Old 06-09-2012, 01:12 PM   #736
davsato
Oddometer: 799
Originally Posted by hilslamer View Post
Aluminum doesn't change color when it is heated, even to a plastic or molten state. You were likely working with steel...
+1 and when it goes, it goes fast! rub aluminium with soap before heating, when the soap goes black, the metals soft enough to bend
Dave
davsato is offline   Reply With Quote
Old 06-09-2012, 10:14 PM   #737
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,366
Originally Posted by stretch160 View Post
3 loose spark plug wires going zap zap zap while forcing fuel vapor from 3 cylinders. How did dad not go boom burn scream.
It takes a lot more than you would think to light gasoline on fire, 'specially when it's "uncompressed"... Try sticking the spark plug of anything next to the spark plug hole while its cranking over and see what happens. Nothing. I've gotten it to go boom ONCE- after dumpming about a cup of gasoline down the sparg plug hole. The resulting fireball was so cool my 16 yr old self had to try it agian, couldnt ever get it to work again though.
VERY cool idea though, will have to member that one!
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 06-13-2012, 05:35 AM   #738
phreakingeek
phreakingeek's Avatar
Oddometer: 554
latest ass saving moment
as i was unloading a bike from the truck in a downpour...i nearly slipped and busted my ass on the wood ramps. Luckily i was home and could grab my trusty dewalt drill and a handful of screws. I spent about 15 minutes driving approx 50 screws into the ramp i needed to walk down. I put them in as rows of 6 accross the board and spaced the rows 6 inches apart all the way down the board. I noticed that i had to back out a few screws since the driver tended to countersink the head. When they were all in and above the surface of the board, it turned a wet slippery board into a nice easy to walk on surface.
phreakingeek screwed with this post 06-13-2012 at 05:36 AM Reason: added crappy cellphone pic
phreakingeek is offline   Reply With Quote
Old 06-13-2012, 06:57 AM   #739
Wlfman
Wlfman's Avatar
Oddometer: 1,293
When I was using boards as ramps I applied 2 strips of this stuff down the entire center of each board. No problems at all with slippage.
http://www.lowes.com/pd_27300-56131-108214_0__?productId=1177559&Ntt=tread+tape&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dtread%2Btape&facetInfo=
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 06-14-2012, 07:05 AM   #740
phreakingeek
Oddometer: 554
i've never had much luck with that kind of tape
Way back in my youth, grip tape on a skate board worked fine. More recently though, my attempt to use that tape on anything that gets wet and muddy seems to remove the tape in a hurry.
Since this is a McGyver thread...i thought my quick fix was a fitting addition.
Old 06-14-2012, 09:49 AM   #741
42
Bokononist
42's Avatar
Oddometer: 17,532
Worked great on my gas tank. Gave my knees something to grip.
Crawling from the wreckage
42 is online now   Reply With Quote
Old 06-15-2012, 01:00 PM   #742
jknight611
Oddometer: 75
A Uralism
On an unsupported solo camping trip on my Ural Tourist I made a midnight ride to the "bathhouse" to..... Well in the AM the bike just wouldn't run smoothly. After a brief inspection I saw that I had kicked the right carb and the rubber on the carb mount had split. I found a guy in a very old RV that had a bit of dried up Permatex. So I cut the seam on the bottom of my T shirt, squished the sealer into it, then removed the clamp wrapped the bandage around the compliance boot let it dry, it ran fine for the next 600 miles till I could get home and replace the rubber flange. Carry a spare now....
Jay
jknight611 is offline   Reply With Quote
Old 06-18-2012, 08:36 AM   #743
svejkovat
svejkovat's Avatar
Oddometer: 856
Came across a guy stranded on the roadside one evening. I was in my car, He was standing next to an older BMW airhead. I stopped to see what was wrong. Out of gas. Angry at himself for having the petcock on reserve all the while so he'd screwed himself out of getting the last few miles to get to a station. His bike was set up like my own with one petcock on the left hand side. There was a ditch next to the road. I wheeled the bike parallel to and on the edge of the ditch and told him that between the two of us we were going to tip the one third of a gallon of gas remaining in the right tank saddle into the left. Besides being quicker and easier than scrounging around for a siphon tube of some sort or removing the tank and wrangling with the fuel lines it just felt more 'macgyver'. Not particularly brilliant but it worked and he'd never even realized that gas was in there. Got him back on the road and pretty surely to a station.
svejkovat screwed with this post 06-18-2012 at 08:46 AM
svejkovat is offline   Reply With Quote
Old 06-18-2012, 01:08 PM   #744
Wlfman
Wlfman's Avatar
Oddometer: 1,293
That's the Reserve Reserve, KLR riders know all about it
Old 07-05-2012, 06:30 AM   #745
Bob_M
Bob_M's Avatar
Oddometer: 161
Wire rope crankshaft holder
Maybe not a McGyver moment but I had to torque a crankshaft bolt on my Grand National to 310 lb-ft. with no way to keep the motor from turning.
Didn’t want to risk stuffing rope into a cylinder to lock the motor. First tried to use a piece of 1” dia EMT pipe with the end notched and wedged between one harmonic balancer bolt and the floor.
Lifted the car up off of both jack stands with torque wrench, cold sweat emerged when one of them shifted out of place, managed to kick it back in place and let car down since I was on a creeper under the car at the time.
Waited for heart rate to drop below 100 then looked for some wire rope, ran it through a hole in the harmonic balancer and tied it to the frame, was able to torque the bolt no problem.
I’ve been home on vacation this week sick as a dog, but am now fully prepared to fix absolutely anything, since I have read every post in this great thread.
Keep it going.
Bob
1996 Gas Gas JTR270, 2001 Ducati ST4
1977 Honda 750F2, 1970 Honda QA50
Bob_M is offline   Reply With Quote
Old 07-31-2012, 08:39 AM   #746
svejkovat
svejkovat's Avatar
Oddometer: 856
This morning my kitchen smelled like a toxic chemical dump. WTF? Really nasty rubber chemical burning dioxin yada yada.
I followed it to the back of the fridge. The compressor was trying to start and not having any of it. I removed the starter relay and starter cap and diassembled. Plastic was burned inside right next to a thermistor chip about the size of a nickel. Thermistor chip was shattered (due to heat and age) and the chips and debris were causing its spring loaded holder arms to short. Thermistor is used as a primitive but generally reliable relay. Closed circuit when cold, open when hot. Starts the run capacitor/starter windings when energized, heats up to open circuit within a quarter of a sec, then blocks current to the starter windings. Thermistor was broken up into three large pieces and a bunch of dust. Realized I had to get a new starter relay at the very least to save a fridge full of food until the part could be had.
Studied up on the web what was happening and a blog described the exact same predicament. A TRUE Macgyver hero on the board suggested his own fix that worked for him. It should have been obvious but I just wasn't thinking in Macgyver mode (no coffee yet). Just clean out the arc causing debris and reinsert the largest of the broken pieces of thermistor between the holder arms. A thermistor piece has pretty much the same resistance curve as the whole. Voila!!! It worked beautifully. I'll only run it while in the house so that I can keep an eye on it and unplug it while sleeping. It would probably run trouble free for another 5 years like this but until I can get the replacement relay or, more likely, replace this 10 year old Gibson, my food wont spoil!!!!
Old 07-31-2012, 11:55 AM   #747
svejkovat
svejkovat's Avatar
Oddometer: 856
The mother of invention may be laziness, but also a good portion of determined thrift. The part at the local appliance store was 75 dollars and a few days' wait. Figured I'd just use my rigged one as is until I buy a new fridge.
On a whim I stopped at the scrap yard on the drive back and looked at the dozen or so fridges on the lot. The relay is just a snap-in that's exposed in the back of the fridge.. 15 second removal tops. There were two of them with identical part numbers heading for the heap. I snapped them off and gave the attendant a buck for them.
Snapped one in when I got home and all is golden. Good for another few years anyway.
Old 08-02-2012, 12:26 PM   #748
liquidsmile
liquidsmile's Avatar
Oddometer: 1,361
If you ever strip a screw you can use match sticks to put in the hole and put the screw back in until you can fix it properly. Used this just the other day on my boat on a carpet cleat that came out of the fiberglass.
liquidsmile is offline   Reply With Quote
Old 08-02-2012, 01:20 PM   #749
theothersean
dirty boy
Oddometer: 1,039
I stripped the head of the allen cap screw that holds the battery into the back of my garmin zumo 450. luckily I was still able to apply enough down pressure and catch enough of a bite on it to it to get it out , then wrapped the threads in electrical tape to protect them while I put it in the bench vise and used the edge of a thin small file to make one slit across , basically turning the stripped allen head cap screw into a flat head screw that i can now get in and out with a common flat head screw driver , or tip of a pocket knife.
on a side note , the head was recessed in the plastic of the battery , but in other cases when you have stripped the head of a screw, bolt etc and if you can access the head you can use a dremmel, hack saw, or file to make a slit and use a flat head screwdriver to back out the fastener with the stripped head .
12 Vstrom 1K
09 KLR 650 (BLACK)
09 Yamaha WR450F (street legal )
04 prairie 700 (plow duty)
theothersean is offline   Reply With Quote
Old 08-08-2012, 05:48 AM   #750
arcanum
Oddometer: 317
Originally Posted by Aviatordoc View Post
Here is a small tip.
To prevent keys (other keys) on your key ring from tearing up the paint/finish around your ignition switch as it happens when riding:
Cut a small length of heat shrink tube which fits the key (the cut edges of the key), heat it up a tad so it conforms to the shape of the cut edges of the key but is still removable as a sleeve. Works well. Just be careful and do not heat it a lot.
Heat shrink works well to keep shoe string ends from unraveling as well. That cheap crap little plastic OEM shoe string end protector just does not cut it.
arcanum is offline   Reply With Quote
Times are GMT -7.   It's 01:18 PM.
