Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 11-28-2012, 03:22 PM   #4036
Paulvt1 OP
Paulvt1's Avatar
Oddometer: 3,598
Does that PP look the bollocks or what?
Paulvt1 is offline   Reply With Quote
Old 11-28-2012, 05:35 PM   #4037
gsride1
Oddometer: 16
Originally Posted by Andreazz View Post
Yes, we all will suffer from PMS (parked motorcycle syndrom) for a couple of months now.. The good thing is that I no have time to clean the bike up properly and surf the internet for some new things to it
Is it an facelifted, Skyhook MTS you have ordered? I was lucky enough to test ride one in Spain this October
crappy iPhone pic:
Yes that is the exact one have ordered and they said early December delivery. Also have a few accessories including the termi exhaust on order for it.
I am pretty sure I will strip down the front end in the winter and get the fork tubes anodized in gold (vain) its just the first picture I saw of the bike (below) had gold ones and a few of my other bikes sport gold tubes so I'm going to be a poser and get that done.
I just couldnt resist the paint scheme that matches the beautiful Desmo!
gsride1 screwed with this post 11-28-2012 at 05:50 PM
gsride1 is offline   Reply With Quote
Old 11-28-2012, 10:20 PM   #4038
bingbong
bingbong's Avatar
Oddometer: 793
Nothing more needs to be said.
R Nine T
"you're never too old to learn something stupid" -- unknown.
bingbong is offline   Reply With Quote
Old 11-29-2012, 09:23 AM   #4039
KHVol
Oddometer: 2,476
Just a quick headsup on the cost of respringing our Multi's...have checked a few places for the cost of both front and rear....everyone was over $1,000 except for Ducati Greensboro who was $675. Thought that was a very good price.
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol is offline   Reply With Quote
Old 11-29-2012, 11:09 AM   #4040
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,622
the rear spring should be around $100, the front springs around $200+.......i can't see labor being anywhere near $700 for that job...maybe i'm wrong.
2015 BMW r nine T | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 11-29-2012, 12:29 PM   #4041
KHVol
Oddometer: 2,476
What I was told was 5 hrs labor for the front and 2 hrs for the back at $103 per labor hour, $721 in labor. They described the front as
" the same number of hours as required for complete fork rebuild", believe it at your own risk.
This was the same guy who when asked about the rear brake TSB replied " It's not really a rear brake , Ducati intended it to be a 'rear stabilizer'...." After asking why is the brake fluid black after 2,700 miles, he said he would try to get the TSB approved.
KHVol screwed with this post 11-30-2012 at 01:45 PM
Old 11-29-2012, 03:10 PM   #4042
expatbrit
Still pretty much a n00b.
Oddometer: 187
I think I paid about $600, including the purchase of the springs
expatbrit is offline   Reply With Quote
Old 11-30-2012, 05:46 AM   #4043
M0t0Rider
M0t0Rider's Avatar
Oddometer: 214
If you ever sit in a Motorcycle Suspension shop and watch the procedure you may see why. I would not say its a difficult job (if you know the bike, have the correct tools, and know whats involved) but a time consuming.
M0t0Rider is offline   Reply With Quote
Old 11-30-2012, 08:01 AM   #4044
Moronic
Moronic's Avatar
Oddometer: 1,726
The question is whether you want them to disassemble the fork and drain out all the oil, then replace springs and oil, or just to drop in new springs and leave everything else in place. (AFAIK.)
I remember reading somewhere recently someone from Ohlins saying just dropping in new springs was fine. There would be a bit of oil lost on the springs taken out but not enough to worry about, and you could add a few ccs more to compensate and (I am assuming) measure the oil level before and after, which will be the critical issue as Ohlins relies on the air in the fork resisting compression to prevent harsh bottoming out. (Again, AFAIK.)
Even for the whole disassembly tho, five hours sounds somewhat generous.
Sorting out the S4Rs Ohlins shock: click here.
Moronic is offline   Reply With Quote
Old 11-30-2012, 08:33 AM   #4045
spartanman
regret minimizer
spartanman's Avatar
Oddometer: 1,104
Why all the spring swaps on the Ohlins-equipped MTSs?
Standing on the shoulders of giants.
spartanman is offline   Reply With Quote
Old 11-30-2012, 08:47 AM   #4046
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,287
If you weigh more than 180lbs with gear, you need stiffer springs or you end up blowing through the stockers on relatively minor hits.
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 11-30-2012, 09:55 AM   #4047
expatbrit
Oddometer: 187
-SM
At Laguna Seca this year I was chatting to the Ohlins guy, and the default spring selection is so that you can max preload in Enduro mode, raising the rear ride height, without too much compromise to the ride quality. So the stockers are a compromise with that, along with the rest of the 'bikes sprung for 150lb riders' thing.
Oddly, I was the first guy my local dealer had had swap the springs out, however, and I'm not exactly heavy -- 195 or so in my boxers.
Old 11-30-2012, 10:47 AM   #4048
KHVol
Oddometer: 2,476
That explains why mine turned so much better after increasing the rear preload...rear ride height
Old 11-30-2012, 11:37 AM   #4049
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,130
Interesting. I wonder how the Sachs with Skyhook will work across the four riding modes. Which will the compromises be with a two-stage spring and the skyhook system. Besides the obvious possible compromises of the electronics and the related systems, or the newness of it, that one may assume will exist. I'm just wondering about performance of the system across the range.
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is online now   Reply With Quote
Old 11-30-2012, 11:55 AM   #4050
oalvarez
oalvarez's Avatar
Oddometer: 2,622
i've seen it done. changing out the fork springs on that bike is not a time intensive procedure as one of the other posters mentioned. having said that, i appreciate what you're saying.
Times are GMT -7.   It's 09:39 PM.
