03-17-2011, 11:27 AM
#2176 | |
Corporate slave
Oddometer: 1,570
![]() LOL. I'm with you Joseph. I've owned both also, and I agree, the Multi feels quite a bit lighter. -SM
aka NoVector Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R, 2010 Ducati Multistrada 1200 S Sport - FOR SALE - PM me since they keep deleting my Flea Market ad ![]() Gone: Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on....... |
03-17-2011, 09:17 PM
#2177 |
Resident Raggamuffin
Oddometer: 1,704
As I have, and why I originally made the statement.
They simply aren't close.
2012 Ducati 1199 Panigale 2012 Ducati MTS1200St Ti 2003 Aprilia Tuono Racing 2012 Vespa 300 Super past: Ducatis, Aprilias, Moto Guzzis, a Husky, and some BMWs as well. |
03-18-2011, 07:39 AM
#2178 | |
Oddometer: 225
http://www.ultimatemotorcycling.com/...1200-gs-review Quotes 229 Fuelled ready to ride. On the MTS I might stand corrected seems conflicting. Have one at 218 kgs fuelled, and one at 239 , so perhaps the heavier one is with boxes ? |
03-18-2011, 10:34 AM
#2179 | |
Corporate slave
Oddometer: 1,570
Again, they are both terrific motorcycles, just different, with a different focus, and that means more choice for riders. -SM
03-18-2011, 02:37 PM
#2180 | |
Oddometer: 225
In any case I am happy to say te Multi is lighter based on the reviews I have read , as most list it at 218 wet, I made my first assumption on incorrect data by the looks. |
03-18-2011, 03:30 PM
#2181 |
Quaaack!!!
Oddometer: 1,120
"Bike" magazine in the UK tested the MultiStrada, GS and Super Tenere. They weighed them wet with full tanks ... The MS was 229Kg, the GS was 247Kg and the ST was 264Kg!
![]() They also dyno tested them ... MS 142Hp, GS 100Hp, ST 90HP.
"All that is necessary for the triumph of evil is that good men do nothing." - Edmund Bourke Irish orator, philosopher, & politician (1729 - 1797) |
03-19-2011, 04:14 AM
#2182 | |
Hey, watch this!
Oddometer: 924
Wow.... That is eye opening.... If its true.
Daniel What would you attempt to do in life if you knew that you could not fail? |
03-19-2011, 04:28 AM
#2183 |
Oddometer: 225
Is the test on line ? I would wonder what accessories were on the GS , as 247 seems way over the 229 claimed wet for the GS ?
03-19-2011, 04:46 AM
#2184 |
Oddometer: 2,808
Your kidding right!? Cause if you are not, you need serious mind deprogramming.
Treat others as you would your loved ones and respect your loved ones as you would others. Capriccio. |
03-19-2011, 05:31 AM
#2185 |
Oddometer: 728
Nothing is worse than active ignorance. Johann Wolfgang von Goethe |
03-19-2011, 07:37 PM
#2186 |
Oddometer: 225
Dry weight of Multi , as per dealr spec sheet 192 kg, for the S.
Dry weight as per BMW spec 203: Wet 229 kg. http://www.motorcycles.bmw.com.au/sc...een=ModelSpecs Multi taks 20 kgs of fuel so that would take it to 212 kg, we then need to add water , oil , battery , brake fluid ! Would still see it lighter than the GS , but not by much , you can add the stuff up , I can't see Multi have 17 kgs in the missing bits. |
03-19-2011, 09:13 PM
#2187 |
Oddometer: 1,704
the GS is a pig in comparison; weight much higher up, much higher weight, much bulkier bike (engine, plastics, windscreen), etc.. while a great riding motorcycle the GS is (yes, i owned one), it was quite large and a lot less fun to own in my opinion. i actually ride the Stelvio better than i did the GS, but that makes a bit of sense given the upgrades i've done on the Guzzi (PCV/AT/Penske rear shock).
be well,
2012 Ducati 1199 Panigale 2012 Ducati MTS1200St Ti 2003 Aprilia Tuono Racing 2012 Vespa 300 Super past: Ducatis, Aprilias, Moto Guzzis, a Husky, and some BMWs as well. oalvarez screwed with this post 03-19-2011 at 09:21 PM |
03-20-2011, 03:02 AM
#2188 | |
Oddometer: 225
03-20-2011, 04:05 AM
#2189 |
Oddometer: 728
Do you mean to say the rotation of the GS motor is "along the axis of the bike"?
03-20-2011, 12:35 PM
#2190 |
Fair/Not Balanced
Oddometer: 332
2010 MTS1200 test ride Friday afternoon
WOW...what a rocket!!! Spent about an hour on the bike in everything from stop and go traffic, moderate twisties, two-lane sweepers, to a 10 mile blast on some interstate with minimal traffic and hot dog in an Audi R8.
I was in Touring mode the whole time, so I can't speak to the other modes, but I found the bike extremely tractable in traffic, no surging or abrupt throttle on/off (I was looking for it), shifts up or down were smooth and only one false neutral, which I'll attribute to the way the shifter was adjusted...way more toe travel to upshift than I'd like. Even with the standard suspension, I found it a good balance, not too harsh, not too soft. I did notice quite a bit of front end compression under braking, but I suppose I'm used to the "telelever" on the RT and lack thereof. Ergo's were just about perfect for me (5-10) and with the windscreen in the low setting, I found good chest protection and didn't notice any bothersome buffeting at freeway speeds. I would prefer the foot brake lever extend out a little further and compared to either my BMW or Suzuki, the foot pegs are a little more rearward than I'm used to. Having the pegs set a little more rearward causes my boot toes to point downward more and I'd have liked the gearshift and the brake pedal shifted down a notch. In the short section of twisty road that I did, I was surprised that the bike took as much turning effort as it did, noticeably higher than my RT which seems to fall into turns, but due to the lighter weight, it changes directions really well. I did a couple runs through the section in both directions at higher speeds, since I'd never done the particular section of road and didn't know it or the conditions. Riding this bike fast in twisties or at a track day will demand a lot more attention! Finally figured I'd better head back to the shop before rush hour traffic started building, so I hopped on GA400 headed South to checkout the freeway manners. Where I started out was 2 lanes each direction, but about 2 miles down the road it opens up 4 lanes. I was in the left lane, behind a pickup, running about 75 or so and I could see in my mirrors something low and squat coming up pretty fast...hmmmmm! When the road opens up to 4 lanes, the PU pulls over a lane, I pass him and pull over to let the guy coming up fast go by...it's an Audi R8. As he starts to go by me, the guy in the passenger seat points down the road as in "go", the driver downshifts and punches it. I downshift to 5th and nail it, blow by the R8, look down at the speedo and it's at 140 and climbing fast...ummm, back off time...geez what a motor! And that's the beauty of the machine, great ergo's for all types of riding, brakes that will almost pop your eyes out their sockets, docile around town and a rocket ship when you twist the wrist. Add the upgrades on the S or Touring model and I can't think of anything that measures up to this level. Am I going to spring for one...I dunno...I'm going to ride a Tiger 800XC on Tuesday and then I'll decide. Different beasts, yes, but I could go either way. When you come right down to it, there really aren't many roads I'd feel any more comfortable taking the MTS on than I would my RT...I've done sand and gravel fire roads on it when I've had to. For serious off-road, I've got the DRz, tho the thought of riding it cross-country on a defined time schedule certainly doesn't appeal. The 800XC might be ideal for cross country traveling and more demanding off-road...with a healthy engine to boot. We shall see... Also, my thoughts on the current obsession with a few kilo's here or there with respect to the GS, MTS or ST...what's the point, they're very different bikes and all big pigs when you get them off-road and screw up. I just don't see the MTS being a competitor to the GS or ST when it comes to adventure touring off-road...not designed for it. Cheers,
Tom Stites - Dawsonville, GA - '11 Triumph Tiger 800XC ABS '97 BMW R1100RT '06 Suzuki DRz400s '08 Yamaha WR250R |
