Old 08-19-2008, 11:09 AM   #16
Plothond
Pretoria, South Africa
Plothond's Avatar
Oddometer: 40
Originally Posted by Le Dahu
I'll check again thanks.
My KTM workshop says that they never saw a faulty lambda sensor before...
2 questions:
Does anyone know if the 2 year warranty covers faulty lambda sensors?
Should I really be bothered by a faulty lambda sensor? In other words, can I ride without it?
That's BS - big time
Happened to me. Clamped rear sensor wire on left crashbar and caused the earth short.
It's possible they clamped the wire, noticed the error and removed the crashbar to rectify and never reset the error code
Your bike has a 2 year warranty - get the sensor replaced !!
Plothond is offline   Reply With Quote
Old 08-21-2013, 04:32 PM   #17
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,555
Did shorting the wire cause an ignition fuse to blow or just a code?
Yellow Pig is online now   Reply With Quote
Old 03-29-2015, 08:21 AM   #18
SwedishRider
SwedishRider's Avatar
Oddometer: 1
Pinched cable
I just did what cpmodem pointed out: clamped the cable while reassembling the crash bars. TuneECU reported it and here are some pics that might help others
http://swedishrider.com
SwedishRider is offline   Reply With Quote
Old 03-29-2015, 09:57 AM   #19
groovyspuds
groovyspuds's Avatar
Oddometer: 50
I had an issue with a cylinder temp probe that turned out to be an intermittent short due to a wire rubbing on a machined bit of the engine case. It took a LOT of time and light to find it. SLOWLY go over your wire with plenty of light bending it a bit.
M
groovyspuds is offline   Reply With Quote
Times are GMT -7.   It's 12:05 PM.
