12-12-2011, 12:52 PM
#2776 | |
Pretty Dogged
Oddometer: 442
Too bad it will have to sit in my garage till April !J
2007 BMW Dakar & 2009 Ducati Multistrada entering the middle of the in-land sea called Saskatchewan Canada http://s737.photobucket.com/home/OceanMtnSea |
12-13-2011, 12:37 AM
#2777 | |
Rider
Oddometer: 1,389
Try again.
12-13-2011, 08:18 AM
#2778 |
Tryin' to get home..
Oddometer: 912
The Multistrada 1200S is 520 lb w/full tank, no luggage. I weighed mine. Split 260 lb F/R.
--Doc
2010 Ducati Multistrada 1200S (RIP...but REBORN) 2006 Buell XB12X Ulysses 2000 Kawasaki KLX300R 1992 Ducati 900SS |
12-13-2011, 11:37 AM
#2779 |
Rider
Oddometer: 1,389
12-19-2011, 10:31 PM
#2780 | |
Oddometer: 421
Given the wear on tires and the general lack of performance of the claimed 150 hp, I would guess the Ducati is pretty heavy. It definitely feels heavier then my Superhawk which was the same claimed dry weight and only 1 gal of fuel difference. (But rated for 35% less hp).
'10 Multistrada 1200 Std ('11 - current) '07 Super Enduro 950 ('12- current) '02 Superhawk (37k miles, '02-'11) '96 KLX250R - kind of street legal - ('97 - current) '90 KLR 650 Tengei ('95-'97) |
12-20-2011, 06:01 AM
#2781 | |
Oddometer: 64
12-21-2011, 07:22 AM
#2782 | |
I'm the Decider
Oddometer: 3,310
+1 I've had mine lift the wheel at 90+ mph, and it pulls harder than my 1098. Something's night right if you feel your MTS1200 is underpowered.
'11 Ducati Multistrada 1200S Sport "Stormtrooper II" '09 BMW HP2 Sport '98 Ducati 900SS Final Edition "The old whore" '93 Ducati 900SS "Slightly older whore" "Gentlemen. You can't fight in here. This is the War Room!" |
12-21-2011, 09:52 AM
#2783 |
Oddometer: 421
Weird, I haven't had an opportunity to ride anyone elses. I wouldn't say underpowered, just not what I expected based on all that I read. It certainly runs fine, and has a stronger mid range then the Superhawk (carb'd), not quite the top speed I don't think, but it's a lot taller (hit 151 indicated the other day, which should be about 140, the Superhawk would get 148 or so actual, but it was more of a sportbike). It is much faster then my buddy's carb'd R6, but I definitely need to be on my toes to out run him on his Buell Uly (EFI).
2 up in the mountains, I definitely would like more power for passing, but I can't imagine ever wanting less power on any bike. It certainly does ok and as far as 1 up goes, it has more power then I am brave enough to use in the twisties. The power modes are all set to default and I can tell a small difference from 100hp to 150hp, but nothing really discernable between 150 low and 150 high. Break-in was done as per the manual, with some agressive throttle input to 6000 rpm as it got closer to 600 miles. Once it first broke in, I was able to do a couple of power wheelies in first gear, but could never re-create it. Seemed like the perfect combination of being around 5000 rpm, going wide open, and getting a little bounce about 6500 rpm. The 14 tooth sprocket woke up the taller gears on the highway but not really noticable in 1st or 2nd.
12-21-2011, 11:15 AM
#2784 |
Oddometer: 64
Well, I guess everybody perceives things differently. For instance, I feel there's a huge difference in the power of the 100 hp modes and 150...like about 50 hp worth! I was almost going to ask you if you were certain you weren't leaving it in one of the 100 hp modes.
12-21-2011, 12:49 PM
#2785 |
Practicing to retire
Oddometer: 143
Something wrong if you can't wheelie it. I get 1st, 2nd, 3rd gear wheelies on mine. It's not likely but, like someone else said maybe it's stuck in in 100 HP mode. A GSXR 1000 is just a bit faster than a MTS1200S, so you should find another MTS to try. I also can tell the difference between 100 and 150 mode, I use the enduro mode quite a bit on our goaty back roads.
Jim "Full Tilt Bozo Panic" |
12-21-2011, 01:03 PM
#2786 | |
Oddometer: 185
If it has to Be then it's up to Me! |
12-21-2011, 02:13 PM
#2787 |
Oddometer: 421
I definitely have one. 9200 miles and counting. Stock tires are crap. I put on a Michelin PR2 in the rear at 4000 miles and it is getting pretty worn. (I think I got about 8000 miles out of these tires on my Honda).
I honestly don't know how to describe the problem to the dealer. It has been re-flashed (to solve the surging at 3k-4k rpm), and obviously the rear brake isn't dragging , and it runs fine, right up to redline. I can tell the difference in the DTC settings, and the throttle response is softer in the 100 hp mode, so I assume it is switching modes fine, it just doesn't feel more powerful. It gets good mileage, a few tanks pushing 50 mpg, most in the low 40s, no backfires, very little surging, so it feels like it is running fine. Just not much enthusiasm, feels like how I would expect a Varadero or maybe even a ST to run. Smooth, powerful, but certainly no where near a true 1L sport bike.
12-21-2011, 02:38 PM
#2788 | |
Oddometer: 64
I know this power thing has been an issue you've brought up and been bugged about before, and I would be too! I hope you get to the bottom of this. |
12-21-2011, 09:21 PM
#2789 |
Oddometer: 1,114
Ramv, here are the dyno curves (rwhp):
![]() Source: sportrider.com You can see that the modes would feel similarly potent up to 5500rpm or so, with the difference being only in the throttle response, which a dyno run at full throttle won't pick up on. Can't turn up a reference, but I believe that what limits the power in urban and enduro is the ride-by-wire system, which in those modes delivers only 60 per cent of the available throttle opening, at the throttle body, when the twistgrip is wound to the stop. Hence, it occurs to me that your bike might not be delivering full throttle in the 150hp modes. You would still feel changes in response when changing modes, and the bike would feel stronger than your 100 rwhp Superhawk down low and in the early mid-range (being a 1200). And it would still rev to red-line. But it would not offer all of the 30hp advantage it should have at full throttle at the upper end of the rev range. As for what would be preventing the throttle opening, I can't say, but I imagine there are electronic and mechanical possibilities. |
12-22-2011, 06:29 AM
#2790 |
Oddometer: 447
My 1200 has the stock pipe and ecu, just for reference. I've added some othe crap (weight). It's got 27000 miles so it should be broken in. At sea level the power seems almost ridiculous - and I almost never am at wide open throttle for more than a second. However when it's loaded up with touring gear and at altitude it's noticeably less "perky". I often wind it out on uphill sweepers in the mountains, something I wouldn't do around my house (first of all - no mountains). I suspect a lot of Ramv issue is the altitude. You should however be able to tell the difference between the 100 and 150 hp modes. The difference between 150 high and low is just the twitchiness of the throttle.
