Old 04-17-2010, 10:10 AM   #316
42
Bokononist
42's Avatar
Oddometer: 17,480
I'm a dead man.
Crawling from the wreckage
42 is online now   Reply With Quote
Old 04-20-2010, 06:51 AM   #317
N.Penley
Oddometer: 92
Flat Tire?
On one of my first dates with my wife we went on a bicycle ride. I got a flat about 6 miles from my truck. I cut off my jeans and sliced my shirt up and shoved them and some leaves into the tire. It was a wobbly ride but I rode it back. This may be a valid temp fix on a dirtbike if your britches are thick enough. My wife thought I was a superhero too.
N.Penley is offline   Reply With Quote
Old 04-30-2010, 05:57 PM   #318
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,340
I am a freaking genius. You know when you have those eureka moments, and its like whooolly cow!? Well heres mine from today.
Was working on some fork seals and was having a tough time getting the seal in. Thought it would be nice to have some type of seal drive that fit around the lower tube. Glancing around my shop I was thinkin maybe an old license plate, or what about a cardboard roll from a roll of paper towels, or the inside of a roll of electric tape, or, wait.... Electric tape!!! (lightbulb over smiley face smiley here)
Wrapped the lower tube in electric tape with about 1/8" thick, used the tube and tape to pop the seal right in! Pics to follow...
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is online now   Reply With Quote
Old 04-30-2010, 08:10 PM   #319
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,340
Heres what I mean. Fork Seal Installation with Electrical Tape:
Clean the oil of the tube, wrap a buncha tape around it.
Slide the tube down so the ring of tape pushes the seal in:
And Walla:
Seal installed! Grab the end of the tape and yank- it just spins right off!
-Charles De Mar.
Old 04-30-2010, 08:45 PM   #320
Marco Moto
Voyager
Marco Moto's Avatar
Oddometer: 1,285
And Walla:
That is awesome!
Marco Moto is online now   Reply With Quote
Old 04-30-2010, 11:15 PM   #321
isa671
blah blah blah....
isa671's Avatar
Oddometer: 263
And Walla:
Science is one cold hearted bitch with a 14 inch strap on. -Masuka (Dexter)
isa671 is offline   Reply With Quote
Old 04-30-2010, 11:37 PM   #322
Parepin
The Filthy Nomad
Parepin's Avatar
Oddometer: 1,127
I just spent little over an hour trying to get fork seals to seat before giving up and mounting tires (which I pinched and threw in the towel for the night). I'll hafta give that a try.
Parepin is offline   Reply With Quote
Old 05-01-2010, 06:59 AM   #323
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Nice one, DP! And good thing you wrapped it wide enough to press on the seal flange. If the wrap is too narrow, it will invert the seal.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 05-01-2010, 07:42 AM   #324
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,340
Yeah, make it plenty wide. it also helps to wipe the oil residue off of the tube before you wrap it with the tape...
-Charles De Mar.
Old 05-02-2010, 11:30 AM   #325
User888
Old Man
Oddometer: 12
Pissed Jumper cables made from alluminum foil.
No tools to remove battery and desperately needed jumper cables to reach 20 feet. Found a roll of allumium foil and decided to unroll two pieces and squeeze it into the shape of large wires. Using great care to make sure they did not touch each other I carefully connected them to the battery posts and waited a half hour for the two batteries to equalize the voltage. Then carefully removed the exceptionally dangerous jumper cables and the vehicle started on the first try. Very scary with the chassis being connected to ground and all but with great caution it is workable in a crisis. Great way to start a campfire with your vehicle if you are not super careful or if the wind is blowing. I supose I could have made an insulating layer out of a roll of wax paper or some duck tape. Definately would not recommend it except in the worse circumstances.
User888 is offline   Reply With Quote
Old 05-03-2010, 04:51 AM   #326
BluegrassPicker
BluegrassPicker's Avatar
Oddometer: 441
BluegrassPicker is offline   Reply With Quote
Old 05-03-2010, 08:08 AM   #327
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,531
Originally Posted by nxdirtbag
This is another one I'll be using on my CL450 carbs later this month hopefully. This thread is great. Thanks AndyJB.
Check this one out it may be easier.
http://www.advrider.com/forums/showthread.php?t=560117
scooteraug02 is offline   Reply With Quote
Old 05-03-2010, 08:49 AM   #328
nxdirtbag
Commuter Adventurer
nxdirtbag's Avatar
Oddometer: 198
PineSol. Interesting. Now I'll have to try that first since it involves less work.
nxdirtbag is offline   Reply With Quote
Old 05-03-2010, 12:07 PM   #329
RandyB
Oddometer: 5,072
I've been shot, cut, burned, blown up, fired, busted, promoted, reprimanded and decorated. What are you going to do? Ban me?
Blessed be the Lord my God, who prepares my hands for war and my fingers for battle. Psalm 144:1
RandyB is offline   Reply With Quote
Old 05-04-2010, 04:05 PM   #330
wallache
wallache's Avatar
Oddometer: 378
Originally Posted by RandyB
wallache is offline   Reply With Quote
Times are GMT -7.   It's 10:07 AM.
