdV
_________
Transalp XL700VA 2009 yello
vdv2020 is offline   Reply With Quote
Old 08-31-2009, 12:35 PM   #238
Mossy_Crk
Fallen over
Mossy_Crk's Avatar
Oddometer: 526
We don't need to let this issue become forgotten.
Seems BMW began answering questions to NHTSA last month.
Here's the list of all documents associated
(that's open source without having to pay $$ for copies of everything)
Mossy_Crk is offline   Reply With Quote
Old 10-13-2009, 02:02 PM   #239
Crew Dawg Dave
VSRI 3563
Crew Dawg Dave's Avatar
Oddometer: 101
Question Any updates??
Anyone heard anything yet??
"Many of us are irritable most of the time (unless we're in love or just bought a motorcycle)." - Jack Lynch, The Lexicographer's Dilemma
Quidquid latine dictum sit, altum sonatur.
Crew Dawg Dave is offline   Reply With Quote
Old 10-14-2009, 12:54 PM   #240
Mossy_Crk
Fallen over
Mossy_Crk's Avatar
Oddometer: 526
Yeah, it was closed last month. Summary is list below (formatting adjusted to make it somewhat more readable)
THIS PE WAS OPENED AFTER NHTSA RECEIVED 3 VOQS CONCERNING ALLEGED FRONT AXLE SEPARATIONS ON CERTAIN BMW F650 GS MODEL MOTORCYCLES SOLD FOR USE IN THE UNITED STATES (THE SUBJECT VEHICLES). COMPLAINTS INVOLVING MOTORCYCLES IN NON-US MARKETS ARE NOT COUNTED IN THIS TOTAL.
AFTER GATHERING ADDITIONAL INFORMATION ABOUT THIS SUBJECT, WE ARE NOW AWARE OF FOUR CONFIRMED INCIDENTS INVOLVING MODEL YEAR 2001-2003 SUBJECT VEHICLES. ALL FOUR BIKES WERE BUILT BEFORE SEPTEMBER, 2002. OF THESE, TWO INVOLVE MY 2001 BIKES AND THE OTHER TWO, MY'S 2002 AND 2003, RESPECTIVELY. THE INCIDENTS OCCURRED IN 2002, 2003, AND TWO IN 2008.
IN EACH INSTANCE, THE LUG FRACTURES ARE FORCED FRACTURES RATHER THAN FATIGUE-RELATED.
BETWEEN OCTOBER 1999 AND SEPTEMBER, 2002, BMW BUILT APPROXIMATELY 4,300 SUBJECT VEHICLES. AFTER SEPTEMBER 12, 2002, ALL F650GS'S WERE BUILT WITH REINFORCED LOWER FORK TUBES TO REDUCE, ACCORDING TO BMW, "THE POSSIBILITY OF ANY SIGNIFICANT FRACTURE THAT COULD OCCUR AT THE FORK LEG AXLE LUG AREA" DURING A CRASH.
BMW TOOK THIS ACTION BECAUSE THE SUBJECT VEHICLES ARE DESIGNED FOR OFF-ROAD USE WHERE CRASHES (MANY MINOR) ARE COMMON AND DID NOT WANT RIDERS TO HAVE TO DEAL WITH A BROKEN FORK AS A RESULT.
CURRENTLY, THERE IS NO DATA CONCLUSIVELY ESTABLISHING THAT THE SUBJECT FORK LUGS ARE SEPARATING BEFORE AN ALLEGED CRASH OCCURS. ADDITIONALLY, THE INFREQUENT, SPORADIC, AND RANDOM NATURE OF THE FAILURES FAILS TO ESTABLISH A DEFECT TREND CURRENTLY EXISTS.
THEREFORE THIS INVESTIGATION IS CLOSED. A SAFETY-RELATED DEFECT HAS NOT BEEN IDENTIFIED AT THIS TIME AND FURTHER USE OF AGENCY RESOURCES DOES NOT APPEAR TO BE WARRANTED. ACCORDINGLY, THIS INVESTIGATION IS CLOSED.
THE CLOSING OF THIS INVESTIGATION DOES NOT CONSTITUTE A FINDING BY NHTSA THAT A SAFETY-RELATED DEFECT DOES NOT EXIST. THE AGENCY WILL TAKE FURTHER ACTION IF WARRANTED BY THE CIRCUMSTANCES.
Times are GMT -7.   It's 11:20 PM.
