Old 09-04-2008, 11:19 PM   #1
MUTZfern OP
MUTZfern's Avatar
Oddometer: 35
Eek hack w/trailer
i saw this camper trailer.wheighs about 255lbs.its made to be towed by car or mc.i'm going to get one but my question is where do you think it should be towed from?the rear of the mc or inbetween the hack and mc?
MUTZfern is offline   Reply With Quote
Old 09-04-2008, 11:23 PM   #2
eastbloc
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,356
I had the same thoughts recently.
Logically, if you don't mount it directly behind the bike, it will contribute to the pull to the right the sidecar already provides.
Conversely, it will center the trailer behind the bike to put it in the middle. I suspect this benefit is comparatively small though.
eastbloc is offline   Reply With Quote
Old 09-05-2008, 07:21 AM   #3
Scott Davis
Which way did they go?
Scott Davis's Avatar
Oddometer: 657
Ural Trailer
Check out how this guy made his trailer. The trailer tongue is offset.
Check it out here: http://www.sheldonaubut.com/narma/na...an/trailer.htm
Scott
Scott Davis is offline   Reply With Quote
Old 09-05-2008, 09:17 AM   #4
toolfan
Broken Hearted
toolfan's Avatar
Oddometer: 9,543
Realize I'm talking out of my ass here...
but, I believe the reason many/most mount the hitch between the tug and the hack is to lessen the overall width of the train.
If you mount the hitch behind the bike, you've got half a trailer on one side and a sidecar on the other, starting to push into Hummer width territory...
toolfan is offline   Reply With Quote
Old 09-05-2008, 10:44 AM   #5
Land
Wanderer
Land's Avatar
Oddometer: 3,833
I followed a link that Scott Davis (up there ^^^^^^^^^ a couple of posts ) provided in the other sidecar/trailer thread on here and saw this cool hitch:
That looks like a neat setup.
Hope this helps,
Chris
I'm not lost. I'm explorin'.
"My dream is to live my life as best I can before I die, even if it kills me." -- Mr. Cob
"If you're on ADV and you're still anonymous, you're doing it wrong." -- Boondoggle
Land is offline   Reply With Quote
Old 09-05-2008, 01:35 PM   #6
MUTZfern OP
MUTZfern's Avatar
Oddometer: 35
correctomundo
those pics make all the difference in my thought process.now i can see the hummer effect if shes mounted behind the mc.those trailer hitches are clever and will be employed on this project.
Old 09-11-2008, 04:03 PM   #7
Montague
UDF Adventurer
Montague's Avatar
Location: an alternate universe, much better than yours
Oddometer: 666
trailer hitch
That looks like the hitch from Gene Holopaw. I bought one and mounted it last weekend to tow my m/c camper trailer.
First test ride was fine, getting the wiring adapted between the Ural and the trailer was a bit tedious.
Montague is offline   Reply With Quote
Old 09-12-2008, 12:38 PM   #8
Matt the Wanderer
Supremely Not Lost
Matt the Wanderer's Avatar
Oddometer: 265
Was already thinking about this...
It seems to me that mounting an offset hitch on the left side of the bike would actually help offset the right-pulling tendency under throttle. If you did not stick the hitch out beyond handlebar width then you could avoid the 'Hummer' sized issues. The offset tongue for the trailer would help, too. Great idea!
Simple: a tent with one pole, a chair that sets up in 5 seconds, and black coffee. This is good.
Matt the Wanderer is offline   Reply With Quote
Old 09-12-2008, 04:01 PM   #9
toolfan
Broken Hearted
toolfan's Avatar
Oddometer: 9,543
Don't forget that the trailer has width as well.
Perhaps if the trailer had an offset ball, but then I suspect it'd be much more likely to jack knife.
Old 09-15-2008, 05:42 PM   #10
Scott Davis
Oddometer: 657
Ural Trailer
Check mine out in the other trailer thread.
Scott
Times are GMT -7.   It's 05:23 PM.
