Old 08-13-2012, 05:54 AM   #751
Wlfman
Wlfman's Avatar
Oddometer: 1,290
Originally Posted by Aviatordoc View Post
Here is a small tip.
To prevent keys (other keys) on your key ring from tearing up the paint/finish around your ignition switch as it happens when riding:
Cut a small length of heat shrink tube which fits the key (the cut edges of the key), heat it up a tad so it conforms to the shape of the cut edges of the key but is still removable as a sleeve. Works well. Just be careful and do not heat it a lot.
Or better yet, don't have any keys except the bikes ignition key on the ring. This way you don't have to worry at all about scratches...
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is online now   Reply With Quote
Old 08-13-2012, 09:49 AM   #752
AK Oldman
WANDRN
AK Oldman's Avatar
Oddometer: 249
My oldest son borrowed my cruiser for a few months. He put the single key I handed him on a ring with a bunch of other keys. When he brought the bike back the triple tree was, IMNSHO, ruined. I'm not worried, I hid his body very well!
AK Oldman is offline   Reply With Quote
Old 08-13-2012, 04:42 PM   #753
davemon
High Speed Airhead
Oddometer: 121
Parachute rubber band tire plug
Got a flat tire on the new to me beemer and pulled out the plug kit to find the glue to be a block and the fancy BMW plugs rotted and falling apart when going thru the tire, rummaged through the tank bag and pockets and found a rubber band used for stowing lines on the deployment of most sport parachutes. Inserted it easily into the tire cut off the excess and after a couple of shots of CO2 and was back on the road home. Macgyver would have been proud. A nice ball of rubberband now resides in the tool pouch
Blue Skies and Cool Rides
davemon is offline   Reply With Quote
Old 08-18-2012, 04:10 PM   #754
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
The rubber band tire plug is a neat trick, Davemon!
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 08-21-2012, 01:02 PM   #755
Drtbkdav
Now Happy again!
Drtbkdav's Avatar
Oddometer: 50
Talking Gatorade?
While at the first reset of a national enduro several years ago, Steve Hatch looked down at my bike and asked "where is your drain plug?" I looked down and realized that when I had put my ktm 300 motor back together before the race, I had not tightend down my drain plug. it was only finger tight.
No oil was coming out of the tranny cases at all so I had lost all of the oil. worse, the biggest bolt I had was a 10mm and the hole is a 12mm. I had not noticed any running problems so far but we were only about 12 miles into the race. I wrapped some electical tape around the 10mm bolt and stuffed it into the 12mm hole. That seemed to work.
Now that I have the hole plugged, what do I fill it with? I had a tool belt and the original camelbak but niether contained any spare oil. That is not something you would normally carry during a race. I knew there would be a gas stop sooner or later and I could go back to my truck and fill it up with oil then but that does not solve the problem of riding 25 to 40 more miles with no oil in the tranny cases. I contemplated removing the oil from one of the front forks but that would destroy the action and no longer allow me to continue racing.
The only other liquids were gas/oil mix from the tank, or the orange gatorade in the camelback. Since I did not have any idea where the first gas stop was, I did not want to use the gas, I poured the gatorade into the tranny. The plug held with no leaks and the motor fired up. (the tranny oil is separate on a two stroke). I gingerly put it into gear and rode off. I took it easy and did not change gears and did not use the clutch. I noticed no problems with the tranny. After 20 miles or so I came to a check with an alternate gas stop. One of the national guys gave me a bottle of tranny oil but no one had a spare drain plug. A factory KTM rider offered me one at the known gas stop so on I went. This time with fresh real oil in the tranny but a taped in oil plug. I pushed it hard and made up lots of time till the gas stop. I got the spare plug from the KTM van (thanks guys) and managed to finish 4th in my class.
After the race, I tore down the motor and split the cases. I could find nothing wrong with any bearing, gear or clutch. I replaced the bearings anyway.
Gatorade as tranny fluid? sure if you have nothing else.
Deliberately destroying the world..... Six inches at a time!
Drtbkdav is offline   Reply With Quote
Old 08-31-2012, 08:37 PM   #756
svejkovat
svejkovat's Avatar
Oddometer: 856
then wrapped the threads in electrical tape to protect them while I put it in the bench vise and used the edge of a thin small file to make one slit across
...more tips&tricks than Macgyver, but if you ever need to hold threads really really steady in a vise then cut a slot in a nut, thread it onto the bolt/rod/stud and then clamp it up to your heart's content.
Prevents damage to the threads.
It's also a handy way to remove a stubborn stud from a block or case without damage when using vise grips.
svejkovat is offline   Reply With Quote
Old 09-01-2012, 09:39 AM   #757
Marco Moto
Voyager
Marco Moto's Avatar
Oddometer: 1,285
^^ Good one, Thanks! ^^
-Marco Moto
Marco Moto is offline   Reply With Quote
Old 09-04-2012, 11:13 AM   #758
victor441
victor441's Avatar
Oddometer: 964
seating the bead on a tubeless tire without a compressor...
long ago I did not have a compressor,changed a tubeless tire on my MC and could not get the bead to even begin to seat well enough to hold air using a manual floor pump....but had two floor pumps on hand, pulled the air chucks off and connected them with a hose, then connected one to the MC wheel and the other to a tire on my car....this flowed enough air to get the bead to begin seating on the MC wheel, pulled the chucks off and then was able to pump the MC and car tires up to rated pressure with the floor pump.
victor441 is offline   Reply With Quote
Old 09-05-2012, 07:05 AM   #759
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,732
You know they have ground penetrating Radar now. They will find him if they are looking.
---Albert Einstein
disston is online now   Reply With Quote
Old 09-13-2012, 08:02 PM   #760
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 3,934
Not mine, but a good one.
Originally Posted by Parepin View Post
I pulverized a mesquite bush, driving a branch into the radiator.
So I sat back and took inventory of the situation. I had just jumped on this set of tracks and was in quite a ways. I really didn't want to turn around, and I sure as s*** didn't want to fry the engine. Hmm... I thought back a bit, and I remember noting several years ago that some Radiator Stop Leak was simply cellulose. Pulverized plant material and whatnot. I considered grabbing some mesquite bark and seeing if I could crush it... no, that's just a bad idea. I'd heard that pepper packets work as a stop leak, but I was sure I had none of that...
So I stepped back and laid my jacket down on the dirt and began emptying pockets. This jacket had at least thirty or forty pockets, so it wouldn't hurt to look. With everything laid out before me, I began taking inventory. Hmmm.. nothin. No pepper no.... er... wait.
....... no......
.....could it.....
....I s*** you not, the radiator leak stopped. I was able to put another 75 miles of dirt, sand, and moondust before returning to the compound without a single leak.
There's a story for ya. Remember that next time you thrash your radiator.
When in doubt, take it as a compliment.
My Ride Reports
Hobbes950 is offline   Reply With Quote
Old 09-16-2012, 04:18 AM   #761
gunnabuild1
gunnabuild1's Avatar
Oddometer: 821
Now that would have been a very difficult choice to make.Should have rolled a smoke and thought about it for a while.After all there are a shitload of free leaves in that photo.
Still, filed away for future reference,radiator/cellulose,thanks knew about pepper and egg thats a new one.
gunnabuild1 is offline   Reply With Quote
Old 09-16-2012, 07:57 PM   #762
zoltan
zoltan's Avatar
Oddometer: 257
[QUOTE=.After all there are a shitload of free leaves in that photo.
.[/QUOTE]
no worries, there is no shortage of "stop leak" in Nevada City.
zoltan is offline   Reply With Quote
Old 09-19-2012, 09:42 PM   #763
Parepin
The Filthy Nomad
Parepin's Avatar
Oddometer: 1,127
No good reefer heads. That's madness, I tell ya.
Parepin is offline   Reply With Quote
Old 09-21-2012, 01:27 PM   #764
troidus
Oddometer: 15,290
Parepin will need to stay far, far away from border crossings with that bike. It would suck to have a drug dog "hit" on the bike, and end up in prison for trafficking.
troidus is online now   Reply With Quote
Old 09-21-2012, 02:03 PM   #765
MotorCade
Rugby whore
Oddometer: 457
Klx
Fixed a KLX 110 (my son's) like it was a KLR.
He dropped his bike on the first day out and broke the shifter peg off the lever. I dug through the tool bag and found a ducati spark plug tool and a small screwdriver. I bent the screwdriver and hammered the first bit of plastic through the hole, and then hammered the whole assembly onto the shift lever. the lever butts up against the screwdriver inside the tube, and doesn't move around. It was enough to get us through the weekend's riding.
IMG_4734 by MotorCade77, on Flickr
MotorCade is offline   Reply With Quote
Times are GMT -7.   It's 03:36 PM.
