04-19-2012, 05:37 AM
#3001 | |
Oddometer: 286
The temporary aerostich heated grips simply velcro onto and above the normal grips. Yes they make the diameter larger, but it's easy to get used to. Yes there's one more set of wires near the triple clamp, but you can route the wires so that it is still a clean look. The switch is similar to an old school lamp switch. It's inline with the wires and located near the left hand grip. You simply install the heated grips, run the wires to the power source and you're done. To turn on just slide the switch. The main downside is that you need to remember to turn them off otherwise your battery will be drained. This is also easily solvable by using a relay with a hot wire trigger. Actually, if someone had an awesome relationship with their dealer I don't see why anyone would need to buy the DP heated grips. You could permanently install heated grips and run them to the multi head grip switch and get the dealer to turn the option on. I don't see why non DP grips couldn't be connected to the Multi controller since all heated grips basically function the same although there might be slight difference in resistance. This would be similar to all the guys connecting their GPS to the standard GPS plug. Since I live in Houston, where "winter" is at most only 2.5 months with summer conditions the rest of the year removable heated grips for $45 were the most cost affective option for me. I didn't pursue hooking grips into the standard plug / controller because I'm too lazy and I'm not sure my dealer is cool enough to turn the option on. Plus if there ever was any electrical problems in the future they most likely would lazily point to the non DP accessory. I just took mine off a few weeks ago and stored them in the garage. IF you're thinking about heated grips, seriously give the $45 Aerostich a thought. |
04-19-2012, 06:23 AM
#3002 |
Stossel for POTUS
Location: Where the stupidest people on earth run things
Oddometer: 23,815
Got the new seat & rode it about 75 miles on Monday. Much better in terms of rider space. I can put my toes on the pegs. The new seat is pretty firm, but the back part is nice and wide. It's a lot easier to move around on, so sliding forward for turns is not a problem. The Rocky seat's shape tends to hold you in one place.
I was able to flat foot the bike w/ my knees bent on the Rocky seat. The new seat is not too high; I can put both feet firmly on the ground. I have a 33" inseam. ![]() ![]() If you ride up close to the tank for more than a few minutes w/ the enduro seat, you get the same numbness as you do w/ a bicycle seat that has the nose above level. Sliding back on the flat portion or standing on the pegs for a few minutes returns your nerve endings to normal. All-in-all, an improvement over the Rocky.
Equal to all of you of roads and good luck! - krokodil al-kashi “We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003 |
04-19-2012, 07:34 AM
#3003 | |
Wanna be
Oddometer: 129
04-20-2012, 06:57 PM
#3004 |
What could go wrong?
Oddometer: 4,985
Top speed
Just out of curiosity.... just how fast can my stock 2011 Multistrada go, last year on a lonely highway I cranked it up to 200 kph (124mph) and had a few gears left. What ever it is I'm never going to see it but it makes me wonder.
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
04-20-2012, 07:29 PM
#3005 |
Oddometer: 551
oil change
Trying to find info on do it yourself oil changes, can anyone point me in the right direction?
Or, answer, how much does it cost to do it your self? What oil is suggested? Are there other oil filters besides ducati you can use? Again, just gathering intel...thanks!
Scott 06' Triumph Tiger (my lifer) 06' Husqvarna TE610 |
04-20-2012, 08:12 PM
#3006 | |
DucDude
Oddometer: 30
MTS 1200 seat alternatives
"...Rider accommodations are generous in the vertical dimension, (but) it becomes clear that tall riders may wish for more wriggle room between the stepped seat and that tapered-steel handlebar. The ensuing riding position focuses body weight on a point directly below your tailbone..." I feel its the vertical riding position (taken here) that causes my pain on the MTS since I didn't have it on my Yamaha FJR1300: ![]() ![]() The 9° forward leaning angle and the extra bit of room to slide backwards on the FJR seem to make it a lot easier on the coccyx... ![]() Anyone know of an aftermarket seat for the MTS1200 that extends to the rear and replaces both rider and pillion seat?
Tillerman screwed with this post 04-20-2012 at 08:36 PM Reason: typo |
04-20-2012, 09:02 PM
#3007 | |
Corporate slave
Oddometer: 1,570
![]() -SM
aka NoVector Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R, 2010 Ducati Multistrada 1200 S Sport - FOR SALE - PM me since they keep deleting my Flea Market ad ![]() Gone: Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on....... |
04-21-2012, 07:01 AM
#3008 | |
Sledge-o-matic
Oddometer: 3,994
Everybody is someone else's weirdo. |
04-21-2012, 07:05 AM
#3009 |
Stossel for POTUS
Oddometer: 23,815
Thanks B. We missed you last weekend.
04-21-2012, 08:08 AM
#3010 |
Sledge-o-matic
Oddometer: 3,994
My torn rotator cuffs suck.
Have FUN with that beauty! I know you will.
04-21-2012, 04:32 PM
#3011 | |
Oddometer: 9
Sent from my iPhone using Tapatalk |
04-21-2012, 06:57 PM
#3012 |
Oddometer: 551
Thanks for the oil change link!
04-24-2012, 09:25 AM
#3013 |
So I think my next 2 investments are going to be the MRA Touring screen and Motech crash bars.
I already ordered the bag liners and have a tank bag on the way. I also have a fuse box I need to wire in along with a few weatherproof 12v power outlets. I am going to wire my radar detector in permanently (actually use it less for radar detection and more for the emergency alerts it provides. I also have my GPS that I will be mounting up...less for direction and navigation and more for the information services it provides. I am also selling off my high end desktop replacement laptop and replacing it with an ultrabook for travel. I am considering running 12v to my top box for the laptop charger as well. Although, some of these small solar kits seem rather appealing too... Got some plans for this beast. Looking forward to travelling as much as possible and maybe some day being able to travel most of the time...
2012 Ducati Multistrada 1200S Touring Forget the road less travelled. Someone has already been there. Give me the places where the road has not yet gone. There is where you will find the true adventure. Avatar courtesy of www.mybadco.com |
04-24-2012, 02:54 PM
#3014 |
Oddometer: 99
Maps for Bazzaz?
I'm still having trouble getting my 2010 MTS to run right in the 2k to 4K range.
I've installed a D&D can with the MIVV cat eliminator pipe and a Bazzaz FI unit. I was able to get the mapping from another guy on the forums that he set up on his with an Akro system and got it close but still not quite right. My question is does anyone know of a place where we can share maps for the Bazzaz units or have one they can shoot me in an email or download somewhere? I've heard mixed reviews on the self mapping unit that Bazzaz sells so I'm hesitant to buy one just yet but would really like to try some other maps. I've heard of the Fat Ducs but I think the Bazzaz unit does the same thing as them while allowing you to tune the maps. Does anyone have any tips or info on this bike with the Bazzaz?
12 KTM 990 SMT ,09 KTM 530 EXC (plated), 06 KTM 950 Adventure, 06 Yamaha FJR AE 1300, 09 Kawasaki Brute Force 750, 10 Toyota Tundra |
04-24-2012, 03:07 PM
#3015 |
Resident Raggamuffin
Oddometer: 1,705
Semi-unrelated, but I'm seeing more dyno reports which suggest that the db killer in the MIVV decat pipe robs the motor of horsepower (restricts exhaust). Check out Ducati.MS for some great ECU/fueling related threads. Personally? The FatDucs do a great job helping the closed loop fueling down low on a stock exhaust bike.
See ya,
2012 Ducati 1199 Panigale 2012 Ducati MTS1200St Ti 2003 Aprilia Tuono Racing 2012 Vespa 300 Super past: Ducatis, Aprilias, Moto Guzzis, a Husky, and some BMWs as well. |
