Old 08-06-2014, 08:47 AM   #886
zookster
Chupacabra
zookster's Avatar
Oddometer: 713
Originally Posted by Achtung View Post
Its all original so I have a top end to do before getting to ride it too much. The cylinders are in great shape still which I have now been convinced means now is the time to do them. Heres another poorly lit one from the garage.
A little off topic but how about some pictures of the car next to your bike? Nice Guzzi BTW, but the car is interesting too! Hopefully you can find a set of cylinders/pistons easily. The Gilardoni sets are still on back order far as I know.
We Are A Circle Within A Circle, With No Beginning, And Never Ending
zookster is offline   Reply With Quote
Old 08-06-2014, 07:45 PM   #887
maquette
maquette's Avatar
Oddometer: 213
My old pic went bye, bye. Here's a current one.
'09 KLX250S
'02 Honda ST1100
'00 Kawasaki 250 Super Sherpa (Hers)
'79 Moto Guzzi 1000SP/ Velorex 562 sidecar
'72 Moto Guzzi Eldorado
maquette is offline   Reply With Quote
Old 08-06-2014, 08:36 PM   #888
Achtung
Wicked Pisssah Adventurer
Achtung's Avatar
Oddometer: 951
I'm planning to have the cylinders either nikasil or sleeved because the Gilardonis are on perpetual backorder. To keep this on topic I'll post my IG address theres more pictures of the forty there.
http://instagram.com/johnscholes
Achtung is offline   Reply With Quote
Old 08-07-2014, 02:44 AM   #889
Morizzi
Oddometer: 93
Mark at MG Classics at Signal Hill, CA, USA is getting barrels done.
Contact him. He may be able to help.
Morizzi is offline   Reply With Quote
Old 08-07-2014, 04:54 AM   #890
Scudman
Oddometer: 312
The 1000cc cylinders bolt on the 850 cases if you remove .75mm from the cylinder skirts (aprox. $100 machining costs). This conversion has been done countless times with no issues. The 1000cc cylinders are available as the original 1000cc cylinders last a long time due to steel liners. The bike will run much better with the upgrade.
Scudman is online now   Reply With Quote
Old 08-07-2014, 08:10 AM   #891
Achtung
Achtung's Avatar
Oddometer: 951
I will thanks.
My bike is a 1971 750 Ambassador, is that conversion still an option?
Old 08-07-2014, 10:17 AM   #892
Scudman
Oddometer: 312
I will thanks.
Maybe. The 750 and 850 differ in stroke. The 850 to 1000 differ in bore and cylinder shirt outside dimension. I have converted a 750 sport into a 1000 (944?) by replacing the crank and cylinder sets. The engine runs great with this setup. This was on a Tonti framed bike. You would need to find out if a 850 crankshaft from a Eldorado fits inside the cases.
It may but check the dimensions of the bearings and distance in the cases. You will need special head gaskets that can be purchased from MG cycles.
Old 08-22-2014, 07:54 AM   #893
cccolin
Oddometer: 1,015
Finally finished this 74 850T for a customer. Rebuilt the gearbox and clutch with all new seals, gaskets, upgraded clutch plates and 4mm spline engagement, new cam chain and spring-loaded cam chain tensioner, all new oil and fuel lines, Posh signals, etc. etc. etc. etc.
cccolin screwed with this post 08-22-2014 at 08:21 AM
cccolin is offline   Reply With Quote
Old 08-22-2014, 08:07 AM   #894
Morizzi
Oddometer: 93
Its got a big fat red wire coming out of the dizzy like Dyna provide.
If so and origninality is an issue is there a reson the VHBs are still fitted?
Old 08-22-2014, 08:20 AM   #895
cccolin
Oddometer: 1,015
It doesn't have a Dyna, it's still points. I suggested the Dyna to the owner, but he didn't want to do it. likewise with the carbs. I think he had reached his budget with doing the work that got done this time. It still needs some things, which I will probably do later on.
Old 08-22-2014, 09:09 AM   #896
LAkevin
Oddometer: 26
Nothing wrong with points. I would however, put a spacer on that alternator post-haste. It's a 14 buck part from MG cycle: http://www.mgcycle.com/product_info.php?products_id=784
Your stator varnish will thank you.
LAkevin is offline   Reply With Quote
Old 08-22-2014, 09:18 AM   #897
cccolin
Oddometer: 1,015
Yeah, i told him that, too.
Old 08-23-2014, 07:38 AM   #898
terisda
Oddometer: 146
Originally Posted by Rathlindri View Post
BEAUTIFUL!!!!!
How clean is this Spada ?, must have shares in solvol and meguiars !
terisda is offline   Reply With Quote
Old 08-23-2014, 08:57 AM   #899
terisda
Oddometer: 146
My Spada
Should've left this thread well alone... ended up bagging a T3 basket case to sit beside the Spada "I only want it for the wheels..Honest", She didn't believe that either !
Old 08-23-2014, 09:06 AM   #900
terisda
Oddometer: 146
T3 "project"
Tank is there but no seat, motor an unknown quantity..worth 500 notes I reckon, (Cheers Stevie)
Times are GMT -7.   It's 04:14 PM.
