Old 12-18-2012, 09:04 AM   #646
impala4speed
impala4speed's Avatar
Oddometer: 19
Originally Posted by danedg View Post
[/QUOTE]
Besides everything else that's just too cool about this bike, I'm digging the visor attched to the top of the windshield.
impala4speed is offline   Reply With Quote
Old 12-18-2012, 10:43 AM   #647
996DL
Buell me
Oddometer: 2,263
Originally Posted by leafman60 View Post
Num, num, num...
Could you perhaps explain the second lever setup, below the clutch lever, leafman60 ?
996DL
996DL is offline   Reply With Quote
Old 12-18-2012, 12:02 PM   #648
deerslayR
Spodely Adventurer
deerslayR's Avatar
Oddometer: 3,028
Originally Posted by 996DL View Post
Num, num, num...
996DL
Decompression lever? Although a Falcone prolly doesn't have enough compression to warrant one.
Even the Nuovo Falcone , the one pictured here, has maybe 6.85 to 1.
AMA 'MOA
ECEA 'RA
ARRA DHMC
TCSMC: teamhammer.org
"I'm a choker!" ask me how
"They're ALL dirt bikes.....some work better than others"-----Harley Huey
deerslayR is offline   Reply With Quote
Old 12-18-2012, 02:08 PM   #649
nick949eldo
Oddometer: 955
I originally held it on with duct tape, to the horror of my son (who foolishly thinks I'm aesthetically challenged). I finally got rid of the duct tape glue smears and bolted it on permanently. It completely removes any buffeting from my face, which, on longer rides, is well worth it.
Nick
nick949eldo screwed with this post 12-18-2012 at 02:13 PM
nick949eldo is offline   Reply With Quote
Old 12-18-2012, 07:26 PM   #650
leafman60
Oddometer: 1,773
Num, num, num...
996DL
Yes, that's a compression release lever. I get questions about it all the time since it doesn't look like the smaller levers typically used on other european bikes.
I have fun with it. When asked what it is, I reply "Haven't you ever heard of double-clutching?" That usually gets a serious stare from the questioner.
The engine is only 6.85:1 compression but the lever does come in handy even though not required when kick-starting instead of using the electric starter.
Most people do not know the proper procedure to kick start a big single. Slowly turn the engine over with your foot until you get to compression and feel resistance. Then , pull the compression relief lever and carefully roll the piston just past the highest compression point. Let the compression release close then and give it a helluva kick. The situation is very rare that this thing doesnt start with the first kick. The same works for my old 500 cc '53 Matchless G80.
leafman60 screwed with this post 02-13-2013 at 07:49 PM
leafman60 is offline   Reply With Quote
Old 12-19-2012, 07:45 PM   #651
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,131
It's not often I burst out laughing... but that's a good one!
Old 12-20-2012, 05:57 AM   #652
mtiberio
mtiberio's Avatar
Oddometer: 88
Most people do not know the proper procedure to kick start a big single. Slowly move turn the engine over with your foot until you get to compression and feel resistance. Then , pull the compression relief lever and carefully roll the piston just past the highest compression point. Let the compression release close then and give it a helluva kick.
or drop it into gear, and roll it backwards against compression. take it out of gear and kick.
mtiberio is offline   Reply With Quote
Old 12-20-2012, 12:42 PM   #653
volano
Oddometer: 10
The NuFalc is a joy to kick. Mine invariably chuffs to life on 1 kick. There are few things as smugly self-satisfying as 1-kicking a big single to life in front of a crowd of doubters!
btw...I've posted some stuff in the NuFalc thread also.
volano is offline   Reply With Quote
Old 12-20-2012, 01:43 PM   #654
volano
Oddometer: 10
My Ambo
Old 12-20-2012, 06:06 PM   #655
leafman60
Oddometer: 1,773
Wow, that's a pretty twin too !
Old 12-21-2012, 09:37 AM   #656
England-Kev
Oddometer: 3,576
Originally Posted by volano View Post
My Ambo
You can't just say my Ambo, and leave it at that, we need far more info, what year, where was that taken, how long have you had it, etc.... and we need pictures man
England-Kev is offline   Reply With Quote
Old 12-21-2012, 01:58 PM   #657
volano
Oddometer: 10
OK, OK...easy now Kev !
It's a '71 I've had for 3 years, in original paint and patina with 61,000 miles on it. While I appreciate Concours level restos, I must admit I'm very partial to original patina bikes. I love 'em when they show their use. A friend found this one for sale and hipped me to it, knowing it was right up my alley. I couldn't pass it up...it was short money--$1,000. Hadn't run in 5 years and took a bit of attention to make roadworthy...typical stuff. Unfortunately, as often happens with these under those circumstances, the motor started showing signs of original chrome bore degradation after I'd had it on the road for a while. The further I stripped the motor, the more signs of damage were evident. Big end shells, rod bushes showed wear and chrome scarring. Crank journal's not too bad, but at that point, I put 'er on the back burner as a winter project, and it's resting in the barn. At this point I'm debating whether to rebuild the 750 or an early timing geared 850 Eldo motor I have.
The pic was taken on a back road in my area (Central Mass.) that I frequent. I'm lucky to have nice roads nearby.
Here's one from prior to departure for the Guzzi rally in Maine last year.
On site.
Old 12-21-2012, 02:12 PM   #658
England-Kev
Oddometer: 3,576
Thanks, it could be the twin of mine....
Old 12-26-2012, 04:59 PM   #659
BOOTLACE
Bikie Scum.
BOOTLACE's Avatar
Oddometer: 3,932
bootlace
BOOTLACE is offline   Reply With Quote
Old 12-26-2012, 08:41 PM   #660
BOOTLACE
Bikie Scum.
BOOTLACE's Avatar
Oddometer: 3,932
bootlace
Times are GMT -7.   It's 02:27 AM.
