Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 06-02-2013, 01:39 AM   #5056
x-moto
Oddometer: 8
I just picked up a 2011 mts 1200 and the ohlins would not work right the dealer vally motor sports in mass was going to fix that on a recall i got the mts back last week and still not working right so i road to vermont ducati to look around talked to the guys there and they ran the vin number on my mts and found no new recalls have been done only the coolent here's the deal should i stay with vally motor sports or ducati vermont this is my first ducati and i'm lost really need a good shop to work on my mts has any one used ether shop can you give me a head's up on them thanks
x-moto is offline   Reply With Quote
Old 06-02-2013, 02:45 AM   #5057
dultanur
dultanur's Avatar
Oddometer: 22
And the beauty of the SCU is,if you don't like it, chuck it on fleabay and, voila, your're only out 30-40 bucks and you have first hand experience.
"I had to lay 'er down..."
dultanur is offline   Reply With Quote
Old 06-02-2013, 06:08 AM   #5058
GS N RVN
GS N RVN's Avatar
Oddometer: 191
Water Pump Cover
Is an aftermarket cover really a must have vs. nice to have? The pump and hose appear to be vulnerable to damage. Experience and opinions wanted?
2013 Ducati Multistrada S
GS N RVN is offline   Reply With Quote
Old 06-02-2013, 06:09 AM   #5059
GS N RVN
GS N RVN's Avatar
Oddometer: 191
Luggage Rack
Looking for recommendations. Altrider, Touratech, others?
Old 06-02-2013, 06:13 AM   #5060
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,704
Originally Posted by Pampero View Post
I did a blind test. It was a disaster. I didn't make it off my driveway before testing my Rizoma water pump guard. Man, does that thing suck!
A blind test is easy to conceive in theory but harder to implement, obviously. The problem would be making sure you had two bikes in the same level of tune, same tires, same roads, same speeds, otherwise, left to the owner, the easiest thing to do is simply to ride it for a few weeks, then go back to the original settings and see how that worked out. That's sensible, easy to achieve and probably practical enough.
The shock dyno thing makes some sense, but in this instance won't show you any differences since you are testing the same shock only at different settings. It's clearly about set up with this box, and if you trust that Ohlins knows how to set up a suspension and can write the software to do that for it's system, you probably won't be disappointed.
Everybody knows the hardware to make this into Skyhook doesn't exist in the pre-13 bikes, but I have some disappointing news. The hot set up in active suspensions is magnetorheological damping, not stepper motors. There's room for improvement even in Skyhook.
Again, I think it's great that Ohlins is supporting their system and as you know (Ziff) because most of us whackos are all over every 'strada forum we can find, rider reports are starting to come in. I could C&P mine from the other list but at the least, the set up function seems to work.
Placebo effect? Maybe but usually when I spend money on something arcane, I bring a healthy dose of skepticism along with me. I don't expect Ohlins to say "hey, our thing plays second fiddle to Skyhook and is really just a sop and a half step to you guys until we get the whole thing into place and then we'll rub Sach's nose in it." If they made an improvement, I expect them to do the thing that corporations are trained to do: trumpet it loudly with tag lines like "fewer calories, more filling." What actual data exists for Skyhook beyond reaction timing? The main claim is that it's loads better. And Aprilia says theirs is even better than that,but hard data? Pretty much "reacts in miliiseceonds, more adjustment range"
As has been said, for $300 bucks if it gives you a good set up it could be well worth it to a great many of us.
I put mine on just like they told me to, and when I activated it, the little motor made whirring noises, the shock rotated and the rear wheel moved just like they said it would. Now the bike is a bit more planted and it feels better to me.
Please don't spoil my good time!
Don't misconstrue what I'm saying. I'd want to be the first person in line if I had a 12. At $300 it's a drop in the bucket...Lord knows I've spent much more on much less.
"Fools you are. To say you learn by your experience. I prefer to profit by others' mistakes and avoid the price of my own."
- Otto von Bismarck
biggziff is online now   Reply With Quote
Old 06-02-2013, 06:14 AM   #5061
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,704
Take a look at the Dynamic rack. Simple, strong and reasonably priced.
http://bang-fab.blogspot.com/2011/10...gage-rack.html
- Otto von Bismarck
Old 06-02-2013, 11:48 AM   #5062
Scoisgreat
Oddometer: 31
TOOO funny but oh so true .
Scoisgreat is offline   Reply With Quote
Old 06-02-2013, 01:00 PM   #5063
deWog
Oddometer: 107
Yep me too; had that Rizoma water pump guard on my Streetfighter. A crash left me in no doubt that the pretty Rizoma unit is the best design to effect a force at just the correct angle as the twist the water pump off the crank housing.
Worst design ever!!!!
True, and it's the reason that Sachs have (correctly) labelled their Skyhook product "semi-active". I would hope Ohlins are at least as honest with their claims.....
deWog is offline   Reply With Quote
Old 06-02-2013, 08:16 PM   #5064
Pampero
Verbose Adventurer
Pampero's Avatar
Oddometer: 710
I was thinking of you when I said that. Your posts about it "back there" were eye opening and disturbing. I actually haven't suffered the problem, was just playing off of BZ (I know he can take it!). I can do a blind test anytime I want. I just take off my glasses.
Pampero is offline   Reply With Quote
Old 06-02-2013, 08:34 PM   #5065
Dave.0
Dave.0's Avatar
Oddometer: 813
I have the altrider pump cover - looks pretty industrial, but would add protection if that part hit the ground - I also have the altrider sliders (which are huge) and it doesn't look like the pump could ever hit the ground with those on so both are probably not necessary
once again I have the altrider model - well made, functional, bolts up simply, allows placement of topcase or alternatively rotopax mount. Its a nice addition with many options to strap stuff to or mount stuff on.
Dave.0 is online now   Reply With Quote
Old 06-04-2013, 11:10 AM   #5066
Pampero
Verbose Adventurer
Pampero's Avatar
Oddometer: 710
For anyone actually looking to buy the Ohlins SCU, the word is that they are now on back order and that a price increase is expected. For better or worse, the product seems to be a commercial success.
Mine is now fully programmed for all modes and loads except enduro, which I kept stock.
Old 06-06-2013, 04:46 PM   #5067
Scoisgreat
Oddometer: 31
Mike at Nichols Sports just got confirmation from Ohlins that he will recieve his second batch on June 13 and will ship mine same day , gotta love that kind of service . Still $312 .
Old 06-07-2013, 08:51 AM   #5068
Paulvt1 OP
Paulvt1's Avatar
Oddometer: 3,602
Had a great day out on mine yesterday. Lovely and warm and dry. Makes a change..
Paulvt1 is online now   Reply With Quote
Old 06-13-2013, 02:51 PM   #5069
Pampero
Verbose Adventurer
Pampero's Avatar
Oddometer: 710
Dead thread five day bump.
I don't want a pickle......
Old 06-13-2013, 06:17 PM   #5070
gkaan
Bikes on the Brain
gkaan's Avatar
Oddometer: 505
15k service
Time for my first visit to a Ducati dealer with my new to me MTS. Dealer quoted me $599 plus parts for the 15k service. Just wondering how badly am i getting ripped off? What is everyone else paying?
gkaan is offline   Reply With Quote
Times are GMT -7.   It's 10:07 AM.
