Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 04-21-2010, 12:22 PM   #1606
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,716
Originally Posted by coast range rider
Do other Ducati's come with steel handlebars too?
Mine does not.
Old 04-21-2010, 01:29 PM   #1607
Florida Lime
Florida Lime's Avatar
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 2,500
What is the advantage of using a steel handlebar painted to look like aluminum, instead of real aluminum?
I would think that a steel bar has a different harmonic vibration than a similar aluminum one.
That's my guess as to why it isn't aluminum -- vibration reduction.
'10 Husaberg FE570
'10 BMW R1200GSA "30th anniversary edition"
'14 KTM 1290 Super Duke R
'08 Ducati Hypermotard 1100S -- Going, still for sale.
Florida Lime is offline   Reply With Quote
Old 04-21-2010, 01:56 PM   #1608
ScottDill
TANSTAAFL
ScottDill's Avatar
Oddometer: 4,422
yep - think bar end weights
ScottDill is offline   Reply With Quote
Old 04-21-2010, 04:52 PM   #1609
mmcannava
Doc
Oddometer: 61
I know that a steel (chrome-mole) bicycle is much more solid and stable vs. an aluminum frame...which is light but chattery and transmits all road vibs to hands.
mmcannava is offline   Reply With Quote
Old 04-22-2010, 04:11 AM   #1610
Tosbaa
Oddometer: 3
I am sorry if I have missed the answer but a fellow inmate had asked the alternator capacity. I couldn't find it either at the time. (It should have been trivial info for a touring bike.) However, June issue of Cycle World list electrical capacity as 360 watts. It is half of 1200GSA (720 Watts) and 6/10 of GS (600 Watts) With so many electrical gadgets, I wonder how many watts will be available for farkles? Not so much I guess.
Cheers...
Tosbaa is offline   Reply With Quote
Old 04-22-2010, 04:25 AM   #1611
ScottDill
TANSTAAFL
ScottDill's Avatar
Oddometer: 4,422
Cheers...
Not listed in the spec sheet on the Ducati web site...
http://www.ducati.com/bikes/multistrada/index.do
However - did a little poking - you can get the owners manual here: http://www.ducati.com/services/maintenance/index.do
It says 500 W
Electric system
Basic electric items are:
Headlight:
low beam bulb type: 2 x H11 (12V-55W);
high beam bulb type: 2xH11 (12V-55W);
Parking light: led bulb (13.5V-4W).
Electrical controls on handlebars.
Turn signals:
Front: LED (9.8 V - 2.2 W);
Rear: halogen bulb type RY10W amber (12V-10W).
Horn.
Brake light switches.
Sealed battery, 12V-10 A.
GENERATOR 12V-500W.
ELECTRONIC RECTIFIER, protected by a 30A fuse located
on the solenoid starter, behind the battery (2, fig. 169).
Starter motor: 12V-0.7 kW.
Tail light and brake signal:
led (13.5 V- 4.2 W/1.5 W)
Number plate light: bulb type C5W (12-5W).
ScottDill screwed with this post 04-22-2010 at 01:51 PM
Old 04-22-2010, 06:09 AM   #1612
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,385
Nice find scodill !
So the gross weight is 430 kg or 947.9 lbs.
So if the bike truly comes in full of fluids just under 500 lbs then that will give close to 450 lbs of load it can carry. Not bad.
On the charging system, it does not state at what RPM however.
2004 KTM 950 Adventure S
2007 Ducati 999S Parts Unlimited
2012 Ducati Multistrada 1200 Pikes Peak
Goss is offline   Reply With Quote
Old 04-22-2010, 10:14 AM   #1613
Tosbaa
Oddometer: 3
Thanks for the clarification Scodill. A 500 (with ~150-200 excess) Watt electrical capacity would be enough for heated clothing and charging non-bike related gadgetry (Camera, PDA.. etc)
Cheers...
Old 04-22-2010, 11:52 AM   #1614
GB
Mod Squad
GB's Avatar
Oddometer: 57,138
Thanks for finding that info.. I bet that owner's manual is the size of a phone book!
500 watts is good enough for a heated jacket, but if you run a heated suit: i.e pants, socks, jacket and gloves, you'll need to turn them off when you're not cruising at highway speeds.
I could live with the 500 w output.
Old 04-22-2010, 11:57 AM   #1615
Lucky Explorer
Traveled the world
Lucky Explorer's Avatar
Oddometer: 303
How about 2 heated jackets, I would think 500 is okay? Keep the RPM's up.
Allen.
Lucky Explorer is offline   Reply With Quote
Old 04-23-2010, 04:04 AM   #1616
Monty777
Old Git
Monty777's Avatar
Oddometer: 4
Multistrada 1200 'S'
Hi Guys, let me introduce myself, Goss asked me to come over here to post some first impressions on the Mutly since I am the lucky guy who got the first one in the UK.
Where to start-well-it's everything they say it is and then some-this is a superbike in adventure clothes. Mine is nearly run in now-it's done 800 miles so I can rev it to 9000rpm-but why would I want to-it goes like a rocket keeping it under 8000!
The electronic suspension is brilliant, really compliant and easy to change modes when on the move. I have taken it offroad-down a very rutted bumpy track-it was dry-and in enduro mode the bike just rode over the bumps like they weren't there. I have to be honest here and admit I am no enduro rider, and if I really want to go offroad I wouldn't choose to do it on a nearly 200kg motorcycle-I have a 450RT for that and it only weighs 125kg-and it's a Ducati.
The majority of 'adventure' type bikes get used for distance touring and the Multi will do that with ease-and then thrash through the mountains when you get there. It will also handle fire roads and stuff like that-if you want to read a more detailed report on the first couple of weeks with the bike have a look at multistrada.net which is where Goss found me.
Must go-got some riding to do.
John
Growing Old-DISGRACEFULLY!
Monty777 is offline   Reply With Quote
Old 04-23-2010, 04:06 AM   #1617
Monty777
Old Git
Monty777's Avatar
Oddometer: 4
It runs to 202 pages-and that's just the English bit..............
John
Old 04-23-2010, 08:43 AM   #1618
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,385
Many thanks Monty777 for joining the asylum here to share your impressions of the new Multi 1200 S !
Keep us updated.
Old 04-23-2010, 08:44 AM   #1619
Gordon Bennett
At least I tried
Gordon Bennett's Avatar
Oddometer: 386
Well, I went for my test ride today in warm spring sunshine, and what a cracking bloody machine it is too. By way of background I’ve owned a number of BMWs over the years, and currently a 1200GSAdv and Ducatis - 450 single, Bevel 900SS, 851, 888, 916 (which was the worst of them all).
It was a Sport model I rode, with plenty of carbon fibre as standard. I started off with the bike set in urban mode, and just following traffic out of town it had all the usual Ducati character, only with the bad bits removed. Even the dry clutch was barely audible when riding, and not the normal "Clockwork monkey with a tambourine" of old. It can potter along snatch free at 2000 rpm, something you take for granted on a jap four, but light flywheel Ducatis always used to struggle there. Delightful quick action throttle (fly by wire) gets it away from traffic as soon as I’m in the countryside – then I switched to touring mode, where it gets decently quicker. Although it can be done while riding it’s a bit of a palaver – first hit the indicator cancel button to bring up the menu, hit the button again to scroll through the four options, then hold it down for a couple of seconds to select the new mode. What the hell is wrong with a four position selector switch? While I’m carping on, the indicator telltales are the usual Italian nice but dim things – fairly useless in sunshine. The bike was very new so gearbox was a bit on the stiff side – fine when riding but tetchy selecting neutral at a standstill. Comfort and ergonomics were great for me, with the small screen in the lowest position it did just enough without any excessive head buffeting, just right I reckon. I felt right at home very quickly – a very confidence inspiring bike. On to the full fat Sport mode – strewth, this thing bloody shifts, now I can feel the strain on neck muscles as it got up 120 alarmingly quickly, but I can’t be bothered to stop and raise the screen as I was laughing too much. Oh, and while I was up there I noticed that the mirrors were still capable of showing what was behind you, fairly blur free. As a license embuggeration device this thing’s certainly got it, real sports performance – much sharper and stronger than the 1050 Tiger I sold last month. I reckon this bike’s natural enemy will be the next Aprilia Tuono with the V4 engine – I don’t see it as an adventure bike, just a really excellent comfortable sports bike that’s up for sport touring at the push of a button (or not if the little red horns grow on your head). Mind you I forgot to test the Enduro mode, and only found out when I got back to the dealer that it not only softens the suspension, but raises it as well, which would be just the ticket for our pot holed fen roads.
You can tell a lot when you get back on your own bike. The GS felt soft, slow, top heavy and ponderous with weird steering characteristics, all of which I had got used to, and adapted to, only it only took a short ride on something really good to have the shortcomings shoved in your face. I’ll still keep it, but I’ve got an awful feeling that it’s got to share a garage with a Ducati.
- Mishap Controller -
Gordon Bennett is offline   Reply With Quote
Old 04-23-2010, 09:34 AM   #1620
jpooch00
Oddometer: 425
Thanks for the great report. The clutch is quiet because it's a wet clutch.
Did you happen to notice if the clutch lever was fairly easy to pull? They're supposedly really soft and they have some kind of torque locking mechanism in the clutch basket.
Disclaimer: The views expressed in this post are solely those of the poster and do not necessarily represent those of anyone else on this or any other forum - nor any other person from any country, planet, galaxy or universe - so don't get yer drawers in a bunch.
jpooch00 is offline   Reply With Quote
Times are GMT -7.   It's 08:37 PM.
