Old 03-20-2012, 06:30 AM   #691
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 1,145
A real handy one, Seems headlight bulbs go bad at the most inopportune time, a trick I have used dozens of times.
You remove the bulb then turn on the dead beam, then take your finger and flick the bulb, if the element is still attached at one end, it will bounce around and literally weld itself back together. Sometimes lasts weeks, sometimes just until you hit a big bump. But it can buy you time, or save you a ticket.
Tuscany 2010
Maritime Alps and Vosges
Richard
PFFOG is online now   Reply With Quote
Old 03-20-2012, 07:03 AM   #692
Dexter2811
Dexter2811's Avatar
Oddometer: 205
or you can wrap a replacement one and tape it to the bottom back of your headlight...
Dexter2811 is online now   Reply With Quote
Old 03-20-2012, 07:04 AM   #693
troidus
Oddometer: 6,937
Back when I was a broke-assed kid, I once lost low beam in a headlight, didn't have money for a new one, and didn't want to run around with only the high beams on, so I pulled the plug and swapped the low and high beam wires to light the high beam on only one side.
troidus is offline   Reply With Quote
Old 03-20-2012, 02:03 PM   #694
Zman1
Zman1's Avatar
Oddometer: 126
Nice weather here. Of course my headlight goes out Saturday night, shop doesn't open until Tuesday. No problem, I have a spare 1157 stop/turn signal bulb in the drawer. Break out the solder gun and solder one wire to both prongs on the end of the bulb and wrap another wire around the base for the ground. Plug in to the wiring harness. Bingo, a headlight that is surprisingly very bright and most importantly, legal!!!
Ride safe and God Bless!!!!
Zman1 is offline   Reply With Quote
Old 03-21-2012, 04:59 PM   #695
AK Oldman
WANDRN
AK Oldman's Avatar
Oddometer: 235
AK Oldman is offline   Reply With Quote
Old 03-21-2012, 07:45 PM   #696
AdvRonski
They call me......Ronski
Oddometer: 555
About 30 years ago, I took a trip to the Black Hills on my BMW R100RS. I parked at Sylvan Lake, and took what has always been my favorite hike in the hills, the 6-mile round trip up to Harney Peak, the highest point in the hills. When I got back it was twilight, the parking lot was empty, and the store was closed. I tried to unlock the steering on the beemer, but it was jammed. Those old airheads had a big brass deadbolt that was pushed into a slot in the steering stem, and locked in place with a key. If someone had a thought to swipe your bike, and tried to turn the bars straight, it could put burrs on the deadbolt, which then could not be extracted from the stem.
Which apparently happened to me. Just at dark, in the middle of the Black Hills.
I worked at the stubborn bolt for a while, then gave up, stepped back, and considered my options.
I put the bike on it's centerstand, and looked things over. The handlebars were turned almost all the way to the left lock, and there was enough play in the locked steering stem to move the ends of the handlebars about an inch in either direction.
I began kicking the front tire to the right, and after about 15 minutes I had twisted the press-fit triple clamps around to have the front wheel pointing straight. I had been roadracing for a few years by then, and knew that if I kept my speed up, the tiny bit of steering lock I had would be enough.
One little problem, though.
The road out of Sylvan Lake to Rapid City was exceptionally twisty, with several 15-mph turns, and even a couple of
10-mph hairpins, as it plunged down the mountain.
So, all it required was that I go as fast as I could, unless I ran out of steering lock. Then I had better stop as fast as I could, before I went over the edge of the switchbacks.
It sure sounds easy.
It all worked out fine in the end, and that crazy charge down the mountain is one of my fondest riding memories.
I never had to bail out, and I borrowed a 1/2" drill at a gas station and drilled out the steering lock.
Ronski
Enduro Racer & Google Earth Adventurer
AdvRonski is offline   Reply With Quote
Old 03-22-2012, 03:16 PM   #697
JensEskildsen
Oddometer: 841
Cool stuff
2003 xt600e 118.000km on stock motor.
1986 xt350 94.000km
JensEskildsen is offline   Reply With Quote
Old 03-28-2012, 04:19 PM   #698
LaChupacabra
Oddometer: 21
Fixing a start button
So I bought a 1971 CL450 from my best friend who ALWAYS kick started the bike. the starter button was at a crazy angle and while trying to force it true, it broke off in my vise-grips.... I went to Fleabay and found a NOS starting button for $5 when it came in the mail i found that it didn't have the spring which was in the picture. I took the spring from my balpoint pen and stuck it behind the start button.
Mullet pride.
"The trick to flying is to throw oneself at the ground and miss."
LaChupacabra is offline   Reply With Quote
Old 03-28-2012, 07:55 PM   #699
Parepin
The Filthy Nomad
Parepin's Avatar
Oddometer: 852
Mullet pride.
I've used a ball point pen spring behind the air mixture screw on a carb as well, that is until the appropriate one was swept up from the shop floor.
Parepin is offline   Reply With Quote
Old 03-29-2012, 04:46 AM   #700
C-Stain
Unreasonable
C-Stain's Avatar
Oddometer: 2,243
This is not a mechanical tip, but one that worked in my garage the other day. I was taping drywall joints and realized I was short one hand. I put my fibre tape in a packing tape gun and was able to quickly apply, smooth and cut the fibre tape without dropping stuff.
TransLab a Go Go 2011
Nova Scotia Fresh Air Inspectors Investigate the Cabot Trail
"Second star to the left and straight on till morning” ― James T. Kirk
C-Stain is offline   Reply With Quote
Old 03-29-2012, 06:09 PM   #701
troidus
Oddometer: 6,937
Brilliant!
Old 03-30-2012, 12:50 AM   #702
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,286
Great idea C-S!
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside is offline   Reply With Quote
Old 03-30-2012, 12:05 PM   #703
C-Stain
Unreasonable
C-Stain's Avatar
Oddometer: 2,243
Originally Posted by troidus View Post
Brilliant!
Can you email that to SWMBO? I don't think she realizes it some days...
C.
Old 04-01-2012, 04:08 PM   #704
Dauntless
Oddometer: 140
I had a 1985 Ford F-350 dump truck that was used to haul a chipper around for my tree service business. I was at a customer's house getting ready to leave after a long, hot day of climbing trees. The rod that gets pushed when you depress the clutch pedal broke. I took this tube with a seam along the length of it off of the buckle of my climbing saddle. It probably has an internal diameter of a quarter inch. I stuck both ends of the broken clutch rod into the tube which acted like a coupler. Then, I took two small hose clamps off of the fuel line of the chipper and clamped them around the tube. It lasted for the ten mile ride home and probably would have lasted for several months. The next day I went to the hardware store and bought a stronger steel tube and some brazing rods and fused it all together.
Dauntless is offline   Reply With Quote
Old 04-01-2012, 06:25 PM   #705
old fart bob
Armchair adventurer
old fart bob's Avatar
Oddometer: 62
Bent clutch or brake lever
#1 About 40 years ago a metallurgist told me to heat my bent aluminum brake lever to a dull red, straighten it with a couple pairs of pliers and it would be fine when it cooled. It worked.
#2 I always carry a length of gas line slipped inside my handlebars.
#3 Taped inside my headlight bucket in a sealed plastic bag I used to keep an emergency $5 bill, a spare ignition key. Now it's 2-$20 bills and a spare key.
old fart bob is offline   Reply With Quote
Times are GMT -7.   It's 05:49 PM.
